Old 04-19-2016, 01:36 PM   #1
1973 Argosy 26
dawsonville , Georgia
Hitch post
Can anyone offer advice on trying to loosen the bolts that hold the hitch post to the tongue? I've sprayed lubricant, rust-buster and all sorts of stuff to try to loosen but have had no luck. Need to replace it but can't get it off.
Thank you in advance.
Cleosdad is offline   Reply With Quote
Old 04-19-2016, 01:47 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Big a----- cheater bar, works wonders on stubborn bolts.
MICHAEL
Old 04-19-2016, 01:48 PM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I'm kinda in the dark by what you're calling a hitch post. Not sure what you're referring to. If it is a bolt you're having trouble with a bigger wrench might work but be prepared to break it so hope you have access to replacement bolts, nuts, washers. It it's a stud try to be more careful but you can apply heat using a propane/acetylene torch or try an impact gun. The vibration often will help to break things free. Sometimes you just gotta do what you gotta do. Good luck with it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-19-2016, 02:33 PM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Try a can of PB Blaster (sold at Autozone, Home Depot, etc.).
BambiTex is offline   Reply With Quote
Old 04-19-2016, 02:51 PM   #5
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Hitch post
Something I found recently that I like very much:
http://crcindustries.com/auto/mobile...ct.php?s=05002
Got mine at O'Reilly Auto Parts. AutoZone also has it.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
"I don't mean to sound degrading but with a face like that you got nothing to laugh about"
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 04-26-2016, 03:17 PM   #6
Airstreamer67's Avatar
I've sometimes used a hammer on the wrench handle to "shock" a tight nut into moving. The hammer blows sometimes can provide enough extra, momentary force to make the nut turn without undue stress. Sometimes, of course, it doesn't work, and the nut and bolt can be damaged anyway.
Airstreamer67 is offline   Reply With Quote
Old 04-27-2016, 06:23 AM   #7
AWCHIEF's Avatar
Images: 33
PaulnGina
1987 Avion 34W
That looks like interesting stuff. Going to get a can.
This what I have on my bench for pesky nuts and bolts.
Kano Aerokroil Penetrating Oil, 10 oz. aerosol (AEROKROIL)
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
MICHAEL
Air Safe Air Hitch and WD hitch combo Uptightto Hitches, Couplers & Balls 18 12-22-2014 03:38 PM
Top Rated Sway Control Hitch (Hensley Hitch) Dgresham Airstream Classifieds 0 08-27-2014 10:20 AM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
