Old 03-19-2019, 10:22 AM   #1
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
Hitch play question
There is about 1/8” of play between the hitch ball assembly and the receiver on my 2010 EB. It’s annoying to hear and feel the slight “clunk” when pulling away from a stop light or whatever. It seems to be the result of a slight difference in the diameter of the hitch pin and the hitch pin hole on the receiver.
Is it typical for there to be a little play?
Are there solutions to eliminate it?
Thx
brad1 is offline   Reply With Quote
Old 03-19-2019, 10:29 AM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Thx
..my 17 ram is the same...wrapped the hitch with duct tape...lasts for quite a long time
Old 03-19-2019, 10:38 AM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Google "hitch rider".
I use one, and has eliminated that clunk.
http://www.hitchrider.com/nowobble.htm
Old 03-19-2019, 06:45 PM   #4
2017 23' International
hendersonville , North Carolina
Sloppy hitch fit
When I inserted the Equalizer shank into the original Class IV hitch on my ford van it had a "Sloppy" fit. I made a shim out of stainless steel to insert into the bottom of the receiver, then slid in the Shank. Problem solved. Fit very nicely. I did have to take a rat tail file and remove a very, very small amount of material from the hitch pin holes in the receiver. Now it slides in and no slack or clunk when towing.
Having done all that, I just replaced the factory receiver with a Class V Draw Tite "Ultra Frame" Heavy Duty receiver. Way nicer receiver and will do nicely as we are moving up to a 30' from a 23'. The fit of the shank in the new receiver is spot on. Snug, pin fits perfect. Looking forward to towing a 30'.
uraljohn is offline   Reply With Quote
Old 03-20-2019, 05:23 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I use this on the boat trailer, not needed on the Hensley.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-20-2019, 05:51 AM   #6
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
Yup, I do just like Bob.
You need to tighten it after each trip but it does work.
az-streamer is offline   Reply With Quote
Old 03-20-2019, 09:07 AM   #7
2007 22' International CCD
Hitch play question
There are a couple versions of hitch tighteners, but they all will eliminate the clunks and bangs from slack in the receiver. I use one with my ProPride setup, and it’s a lot quieter in the cab when I’m maneuvering or going from the brakes to the gas.
Old 03-20-2019, 09:21 AM   #8
Kanusport's Avatar
2019 22' Sport
Missoula , Montana
I have used a soft ride locking pin for years on my Subaru. It works.
You could also make your own by welding a nut in your receiver and using a proper strength bolt.
https://www.amazon.com/Softride-Tigh.../dp/B000T5BI8Y
Kanusport is offline   Reply With Quote
Old 03-20-2019, 01:19 PM   #9
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Like Robert, my WD hitch doesn't clunk, but my boat hitch does.
Us Hillbillies solve that with an 89cent muffler clamp.
ALUMINUMINUM is offline   Reply With Quote
Spot Welds on a Hitch Shank to Remove Play KJRitchie Hitches, Couplers & Balls 76 07-27-2015 08:22 PM
Hitch Ball Play 1Boyscout Hitches, Couplers & Balls 10 04-20-2015 07:29 AM
How to play ebay? maxandgeorgia Off Topic Forum 46 03-10-2007 07:42 PM
PDX area? Come see our play! Stefrobrts Off Topic Forum 7 10-26-2004 09:29 AM
