Old 03-05-2010, 04:01 PM   #1
Kenny Lake , Alaska
Hitch modification
I have to modify the standard ball hitch too a fifth wheel or goose neck hitch because that is all my truck has.Has anyone ever seen this modification done on a standard airstream?
Thank You Dick
alaska dick is offline   Reply With Quote
Old 03-05-2010, 04:31 PM   #2
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
I apologize in advance because I'm not sure I understand your question.
Your truck doesn't have a standard hitch?
Wouldn't it be easier and SAFER to add a standard hitch than modify the Airstream to some kludge?
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 03-05-2010, 05:22 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
5th Wheel or Gooseneck?
Do you have a 5th wheel Air Stream? Does it have a socket type hitch for a gooseneck trailer? Typically goosenecks are used on horse or stock trailers as well as flatbed utility trailers. I have not seen a 5th wheel travel trailer with the socket type hitch. They all have had a 5th wheel type hitch, a smaller version of what you see on a semi tractor/trailer.
Old 03-05-2010, 05:30 PM   #4
Kevin245's Avatar
There was one listed on Ebay last Fall. It was converted by the owner, or a fabricator for the owner and the workmanship looked good. I would say that it was unique looking to say the least.
Not sure it ever met the reserve price and I know it seller listed it twice.
Eleanor Roosevelt
Old 03-05-2010, 05:32 PM   #5
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
There was one near me that was for sale last year. A 28'ish 1980's model Airstream had a gooseneck welded to the frame and the tongue cut off. It looked very strange, but I suppose it functioned. I have NO idea if it had been done safely or met any standards... It was sold by Schmalz Auctions in Prince Albert, Saskatchewan, Canada if you want to follow up... (306)922-2300. Maybe they can put you in touch with the buyer. They were aking $9900.00 in the ad.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 03-05-2010, 05:32 PM   #6
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
He owns a freightliner. This is a large commercial truck used as delivery trucks, tow trucks . In other words a semi type truck I presume.
arodriguez60 is offline   Reply With Quote
Old 03-05-2010, 06:49 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Seen at the First Branson Fall Rally
Here is a gooseneck adaptation in the upper left photo. It does hold a flamingo nicely.
I still think I'd put a hitch on the tow vehicle instead.
Vaughan
Old 03-06-2010, 09:00 AM   #8
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
The workmanship may have looked good, but it had to be one of the ugliest things I have ever seen.
Ken
Old 03-06-2010, 10:04 AM   #9
Kenny Lake , Alaska
Thanks for the reply on the fifth wheel or goose neck mod to a standard tag along airstream.When I had my truck built it was for towing a fifth wheel or goose neck and the reciever is welded to week structure(5000 lbs) standard tow. So to make a long story short, I want a airstream but it has to be a fifth wheel or goose neck.
Dick
Old 03-24-2011, 10:56 AM   #10
1972 Travelux Princess 25
Cobourg , Ontario
I don't know about Airstream but Avion built some very fine fifth wheel trailers.
As this thread is a year old I don't expect a reply.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 03-24-2011, 11:08 AM   #11
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
why not buy a new truck,or a different truck?
Rollerboy is offline   Reply With Quote
Old 03-24-2011, 11:22 AM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
The trailer frame stresses are greater with a 5er or gooseneck hitch. I wouldn't try it with an Airstream given that there are problems with frame strength even with a stock hitch.
Old 03-24-2011, 11:23 AM   #13
1988 29' Excella
Livingston , Texas
Howdy!
I assume you are talking about towing a Airstream travel trailer with a HDT/MDT. For the cost of modifying the Airstream TT to a Gooseneck or 5th wheel pull, and then the value of it to resale later I would modify my tow vehicle to tow the Airstream now. Adding a 2" receiver the the TV should be much easier than the other modification to the TT.
"Happy Trails"
chiefneon
chiefneon is offline   Reply With Quote
Adjusted the ball and hitch today Lucky Dog Hitches, Couplers & Balls 15 03-30-2011 11:03 AM
Hitch height Khulse Hitches, Couplers & Balls 1 02-26-2011 04:19 PM
Which Hitch to buy? jomondnv Hitches, Couplers & Balls 19 01-01-2011 07:22 AM
