Old 11-15-2007, 09:56 PM   #1
1976 Argosy 24
Santa Clarita , California
Question Hitch Lubrication?
What type of lubricant is best for lubricating a weight-distributing hitch? My Reese Hitch instruction manual recommends "Reese on the Ball", but that isn't available anymore. I'm wondering what is in that lubricant, perhaps I can just use some sort of standard oil or grease?
AndyPenny is offline   Reply With Quote
Old 11-15-2007, 10:00 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I use this...
Reese® Teflon® Ball Lube - Camping World
Richard
Old 11-15-2007, 10:00 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I use marine grease. It is somewhat moisture resistant. I buy it in the boat section at Wal-Mart.
Brian
SuEllyn & Brian McCabe
Old 11-15-2007, 10:22 PM   #4
DFord79's Avatar
Yakima , Washington
another option is the grease...IF I COULD JUST REMEMBER THE NAME....that you can find at truck stops. It is used on the 5th wheel hitches for trucks. Availible almost anywhere and at truck tops if you get in a pinch.
DFord79 is offline   Reply With Quote
Old 11-15-2007, 10:30 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
I use goose grease or tallow. Sometimes peanut butter.I have a lot of turm oil, I use that too.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 11-16-2007, 02:49 AM   #6
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Turm oil...
Man thats good stuff.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 11-16-2007, 04:34 AM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Which grease to use is dependent on which area you are talking about. The trunions on the front of the hitch actually have the highest forces on them and a very low speed of movement. You can use a wheel bearing grease on them and the ball. The cams and cam followers should be very lightly lubricated to minimize metal wear and galling but not provide reduced friction, since that will detract from the hitch's ability to dampen any sway which might occur. I would use a light oil like 10-30 engine oil for that. Only a small amount would be necessary. Reese's special purpose grease is designed by them to give good lubrication for the ball and trunions while not being too thick to attract and retain road dirt which might wear the ball. It is important to clean the ball and trunions occasionally and relubricate with new grease to get rid of these contamenants.
Old 11-16-2007, 05:16 AM   #8
Images: 59
Originally Posted by Excella CM
. . . I have a lot of turm oil, I use that too.
I used to have a lot of turm oil. It can be removed with liberal applications of ethanol.
Old 11-16-2007, 05:43 AM   #9
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Originally Posted by dwightdi
The cams and cam followers should be very lightly lubricated to minimize metal wear and galling but not provide reduced friction, since that will detract from the hitch's ability to dampen any sway which might occur. I would use a light oil like 10-30 engine oil for that. .
I believe that's incorrect, the only lubricant to use there is vasaline, no grease or oil.
'77 Sovereign Intl 31' CB
Old 11-16-2007, 07:10 AM   #10
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
That's exactly what I read in the instructions that came with my Reese Dual Cam. I purchased one of those small tubes of Vaseline for lips and toss it in the bumper storage. Then, every few days while Streamin' I can easily put a small amount where the bars meet the cams.
SilverCottage is offline   Reply With Quote
Old 11-16-2007, 07:13 AM   #11
2005 22' Interstate
Afton , Virginia
I haven't pulled a trailer since the early '70's, but..
Back then I used Molykote, which I believe is molybdenum disulphide. It is a grease which was developed for high temperature applications, and worked quite well on the hitch ball.
regards
herrgirdner is offline   Reply With Quote
Old 11-16-2007, 09:25 AM   #12
1977 31' Sovereign
1989 34' Excella
Hitches do not develop high temperatures and therefore you really do not need to use the moly-disulfide grease for that characteristic, but it does provide good high pressure lubrication characteristics for use on balls and trunions. It is quite messy and black so do not get it on your clothing.
Old 11-16-2007, 11:02 AM   #13
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Look in your medicine cabinet
Vaseline on the ball and trunion.aqbsolutely nothing on the cams. Quick inexpensive and available everywhere.
Michelle TAC MT-0
Sarah, Snowball
Old 11-21-2007, 02:59 AM   #14
Michelle, that is what is recommended by the designer of the system and I go by their recommendations also.
Live and LET live
FrenchBern is offline   Reply With Quote
Stabilizer lubrication? Fyrzowt Jacks, Stabilizers, Lifting and Leveling 14 09-16-2006 05:08 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Which Hitch should I use? JimGolden Hitches, Couplers & Balls 10 02-28-2006 06:58 PM
Bal Stabilizer lubrication mandolindave Jacks, Stabilizers, Lifting and Leveling 4 02-19-2004 09:51 PM
Hitch ball lubrication Kistler Our Community 9 05-12-2003 12:48 PM
