Old 08-23-2006, 09:03 AM   #1
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Hitch locks
Can anybody point to a thread that discusses hitch locks? I know I’ve seen a thread or two on this before, but can’t seem to find them now. I’ve had a couple of problems with the search feature today (it’s me, not the site). I have kind of an emergency need to get one, but I’m interested a little more knowledge before I plunk down the money. I seem to recall that at least one of these locks could be easily defeated in some way.
Thanks for the help.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Jim & Susan is offline   Reply With Quote
Old 08-23-2006, 09:15 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Search is working okay for me now. I know the forums went off the air for a while yesterday mid-evening. Might have taken a while to get everything up and running....
I credit John Irwin with what I use. Do a search on Blaylock. I like it. It would catch the unprepared ji-hacker unawares, but all any of these would do is slow down the determined thief. The Blaylock is only aluminum, so with my eu2000i and Makita grinder I could have it off in a couple of noisy minutes.
5 meter Langford Nahanni
Old 08-23-2006, 09:17 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I found some stuff in the TOWING FORUM using keywords hitch and lock.
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 08-23-2006, 11:38 PM   #4
1960 24' Tradewind
santa barbara , California
hello jim & susan,
the master lock brand is very heavy duty and in no way I can see that it
could easily be broken into .It fits completely over the coupler ,then it has a
solid hardened pin that you thread up into the bottom side of the coupler
by way of a small opening in the bottom of the lock .you use an allen key
or wrench to screw that large pin into the coupler (the allen key comes with
the lock)then you rotate the main lock cylinder with a round key that covers
the allen wrench access hole .very beefy lock.There are similar types that
look the same as the master lock brand .I used one for years on SOB trailer
and it did the job.now the main thing is to get the one that fits your coupler.
they have many sizes and such.Our 60 trdwnd could not utilize this type do
to the extra welded area on the very front edge of the atwood coupler and
( it is the original one ,most airstreams used the marvel couplers),so i used one that fit thru the eyeloop of the coupler latch and ratchets up into the bottom of the coupler solidly .I believe it could be smashed off if needed ,
or torched or?? if someone really wanted to do that.the trdwnd sits right out front of the house and garage so it is not hidden from view .any way I cannot see that happening with the locks that cover the whole coupler ,they would be there forever smashing away ,with no luck I hope .Get the best lock they
make ,I recommend the master lock if you can get the correct one.
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 08-24-2006, 12:22 AM   #5
CaddyGrn's Avatar
1963 16' Bambi
1962 22' Safari
Yreka , California
I am interested in what you use Scott. Can you post a picture? My lack of technical knowledge gets in the way.... but a pic could show me the way!
Thanks.
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 08-24-2006, 08:55 AM   #6
1960 22' Safari
in the wilderness , The great Mojave Desert
I'd like to see a picture of that one myself.
WBCCI 3344 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 08-24-2006, 10:09 AM   #7
On the road , again...
Why not go triple duty?
Install a hitch lock, Lo-Jack, AND a wheel lock. For about $1K, that would guarantee more piece of mind than just a hitch lock.
http://www.fishing-catalog.com/hammerlock/wheel.htm
rebfa is offline   Reply With Quote
Old 08-24-2006, 01:08 PM   #8
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Jim,
I use a standard master Combination Lock. The Brass ones with a steel shackle. Four numbers. Can be re used if necessary. Picked it up at Lowes.
Michelle TAC MT-0
Sarah, Snowball
thecatsandi is offline   Reply With Quote
Old 08-24-2006, 09:32 PM   #9
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I got this one locally at Wal-Mart:
http://www.foreandaftmarine.com/220-379DAT.htm
David
TAC # TX-18
AIR # 410
https://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 08-24-2006, 11:02 PM   #10
1960 24' Tradewind
Hello everyone,
ill get a photo tomorrow friday and post it here. Once you see the master lock i have mentioned (its gold tone in color) you will see that it is made
not to be removed without the key.Quite different than the master lock
listed at the link provided,that one could also work though on my early
coupler also .The padlock can be removed in seconds with bolt cutters
I would give the thief more of a struggle with the best lock I can get,
so hopefully he can't get my airstream .
Scott
Old 03-22-2007, 11:29 PM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Coupler lock and wheel chocks
Hi, I decided from research on this forum that I need/want to purchase two items for my trailer. First I want a Guardian G-37 coupler lock. And second, I want one or two BAL #28005 wheel chocks. Where can I find the best prices on these? Camping World Has the Guardian coupler locks on sale for about $33.00, but have to special order the G-37 model for $42.00. Also they have the BAL #28005 wheel chocks for $54.00 each. From your experience do know where I can get a better price that won't get washed away by shipping charges?
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline   Reply With Quote
Old 03-23-2007, 12:09 AM   #12
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
We bought a couple but this is the one that would fit.
Universal Coupler Lock-Fits All 1-7/8", 2", and 2-5/16"Couplers It's a Gorilla lock.
Trailer Hitch Ball Mount Locks By Draw Tite
We haven't used it in a while since the Airstream is on our property and when we have been camping we have just used the long padlock that goes through the hole of the lift mechanism for the ball lock that we also use while we are hitched up.
I have wondered if those wheel chocks work if you let some of the the air out of the tires???
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 03-23-2007, 06:48 AM   #13
jimmickle's Avatar
2000 31' Land Yacht
I second Scott on the Master Lock. I have used them for over 20 years. The round key sounds like an improvement over mine which used conventional key.
jimmickle is offline   Reply With Quote
Old 03-23-2007, 06:49 AM   #14
jimmickle's Avatar
2000 31' Land Yacht
I second Scott on the Master Lock. I have used them for over 20 years. The round key sounds like an improvement over mine which uses conventional key.
Old 03-24-2007, 12:12 AM   #15
Salem , Oregon
Images: 18
Hi, I keep my trailer at home too, but when I just want to pull it forward enough to work on it and be able to open the door, [too close to the house to open door] I just use my basic 2" ball hitch; The 2" ball will slip right into tongue without unlocking it. Theives probably know this too. So I want a tongue lock too.
I just want to have the wheel chocks for when I'm camping to hold the trailer more stable. I once parked on a sight in-which I lowered my tongue jack all the way down to get my trailer level. Now I have after thoughts, that without wheel chocks of any kind, my trailer could have rolled down hill. As for secureing the trailer, let some air out of the tires, and I'm sure the tire chocks would come out easily, if that is what you meant?
Storage Compartment Locks - 1968 Jim Clark 1965 - 1969 Globetrotter 14 11-08-2017 08:05 AM
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
