Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 08-23-2006, 09:03 AM   #1
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Hitch locks
Can anybody point to a thread that discusses hitch locks? I know I’ve seen a thread or two on this before, but can’t seem to find them now. I’ve had a couple of problems with the search feature today (it’s me, not the site). I have kind of an emergency need to get one, but I’m interested a little more knowledge before I plunk down the money. I seem to recall that at least one of these locks could be easily defeated in some way.
Thanks for the help.
E=MC² (and stuff)
www.nesa.org
Air No. 6427
Old 08-23-2006, 09:15 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Search is working okay for me now. I know the forums went off the air for a while yesterday mid-evening. Might have taken a while to get everything up and running....
I credit John Irwin with what I use. Do a search on Blaylock. I like it. It would catch the unprepared ji-hacker unawares, but all any of these would do is slow down the determined thief. The Blaylock is only aluminum, so with my eu2000i and Makita grinder I could have it off in a couple of noisy minutes.
Old 08-23-2006, 09:17 AM   #3
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I found some stuff in the TOWING FORUM using keywords hitch and lock.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 08-23-2006, 11:38 PM   #4
Profile:  1960 24' Tradewind
santa barbara , California
hello jim & susan,
the master lock brand is very heavy duty and in no way I can see that it
could easily be broken into .It fits completely over the coupler ,then it has a
solid hardened pin that you thread up into the bottom side of the coupler
by way of a small opening in the bottom of the lock .you use an allen key
or wrench to screw that large pin into the coupler (the allen key comes with
the lock)then you rotate the main lock cylinder with a round key that covers
the allen wrench access hole .very beefy lock.There are similar types that
look the same as the master lock brand .I used one for years on SOB trailer
and it did the job.now the main thing is to get the one that fits your coupler.
they have many sizes and such.Our 60 trdwnd could not utilize this type do
to the extra welded area on the very front edge of the atwood coupler and
( it is the original one ,most airstreams used the marvel couplers),so i used one that fit thru the eyeloop of the coupler latch and ratchets up into the bottom of the coupler solidly .I believe it could be smashed off if needed ,
or torched or?? if someone really wanted to do that.the trdwnd sits right out front of the house and garage so it is not hidden from view .any way I cannot see that happening with the locks that cover the whole coupler ,they would be there forever smashing away ,with no luck I hope .Get the best lock they
make ,I recommend the master lock if you can get the correct one.
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 08-24-2006, 12:22 AM   #5
Profile:  1963 16' Bambi
Yreka , California
I am interested in what you use Scott. Can you post a picture? My lack of technical knowledge gets in the way.... but a pic could show me the way!
Thanks.
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 08-24-2006, 08:55 AM   #6
Profile:  2007 25' Safari FB SE
valencia , California
I'd like to see a picture of that one myself.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 08-24-2006, 10:09 AM   #7
Profile:  Currently Looking...
On the road , again...
Why not go triple duty?
Install a hitch lock, Lo-Jack, AND a wheel lock. For about $1K, that would guarantee more piece of mind than just a hitch lock.
http://www.fishing-catalog.com/hammerlock/wheel.htm
rebfa is offline   Reply With Quote
Old 08-24-2006, 01:08 PM   #8
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula maybe Helena soon , Montana
Jim,
I use a standard master Combination Lock. The Brass ones with a steel shackle. Four numbers. Can be re used if necessary. Picked it up at Lowes.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 08-24-2006, 09:32 PM   #9
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
I got this one locally at Wal-Mart:
http://www.foreandaftmarine.com/220-379DAT.htm
David
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
archival giclée prints available for each picture, 16 x 21 and larger.
dscluchfc is offline   Reply With Quote
Old 08-24-2006, 11:02 PM   #10
Hello everyone,
ill get a photo tomorrow friday and post it here. Once you see the master lock i have mentioned (its gold tone in color) you will see that it is made
not to be removed without the key.Quite different than the master lock
listed at the link provided,that one could also work though on my early
coupler also .The padlock can be removed in seconds with bolt cutters
I would give the thief more of a struggle with the best lock I can get,
so hopefully he can't get my airstream .
Scott
Old 03-22-2007, 11:29 PM   #11
ROBERTSUNRUS's Avatar
Lakewood , California
Coupler lock and wheel chocks
Hi, I decided from research on this forum that I need/want to purchase two items for my trailer. First I want a Guardian G-37 coupler lock. And second, I want one or two BAL #28005 wheel chocks. Where can I find the best prices on these? Camping World Has the Guardian coupler locks on sale for about $33.00, but have to special order the G-37 model for $42.00. Also they have the BAL #28005 wheel chocks for $54.00 each. From your experience do know where I can get a better price that won't get washed away by shipping charges?
2005 Safari 25-B
"Le Petit Chateau Argent "
[ Small Silver Castle ]
Blue Stripes, American flag, Edition
2000 Navigator / Equal-i-zer / P-3
AIR #12144
Old 03-23-2007, 12:09 AM   #12
wheel interested's Avatar
Profile:  2007 27' Classic FB
Lapeer , Michigan
Images: 117
We bought a couple but this is the one that would fit.
Universal Coupler Lock-Fits All 1-7/8", 2", and 2-5/16"Couplers It's a Gorilla lock.
Trailer Hitch Ball Mount Locks By Draw Tite
We haven't used it in a while since the Airstream is on our property and when we have been camping we have just used the long padlock that goes through the hole of the lift mechanism for the ball lock that we also use while we are hitched up.
I have wondered if those wheel chocks work if you let some of the the air out of the tires???
-Carol
Adopt the pace of nature: her secret is patience. ~Ralph Waldo Emerson
wheel interested is offline   Reply With Quote
Old 03-23-2007, 06:48 AM   #13
jimmickle's Avatar
Profile:  Marion , Iowa
I second Scott on the Master Lock. I have used them for over 20 years. The round key sounds like an improvement over mine which used conventional key.
jimmickle is offline   Reply With Quote
Old 03-23-2007, 06:49 AM   #14
jimmickle's Avatar
I second Scott on the Master Lock. I have used them for over 20 years. The round key sounds like an improvement over mine which uses conventional key.
Pingbacks are On
Storage Compartment Locks Jim Clark 1968 Globetrotter 13 06-25-2006 07:40 PM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 2 01-19-2003 09:05 PM
Hitch problem wyhjr Hitches 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches 3 07-09-2002 03:05 PM
Hitch height Chuck Hitches 9 06-09-2002 10:32 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
