Old 03-05-2013, 10:20 PM   #15
2010 27' FB Classic
N/A , Texas
Thumbs up
Originally Posted by kry226 View Post
WILCO, sir. Heck, I might even document the occasion. (And hopefully nothing else breaks.)
Excellent!
Old 03-08-2013, 09:15 AM   #16
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Originally Posted by GCinSC2 View Post
I'm the suggesting that the exact model number of your hitch searched on the manufacturers website will provide the factual answer. I don't have my hitch model number handy today, but I searched this a while back and IIRC, mine was not servicable at the component/repair kit level. I'm sure we'll figure it out.
Research complete. The part number stamped into my hitch, or A-Frame Coupler, is 88007. The attached repair instructions shows part number 88061 as the repair kit for this coupler. This is the kit I have on-hand. I'll probably do the repair this afternoon, or more likely tomorrow when the nippy wind dies down and we get a few more degrees on the mercury (the new Boondocker might get itself installed too).
More to follow.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 03-08-2013, 09:47 AM   #17
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Can you see a model number of your hitch thru the paint? Mine (2007 Classic) is stamped in the metal, don't have the number but I researched mine and it was non-servicable IIRC.
Hmmm, I have an '07 27FB Classic and would assume the 2 5/16" coupler on all recent Airstreams would be the same but it's always a good idea to verify part numbers. I tapped the roll pin out and found it was simple to remove and replace the latch. The reason I took mine out was to clean the old grit laden grease out of the coupler. I bought one to keep on hand as it looks like something that could cause a headache if it became a problem in some out of the way location.
One thing that has worked very well for me during the hitch/unhitch process is to chock the trailer in both directions then loosely chock the TV and leave it in neutral. The coupler will then latch/unlatch with no binding. Then when using the tongue jack to raise the combo to assist in latching the WD bars, the TV is free to move fore/aft relieving the lateral pressure on the jack post assy.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 03-08-2013, 05:34 PM   #18
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Found my answer.
kry226,
OK, glad you found your repair kit very good. Now here's my Rest of the Story:
http://www.airforums.com/forums/f464...d-91132-5.html
Look at post #58, the pdf is for atwood couplers and repair kits, mine is an 81912 THUMB LATCH and on page 2 it lists latch kit as N/A.
So I haven't contacted Atwood, but looks like mine does not have a latch repair kit.
I'm giving some serious thought to NOT USING the tounge jack to set the bars as this puts the latch in the position of lifting the coupling/hitch/truck to set the bars, considering a bottle jack under the hitch head to lift and to not ask the latch to take this lift load. Comments folks?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-08-2013, 06:10 PM   #19
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
kry226,
Ahh, yours is a slide out and requires a heavier rated hitch. Yours is rated at 13K while mine is at 10K. But that blows my mind that they don't make it serviceable.
As for your idea, I am not sure that the latch, when correctly done (unlike what I did) assumes much load. I'll continue to use the jack, albeit much more carefully.
2010 Classic 30
ProPride P3-1400
Old 03-09-2013, 10:47 AM   #20
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Got to the hitch this morning, and it was worse than I thought. It's a really simple, five minute job. Took some pics to share.
This part is called the shoe lock. I don't think it's supposed to look like that...
Complete. And for the moment, I don't really care that it doesn't match the Airstream gray. Once that moment passes, I'll paint it to reduce rusting. And to note, the edges of the latch handle were very sharp out of the package. I took a small file and smoothed them off.
2010 Classic 30
ProPride P3-1400
Old 03-09-2013, 11:31 AM   #21
GCinSC2's Avatar
Very good. I might post a picture later of a thumb latch coupler, but it just has a thing on the top of the coupling that when seated on the ball, you just slide it forward and it locks.
S/OS #001
Old 03-09-2013, 12:52 PM   #22
HowieE's Avatar
Princeton , New Jersey
Images: 12
kry226
I may have missed it but what WD system are you using?
2004 Excursion 4x4
Old 03-09-2013, 12:56 PM   #23
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Sir,
Reese Dual Cam 800#. Saving for a ProPride though.
Kyle
2010 Classic 30
ProPride P3-1400
Old 03-09-2013, 07:39 PM   #24
2010 27' FB Classic
N/A , Texas
kry226,
I'll be ordering the latch repair kit soon for the day when I run into the same problem. Thanks for the pictures and part numbers. Glad it all worked out for you!
Old 03-09-2013, 07:47 PM   #25
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Originally Posted by Bluto View Post
kry226,
Thanks. The kit is so cheap, and the fix so easy, that it really makes sense keeping a spare in stock while on the road.
2010 Classic 30
ProPride P3-1400
