Old 07-26-2008, 05:48 AM   #1
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
Thumbs up Hitch holder on Frame
Ha!
I tried the idea shown in the summer issue of Airstream Life from Carlos Leach.
Modiified it a bit, so it locks with my hitch pin lock, and is tucked back under
the frame. The local welding shop did it for $52.56. They used 3" OD tube
(I have a 2.5" hitch), and had to grind the seam a bit.
Works great, no more banged (or greasy) shins, and it is more secure...
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 07-26-2008, 07:51 AM   #2
adore's Avatar
1977 Argosy Minuet 6.0 Metre
Mont-Laurier , Québec
Another idea...
Originally Posted by hshovic View Post
Ha!
What about using the same for a support for a small BBQ? With a special fitting on the propane thank, I could connect it directly and would eliminate the need for transporting another 20-lb tank of propane... Any thoughts?
André
adore is offline   Reply With Quote
Old 07-26-2008, 07:59 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would rather not cook that close to my trailer. With the rock guard up and the front window open it could turn into a mess in a hurry. If you want to tap into the propane system you could install a T and a quick disconnect with a longer hose.
Richard
Old 07-26-2008, 11:00 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Looks neat.
When I get to my destination, I simply unhook, remove the hitch from the truck, put the ball into the trailer, drop the latch, lock it, and put my draw bar lock in. True I have to walk around it and my Enkay's which are attached, but it's been a good working solution for me for about 5 years now. Best of all it is free, with no additional modification needed.
I too would be concerned with a grill that close to the front of the trailer. I agree that a "T" fitting and a hose would be a better option for grilling.
Old 07-26-2008, 12:12 PM   #5
ScottW's Avatar
Hernando , Mississippi
Way too much trouble for me. I unhook and move the truck forward enough to leave a small walkway, cover the two greasy hitch balls with brightly colored tennis balls. No problems!
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 07-26-2008, 01:27 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
...<snip>....
I like it! Great way to store the hitch... We (well, Greg, actually) designed a hitch cover for our Equal-i-zer hitch so it's covered and doesn't collect dust when we drive around after unhitching the Bambi...also keeps the grease where it belongs... It's made of black vinyl inside and out so it's easy to clean.
TB & Greg and Abbey Schnauzer
#3954
Old 07-26-2008, 01:45 PM   #7
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
It would be easy to use one of those receiver hitches designed to bolt into the holes on a pickup truck step bumper for the same thing. I've always thought those things should be illegal to build, but it's perfect for that purpose. Just drill a couple of holes in the bottom of the frame, and bolt it up. You could easily tack weld the bolt threads for theft prevention.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 07-28-2008, 07:26 AM   #8
hshovic's Avatar
Bozeman , Montana
Images: 20
Some great ideas out there! I saw many of Silvertwinkie's solutions at the Byam rally.
Most did not lock their hitches, so it looks easy for anyone to hook it up and leave (whether the owner or not)... But then it is fairly secure there.
I also like the vinyl cover idea. But sewing is outside of my decision space.
However, I wanted it out of the way (in the unused triangular space by the frame), and aesthetically pleasing (to me). I wander around the trailer a lot in the 0darkthirty hours, so didn't want to run into it. And I didn't want to drag the hitch around towns..
On the grill idea, my solution was,
http://www.airforums.com/forums/f45/...tml#post455801
Hank
Old 07-29-2008, 01:03 AM   #9
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
As long as the bright tennis balls catch people's attention when they walk around behind your truck. Those hitches can really dent up shins. A bright orange cone would be better if you must leave the hitch.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 07-29-2008, 12:30 PM   #10
Cracker's Avatar
Pittsfield , Maine
I thought proper etiquette for storing the hitch was to remove it from the TV and re-attach it to (---i.e. - "hang it from") the trailer coupling, folding it back against the tongue??? I realize that this doesn't work for some of the more involved assemblies - but it works just fine for the typical equalizer assembly.
Cracker
Cracker is offline   Reply With Quote
Old 07-29-2008, 12:48 PM   #11
Aluminum Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Is there a problem?
I am following this thread with some interest, as I am tired of carrying my hitch head back and forth!
My questions - is there a problem with having the hitch head "hang" from the trailer coupler? Does this cause excess strain on the coupler?
thanks as always
Malcolm & Randy
WBCCI # 12523
kamadeca is offline   Reply With Quote
Old 07-29-2008, 01:56 PM   #12
ScottW's Avatar
Proper etiquette for storing the hitch??? I'm sorry but I can't help but chuckle at that notion. I'll reserve the remainder of my comments .
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 07-29-2008, 04:21 PM   #13
1994 30' Excella
Mississauga , Ontario
With a Hensley the stinger is about a foot long.
I take it out,put in heavy duty plastic bag and store in rear trailer compartment(under queen bed) so it can't tempt someone into becoming a thief.
Al
Old 07-29-2008, 08:06 PM   #14
Cracker's Avatar
Pittsfield , Maine
"Etiquette" was perhaps a poor choice of words for those who don't understand why the procedure was adopted - and it was intended as a somewhat "tongue in cheek" comment. Simply enough, in a crowded campground that you might encounter in a rally situation there were probably more than enough banged up legs to suggest that everyone should adhere to a given procedure to minimize the anguish. In that situation, brightly colored tennis balls probably wouldn't be effective. Pick your own choice of words!
Cracker
Flag holder barksdm General Motorhome Topics 7 07-14-2008 12:01 PM
Argosy 1976 Hitch & Frame Questions AndyPenny Hitches, Couplers & Balls 3 11-07-2007 05:35 AM
Battery Holder tray ve3czn Batteries, Univolts, Converters & Inverters 2 10-27-2007 11:12 AM
Hitch/Frame Rusted Out airdreamer Repairing/Replacing Floor &/or Frame 13 05-06-2004 11:39 PM
Neat CB Holder Pahaska Our Community 12 11-19-2002 08:35 PM
