Old 08-18-2017, 05:53 PM   #1
1976 Argosy 24
McBain , Michigan
Hitch height problems
Hey all,
I've got a '76 Argosy 24 footer that I'm towing behind a 2013 Suburban 1500. The hitch on the suburban is at the lowest setting but still sits at 23.5". Looks like recommend height for the trailer is 19.5". Hooked up with the self leveling hitch it looks like the truck is squatting bad.
My question is how big a deal is this? Should I get a hitch that is lower or lift the trailer or just not sweat it?
pfcgrinner is offline   Reply With Quote
Old 08-18-2017, 06:12 PM   #2
Mount Dora , Florida
You need a new shank that will allow you to lower the ball height, and weight distribution to take some of the 'squat' off the Suburban.
I have an Equal-I-Zer 10000 lb hitch with 1000 lb weight bars, and like it very much. But I hesitate to recommend it because that might start a brand new hitch war.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 08-18-2017, 06:36 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Whatever hitch setup you end up with, you will need a tall drop bar, and possibly an extra-tall drop bar, so the trailer will sit level.
Old 08-18-2017, 08:06 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
As Overlander said, you want whatever drop length on the hitch that will get the trailer level.
But you said the Suburban seems to be squatting pretty bad. That is a sign of not having enough weight distribution--either from bars that are too "light" or hitch adjustment (head tilt, chain length, etc. depending on the brand of the hitch).
Have you measured your wheel well heights on the Suburban both unhitched and hitched up? Have you weighed the rig on a truck scale?
SSquared is offline   Reply With Quote
Old 08-19-2017, 06:40 AM   #5
1976 Argosy 24
McBain , Michigan
No, I've not done any of that. Looks like I need to do some research paper
Old 08-19-2017, 06:41 AM   #6
1976 Argosy 24
McBain , Michigan
Research, not research paper.
Auto correct for the loss
Old 08-19-2017, 08:45 AM   #7
Mollysdad's Avatar
Originally Posted by pfcgrinner View Post
Hey all,
Not sure I understand. Your Suburban hitch is at 23.5" unloaded, but sinks to a squat when loaded? Are you using a weight equalizer hitch? Which one?
Sounds like you need more weight transferred to the front of the Suburban, that will "lift" the back.
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Hitch Height vs. Ball Height adamwright Towing, Tow Vehicles & Hitches 5 02-12-2015 03:24 PM
Problems setting rear air bag height montreal Classic Motorhomes 6 10-24-2012 12:42 AM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
