Old 06-11-2011, 07:01 AM   #1
Denis4x4's Avatar
Durango , Colorado
Hitch Handle
Got tired of wrestling the hitch and getting greasy so I took some round stock the same size as the hole in the hitch and welded it in place.
Denis4x4 is offline   Reply With Quote
Old 06-13-2011, 10:34 AM   #2
Airstreamer67's Avatar
That's a great idea. It sure should reduce the use of Go-Jo (grease remover)around the campsite. Thanks for sharing!
Airstreamer67 is offline   Reply With Quote
Old 06-13-2011, 10:56 AM   #3
jspafford's Avatar
San Diego , California
Amazon.com: Heininger 6033 Advantage SportsRack 1.25" Threaded Receiver Trailer Lock: Automotive
This hitch lock works pretty well as a carrying handle - the barrel is perpendicular to the shaft and fits the hand well. However your design allows for wrestling the heavy hitch head in the receiver.
Hope you don't bash your knee on it!
John and Lynn,
Silvia ('06 25' Safari SE FB) and Silvester ('05 Chevy Express 3500)
jspafford is offline   Reply With Quote
Old 06-13-2011, 03:14 PM   #4
Images: 59
I mounted a hook type handle on mine. It's pretty well balanced and easy to slide into the receiver.
Old 06-13-2011, 04:01 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Question. Why do you ever take it out? The only time I take mine out is to change heads for my smaller trailer, 1 3/4 in. ball.
2004 Excursion 4x4
Old 06-13-2011, 04:08 PM   #6
Images: 59
1. Because it drags on the ground when the bars aren't hitched up.
2. Because the TV is my DD.
3. Because I walk into it when I need to put something in the back of my Tahoe.
Old 06-13-2011, 04:08 PM   #7
Ottawa , ON
Guess I get tired of banging my shins on the hitch...
Old 06-13-2011, 04:42 PM   #8
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I hate to say this.... the shank is heat treated. No Welding allowed.
An interference fit rod would work better.
Michelle TAC MT-0
Sarah, Snowball
Old 06-13-2011, 05:47 PM   #9
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Or some all thread double bolted on each side.
Gene
Old 06-13-2011, 07:07 PM   #10
DKAir's Avatar
2003 30' Classic S/O
Battle Lake , Minnesota
Thanks for sharing the tips. Avoiding the grease hand, leg, chest, etc. is something I strive for but seldom achieve.
Related question, is there anyone that doesn't lube the ball (get your mind out of the gutter) and, if so, any negative consequences? My dealer told me greasing wasn't necessary, but metal on metal is bound to wear, I just don't know how quickly. I use white lithium grease as it seems the easiest to clean off the ball and then reapply when you'd like.
DK
AIR: 48965
TAC: MN-7
DKAir is offline   Reply With Quote
Old 06-13-2011, 08:02 PM   #11
Images: 59
It's a good idea to lube the ball so that coupler rotates freely on the ball. If the ball and coupler get bound up it can loosen the nut on the ball.
Old 06-13-2011, 08:38 PM   #12
Master of Universe
Gene's Avatar
I've been trying to get my mind out of the gutter for years, but just can't.
However, the dealer is an idiot. Metal rubbing metal continuously will result in early failure without grease. Since I already have wheel bearing grease, that's what I use on the ball. Dust and grit gets into the coupler, so clean it out periodically. And when I'm driving around without the trailer but don't want to take the hitch off the truck, I put a partially split tennis ball on the hitch, then clean the ball off when it is time to hitch up and re-grease it.
Every once in a while the same question appears on the Forum, so it seems quite a few people don't grease the ball because people are telling them they don't have to.
Gene
Old 06-13-2011, 09:54 PM   #13
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
Try it dry if you like but a little lube will always help. My hitch loves it.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 06-13-2011, 10:04 PM   #14
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
WHY TAKE THE HITCH OUT??? HOwie my wife walked into ours JUST ONCE.
ENOUGH SAID?????
ROGER
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Who makes this hitch? btophek Hitches, Couplers & Balls 2 06-03-2011 05:53 PM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
Hitch height Khulse Hitches, Couplers & Balls 1 02-26-2011 04:19 PM
