Old 06-27-2007, 06:29 PM   #1
1990 34' Excella
Windcrest , Texas
Hitch for F-350
Hello everyone,
Well I've scoured this forum looking for suggestions for what type of hitch to use on my 1 ton truck to buffer the impact of the springs of the truck.
I did some research into 'buffered hitches' by Air Safe and saw a few other firms. Does anyone have a suggestion regarding if these things are worth the money and if so which brand works well with an Airstream..
Cheers
Swanny is offline   Reply With Quote
Old 06-27-2007, 07:12 PM   #2
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
I just installed a hitch pn my F350, but it has a cab and chassi frame and while sprung heavy, the suspension is designed soft (guess they did not like bouncing around the "cargo".)
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 06-28-2007, 05:18 AM   #3
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
There are two vastly different versions of the F350. The single rear wheel version uses the same springs (and pretty much everything else) as the F250 and certainly doesn't need an air hitch. The only difference between them is the 4WD version of the F350 uses 3.5" blocks between the axles and springs, while the 4WD version of the F250 uses 2" blocks. So you'll need more drop on the F350 hitch. This difference doesn't exist in the 2WD versions.
The dual rear wheel F350 has MUCH heavier rear axle and springs and I definitely would think about a cushioned hitch. As a young RV tech years ago, I saw cracks in the A frame of a quality SOB the more experienced techs attributed to being towed by a dually. In this case, search for posts by Femuse, who put an air cushioned hitch on a box truck they use to tow their Airstream to festivals.
Maurice
Old 06-28-2007, 09:53 AM   #4
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Hi,
I have been using a Airsafe hitch with a reese duel cam setup/550 bars for about a year/35,000mi now.
I installed it after I had some front end separation issues.
I also installed a set of Centermatics(sp) wheel balancers.
In all fairness it would be hard to say if these things WORKS/HELP or not.
What I can say is that the front end repairs have held.
F350 1ton,dually
Michael
PS, here at JC I have seen over 5, 30-34 footers come in for front end separation over the past 2 weeks.
1994-1998 mod's, 1/2 ton to 1 ton TVs
ArtStream is offline   Reply With Quote
Old 07-01-2007, 12:09 PM   #5
1990 34' Excella
Windcrest , Texas
Thanks for the tips
This is great info. Our F-350 is the 4WD version with single rear wheels. Everything seems to ride great; however after reading other posts on this forum I was concerned that I wasn't using the correct hitch.
As for the drop you are correct. I had to find a 12" drop that could handle 10k++ pounds. We use the WD bars and I've found that I don't really need the sway control since the truck has a long bed. Thanks again everyone!
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Hensley Arrow Hitch Les Hitches, Couplers & Balls 116 12-14-2015 07:41 AM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
