Old 08-07-2010, 06:47 PM   #1
akirkbride's Avatar
1984 29' Sovereign
Phoenixville , Pennsylvania
Hitch for a 2007 3/4 ton Suburban?? Anyone???
We have a 3/4 ton, 2007 Suburban and wondered if anyone has the same - what are you using as a tow package/hitch?
The 2007 Sub receiver is IN the bumper, not below it. It's significantly higher and therefore, been a challenge to find the right hitch for towing an '84 Sovereign we are planning to buy in the next week or so.
Does anyone have the same vehicle and found a hitch package that worked for them? We're on a mission to be 'Stream owners!!!! Help!!
akirkbride is offline   Reply With Quote
Old 08-07-2010, 07:23 PM   #2
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
What is the height from the ground to the inside top of the receiver box? I think it's around 16-18" in which case you'll just need a straight hitch with a 7000 or 8000 lb capacity... You don't mention if the A/S is coming with a WD/anti-sway package, and this might make a difference to what you buy...
TX-16
Dave Park is offline   Reply With Quote
Old 08-07-2010, 07:27 PM   #3
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Our Tahoe's receiver is also in the bumber. I know its not a 3/4 ton but, our hitch is a Equalizer and I bought a 9 inch drop. You'll have to measure the tonque height to determine which drop you'll need.
subfan1 is offline   Reply With Quote
Old 08-07-2010, 07:44 PM   #4
akirkbride's Avatar
1984 29' Sovereign
The height of the receiver is 24" - thus has been our problem finding a drop - and then we were looking for some of the advice of the experts to provide their thoughts on their preferred package - Thanks, Dave and SubFan1 for your input and help! Every little bit counts...
Old 08-07-2010, 08:34 PM   #5
2010 25' FB Flying Cloud
Davenport , Iowa
I have a 07 GMC yukon 1/2 ton. It also has the receiver in the bumper. I am using a equilizer with a 11 in , 9 inch drop. My receiver measured 24 inches and the trailer was 17 3/4. I have 1 hole showing at the bottom of the drop. My measurements and weights are fine for this set-up.
Problem I do have is that I have suv tires and would prefer truck or something with a stiffer sidewall. Tires are fairly new. 8000 miles.
Airtandem is offline   Reply With Quote
Old 08-07-2010, 08:40 PM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you call the folks at Equalizer they will be able to tell you which shank you will need to provide the correct hitch ball height for your trailer. Their customer service is great.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-07-2010, 09:11 PM   #7
Lakeway , Texas
Equalizer
I have an '09 3/4 suburban but hitch height should be identical. I run an equalizer hitch and have had no problems whatsoever.
Hope this helps.
reubanks is offline   Reply With Quote
Old 08-08-2010, 11:13 AM   #8
akirkbride's Avatar
1984 29' Sovereign
Thank you to all for your help and advice. We're off to an Equalizer dealer for our next step. Hope to have the new Airstream home by Friday! Thanks again!
Old 08-10-2010, 09:18 PM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
http://www.propridehitch.com/
Contact Sean Woodruff at Pro Pride. A far better hitch than an Equalizer as it eliminates sway.
Old 08-11-2010, 02:53 AM   #10
Dave Park's Avatar
2005 22' Safari
There's something ironic about a hitch system that costs more than the trailer! Those hitches run $2,350 and up, not including shipping and handling.
TX-16
Old 08-11-2010, 07:21 AM   #11
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Welcome to Airforms!! I have a 2005 Sub so I can't help on that hitch point but I have a 1985 Sovereign 25" Love it, you will, I am sure!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 08-11-2010, 08:03 AM   #12
akirkbride's Avatar
1984 29' Sovereign
We're so excited, too - state inspection this week and then she'll be ours...of course, pending passing state inspection...she's an '84, 29-foot Sovereign and we're tickled...
We're superstitious enough not to want to post a photo until we've got a clear bill of health (hockey fans are a superstitious type...).
As for the hitch - I think we've found a dropout that is the right length (our biggest problem was finding that) and a hitch that appears to be an answer to our needs. Once we're sure of all of that, I'll post to let everyone know (especially anyone with an '07 or later Suburban) the results!
Keep fingers crossed we pass state inspection!
Old 08-11-2010, 10:26 AM   #13
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I used a Reese WD hitch initially and have switched to a Pro Pride. The difference in ease of towing and lack of sway is worth every bit of the cost!
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 08-11-2010, 08:16 PM   #14
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
Thanks Ross and Craig.
The top of receiver on the later model Suburbans is 22-24".
Most Airstreams have a top of ball measurement of 18-3/4" or 19".
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
2007 Suburban 3/4 ton - enough guts? shinysideup Tow Vehicles 10 04-20-2009 02:12 PM
New TV: 2008 Suburban LT3, 3/4 ton Jeff Evans Tow Vehicles 5 07-03-2008 09:09 AM
Suburban 3/4 Ton vs. Expedition EL Roadtech Tow Vehicles 19 12-23-2007 06:04 AM
Suburban 05 3/4 ton 6L 4.1 axle chaimemet Tow Vehicles 9 04-21-2007 07:59 PM
2007 3/4 ton Suburban changes..... Silvertwinkie Tow Vehicles 38 05-16-2006 12:26 PM
