Old 09-20-2007, 08:54 AM   #1
JimHoek's Avatar
1959 18' Traveler
Apeldoorn , The Netherlands
Images: 21
Send a message via Skype™ to JimHoek
Hitch for 1957 Dodge passenger car
Hi all,
To go in style, I would very much like to have a good, class II or III hitch for my TV, a 1957 Dodge Custom Royal Lancer.
Of course these are no longer in production (the hitchses, as are the cars...).
Does anybody have any idea about a custom product that might fit?
Much appreciated!
Regards, Jim.
Jim, WBCCI #3755 OCC #1580
The Netherlands
1959 Airstream 18ft Traveler
Avatar: 1957 Dodge Custom Royal Lancer D500
my pictures
JimHoek is offline   Reply With Quote
Old 09-20-2007, 09:07 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Best thing is to find a custom hitch shop, and let them make one for you. There weren't any prefab receivers in that era anyway.
Old 09-20-2007, 09:10 AM   #3
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Try the junk yards...find one off a wide SUV and modify it.
klattu is offline   Reply With Quote
Old 09-20-2007, 09:15 AM   #4
JimHoek's Avatar
1959 18' Traveler
Images: 21
What I'd prefer is to have one which doesn't need any welding at all, or at least hardly any...
There were era correct receivers, but you wouldn't want these... There was one on eBay recently, see the accompanying picture.
Name:	57-58 Plymouth Hitch.jpg
The Netherlands
my pictures
Old 09-20-2007, 09:26 AM   #5
rideair's Avatar
Jim,
I've had a couple of "custom hitches" made over the past few years. Not that it's hard, it can be hard to find someone that will do the work. Lucky for me, I have a friend that can do it. The problem, more and more, people are less willing to do that type of work becuase they don't want to be on the hook if it fails and someone gets hurt.
Paul Waddell
rideair is offline   Reply With Quote
Old 09-20-2007, 02:17 PM   #6
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Don't pull a fat girl off a tricycle with a hitch like that !
The welding needed would not be on your car, it would be done to hitch only, then bolted onto frame.
Maybe using existing holes too.
Old 09-20-2007, 03:29 PM   #7
1976 25' Caravanner
Campton , New Hampshire
I think you would be better off with a 2" reciever so you could use an adjustable ball mount to gain the correct height . Some U-haul places do custom hitches , also some welding shops . Good luck
ticki2 is offline   Reply With Quote
Old 09-20-2007, 03:52 PM   #8
Images: 59
Jim,
You can certainly use a 2" receiver, they are correct for that year. My '59 Tradewind was originally hitched up behind a '57 Chrysler. The hitch was an EAZ-LIFT.
I believe the only difference between it and today's hitches was the tube was 2.5 inches (63mm), compared to todays 2 inches.
I have the original documentation if you would like me to fax it to you. There were several installation options, including one that had draghooks from the rear axle.
The head was adjustable. Once. The head would be set up at the correct height and angle, and then the head and tank bar were welded together permanently. The tank bar, sleeve, shank and uprights were chrome-moly 4130 steel, they recommended a low hydrogen welding rod, such as #327 Airco 5/32".
Other than that, the hitch looks just like a modern Reese round bar WD hitch with a friction anti-sway bar.
Old 09-20-2007, 06:21 PM   #9
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Mr. Incredible, meet Mr. Incredulous
Originally Posted by markdoane
... The tank bar, sleeve, shank and uprights were chrome-moly 4130 steel, they recommended a low hydrogen welding rod, such as #327 Airco 5/32". ...
I am casually familiar with the steel & welding rod you posted, and can believe the materials are the optimum choice.
But how in the h*ll did you know that?
Tom
Old 09-20-2007, 06:39 PM   #10
Images: 59
Tom
Back-In-The-Day, the manufacturers presumed your local mechanic would be welding the thing up for you, and they included things like that in the instruction sheet.
Sure made it easier.
Old 09-20-2007, 08:15 PM   #11
JimHoek's Avatar
1959 18' Traveler
Images: 21
Jim,
Well, thank you very much!! Though I don't speak that lingo, my good friend and welder probably does. And I'm very interested in the documentation you have.
Though I'm deeply into fifties, I do no longer have a fax..., could you email instead? I'll PM you my address if so.
The Netherlands
my pictures
Old 09-20-2007, 08:37 PM   #12
Images: 59
I'll try to get them scanned tommorrow, PM me your email.
Old 09-20-2007, 08:56 PM   #13
JimHoek's Avatar
1959 18' Traveler
Images: 21
Very much appreciated!
PM me your email.
And done.
The Netherlands
my pictures
Old 10-04-2007, 12:05 PM   #14
JimHoek's Avatar
1959 18' Traveler
Images: 21
I think I just found the perfect hitch...
Australisch stel overleeft nachtmerrie
And you can learn a little Dutch Too!
The Netherlands
my pictures
Need 1969 front passenger window CJ of Okla Windows & Screens 4 07-03-2008 11:07 PM
Car Will Not Fit On Car Dolly! Chaplain Kent General Motorhome Topics 7 11-08-2006 04:46 PM
Passenger window leak '98 Landyacht Bkcat Airstream Motorhome Forums 2 03-23-2004 11:17 AM
Driver/passenger legroom/Argosy MH? pepepepe Airstream Motorhome Forums 4 01-01-2003 06:24 PM
tow hitch height using a 1960s car oldvws Hitches, Couplers & Balls 15 11-27-2002 03:43 PM
