Old 07-19-2008, 02:42 PM   #1
IggyWalker's Avatar
2014 30' FB FC Bunk
1986 25' Sovereign
1968 30' Sovereign
Vestavia , Alabama
hitch for 07 suburban and 25' sovereign??
We recently purchased a 1987 25' sovereign and a 2007 Chevy Suburban 4 WD 3/4 ton. Does anyone have a similar setup or suggestion for the best weight distributing hitch and aniti-sway device? I have been looking at the Reese dual cam and the Equalizer hitch. W/D hitches are totally new to me so I am unsure how to select one.
The TV has the factory tow package and hitch rated for 10,000 lbs with 1000 lbs max tounge weight for a weight distributing hitch. (The actual tow rating is 9400 lbs.)
Our Airstream has a GVWR of 6800 lbs. (I think)
The hitch receiver in the suburban is quite high (appx 22-23 inches from the ground to the top of the box).
I assume we will need a drop bar to lower the hitch ball, but how much?
Unfortunately the Airstream is at a relatives house four hours away and parked on uneven ground. I did not think to measure the height of the coupler when we bought it.
Thanks in advance,
IggyWalker
IggyWalker is offline   Reply With Quote
Old 07-19-2008, 02:47 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Yes and yes.
Originally Posted by IggyWalker View Post
We recently purchased a 1987 25' sovereign and a 2007 Chevy Suburban 4 WD 3/4 ton. Does anyone have a similar setup or suggestion for the best weight distributing hitch and aniti-sway device? ...
Reese dual-cam with 500 lb spring bars.
Read this thread:
http://www.airforums.com/forums/f381...not-13393.html
Tom
Old 07-19-2008, 02:54 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We pull an '05 25FB with an '05 Suburban 2500 Quadrasteer. We have have logged over 30,000 miles with this combo. At the beginning we decided to bite the bullet and go with the Hensley Arrow. It works as advertised. We have never had ANY sway whatsoever.
SuEllyn & Brian McCabe
Old 07-19-2008, 03:09 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Your GVWR of 6800 lbs. is correct. It is the same on my '86 Sovereign 25'.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-19-2008, 04:06 PM   #5
IggyWalker's Avatar
2014 30' FB FC Bunk
1986 25' Sovereign
1968 30' Sovereign
Vestavia , Alabama
spring bars
Thanks for the link Tom- I'll have to read through that thread twice. (or more) I did not realize the spring bars should be sized down due to our stiffer suspension.
Old 07-19-2008, 04:19 PM   #6
IggyWalker's Avatar
2014 30' FB FC Bunk
1986 25' Sovereign
1968 30' Sovereign
Vestavia , Alabama
Hensley Arrow
Moosetags-
Are you using a factory hitch receiver on your suburban? I did not look at the previous body style of suburans so do not know if the hitch receiver height is different.
Does the Hensley arrow adjust vertically or do they make a drop bar? I could not tell from their website. I do like the way the Hensley stays on the trailer when unhitched. I'll do a forum search as well-
Thanks, IggyWalker
Old 07-19-2008, 04:29 PM   #7
moosetags's Avatar
Moosetags-
Thanks, IggyWalker
I replaced the OEM receiver on my '05 Suburban 2500 after I detected cracks in the welds. I replaced it with a Class IV receiver. The pre-07 Sub's receiver height is probably lower than the 07/08.
The Hensley uses a hitch bar with a drop. I use a 6". The new Subs would probably take at least an 8".
Brian
'85 Sovereign 25' j54mark 1984 - 1989 Sovereign 13 11-07-2013 11:24 AM
new member - 25' Sovereign hcamper Member Introductions 8 04-14-2008 08:43 PM
Suburban hitch replacement install question davesamuelso Hitches, Couplers & Balls 0 10-17-2007 10:38 AM
Hitch height '85 sovereign, 25' jessl Hitches, Couplers & Balls 5 01-15-2006 02:23 PM
Suburban and Sovereign Craftsman Tow Vehicles 8 08-14-2004 04:09 PM
