10-27-2007, 07:32 PM
#61
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
GM hitchs
2007 Suburban hitch view from left rear. The square welded face you see
in the center of the main tube is the female portion of the reciever, it is also
bracketed and welded on the front side. Also at least 10lbs heavier, much
more substantial unit.
2007 2500HD look and decide.....
01-11-2012, 05:06 AM
#62
2007 31' Classic
Kansas City
, Missouri
Here's a look at the '12 Sierra 2500 HD hitch. It looks like it's beefed up over earlier versions. This one's installed on a Denali with a $62,000 sticker which I'll buy when I hit the PowerBall.
01-11-2012, 05:17 AM
#63
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Haven't seen the new models,(retired last year), but it sure looks like they have made some up-grades. I see the triangle brackets on the hitch head and it looks like the box has been welded all the way around.
Next time I'm at the store I'll check the backside, see if it carries thru there.
08-07-2012, 07:33 PM
#64
2006 30' Classic
Yonkers
, New York
Went through this post and I didn't get answer/s to my recent tow hitch separation: "NEED HELP"
I hitched my 31' classic with the tow hitch pin & clip perfectly installed ( Hensley Hitch) and travelled 100 miles to my destination. As I was trying to park my rig at my final destination (after going through a lot of hills, slopes and twisties) my AS got seperated from my TV. With luck on my side, no damage or injury but very scary. I found the hitch pin right underneath my AS but could not find the clip that holds the pin in place under the bumper. My hensley bars & stinger on the ground, safety chains in place and safety brake cable in place on the bumper not yet activated.
Can someone please explain what could have caused the clip to break and the pin to come out of the hole. Thanks.
TV = 2012 GMC HD Diesel
AS = 2006 Classic
08-07-2012, 07:43 PM
#65
Retired.
, At Large
AS = 2006 Classic
A guess based on previous experience is one of the hooks for the safety chain caught the clip and pulled it off the pin when you went around a tight corner or "twistie". When you backed up, it removed the tension that was holding the pin in place.
I use and recommend a locking pin that has no protrusions, so it can't get caught on anything.
08-07-2012, 08:23 PM
#66
2006 30' Classic
Yonkers
, New York
Terry,
Thanks for the quick response, will adopt your recommendation.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Hitch height
Chuck |
Hitches, Couplers & Balls |
20 |
04-09-2016 10:21 PM |
Hensley Arrow Hitch
Les |
116 |
12-14-2015 07:41 AM |
Hitch problem
wyhjr |
8 |
07-22-2002 05:29 PM |
Hitch inspections
83Excella |
3 |
07-09-2002 03:05 PM |
Handy hitch step
Pahaska |
Our Community |
0 |
06-26-2002 05:44 PM |
