Old 05-14-2015, 06:23 AM   #15
Gainesville , Florida
Good insight, thanks. Jim
Old 05-14-2015, 08:52 AM   #16
HowieE's Avatar
Princeton , New Jersey
Images: 12
avionstream
It appears our differences with regard to sway control hinges on the term BARS.
I now believe that what you are referring to is the Curt Sway control or an equivalent. Is this in fact what you are referring to?
http://www.carid.com/curt/sway-contr...mpn-17200.html
If so. Yes this device does not require WD BARS and will act without them
2004 Excursion 4x4
Old 05-14-2015, 08:58 AM   #17
Yup, same thing that's been used for over forty years. Ultra must be a brand name.. I've used Reese and eazlift over the years. Very common. Jim
Sewer Solution Extension Question Jfuller678 Waste Systems, Tanks & Totes 6 12-02-2014 03:56 AM
Hitch Chain Extension bkervaski Towing, Tow Vehicles & Hitches 1 06-07-2013 03:31 PM
Hitch Extension???? Drathaar Hitches, Couplers & Balls 16 09-16-2009 09:28 PM
Hitch extension Phil Gobie Hitches, Couplers & Balls 26 12-05-2006 02:54 PM
What is the gray 7 3/4" long extension Kistler Our Community 11 12-10-2002 08:40 AM
