Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 08-12-2004, 08:34 PM   #1
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Hitch bar drop size for 3/4 ton trucks
Now that I've mostly retired the Impala SS as my primary tow vehicle, I've been working on the fact that the 3/4 ton Suburban is significantly higher than the car was.....so now I've been playing with the hitch bar heights. I have what looks like a Reese 54970 and I was wondering what size hitch bar you folks that have 3/4 tons are using.
The 54970 has a drop of about 1.25 inches which still seems a bit high. I was thinking of getting a hitch bar that can go further down as I don't anticipate the 3/4 ton truck's rear dropping as significantly (without weight bars) as the car did even with cargo coils.
Old 08-12-2004, 08:51 PM   #2
jimmickle
jimmickle's Avatar
Profile:  Marion , Iowa
Suggest that you take a look at the Reese web site www.reeseprod.com. They have complete directions for proper hitch setup for download. With this in hand, you can measure and determine what drop you need.
jimmickle is offline   Reply With Quote
Old 08-12-2004, 09:00 PM   #3
Silvertwinkie
Aluminut
I've seen the site...actually www.reesehitch.com had better info mostly cause it didn't just throw the numbers at you IMHO. I am most curious though what folks that have 3/4 ton trucks are actually using.
Old 08-12-2004, 09:13 PM   #4
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
i have a hitch drop bar i used with my 97 2500 available.
shipping will be a bear as it is heavy. new it was i think $100. if interested let me know.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
wb13798 is offline   Reply With Quote
Old 08-12-2004, 09:48 PM   #5
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Reese R54995
I started with the R54932 on my 2500hd. It is a 14" bar with 1" drop, 5 3/4" rise and total adjustment of 6 3/4". It was just not enough drop for my '77 Excella 500.
I purchased the R54995, a 14" bar which added 3" to both the rise and drop over the R54932. It now has 4" drop and 8 3/4" rise. The bottom bolt of the ball platform sits in the next to last hole and it works out perfectly.
There is a R54917, a 14" bar, 6"drop, 10 1/4 rise with 16 1/4" total adjustment
Go to www.hitchfinder.com to look up the drawbars under Reese weight distribution and you will see a bunch of the bars listed with all the specs.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-12-2004, 11:59 PM   #6
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings Eric!
I have been running the Reese #54917 for a number of years with my Overlander/Suburban combination (and before that with my '95 K1500-Z-71 Chevrolet Club Cab pickup) - - it takes the maximum drop setting with the ball mount on the lowest setting possible. With the later model coaches, the ball mount may not need to be on the lowest setting as my '64 Overlander needed a hitch height of 18" due to its well-worn axles. If your Suburban is not 4WD, the #54917 may provide too much drop.
Good luck with your drawbar research!
Kevin
Kevin D. Allen
AIR #827
Old 08-13-2004, 12:35 AM   #7
66Overlander
66Overlander's Avatar
Profile:  1955 22' Safari
1994 28' Excella
Oakland County , Michigan
Images: 11
It may not be an exact comparison, but the Hummer H2 qualifies as a 3/4 ton vehicle. However, it may have a slightly higher hitch receiver than other 4WD 3/4 ton vehicles (25" to the top of the receiver box). 2WD's would probably have a lower receiver height than 4WD's, so you'll have to take that into account when people respond.
Anyway, in my case, I'm using the Reese 54990 6" drop "long shank" on the lowest (6" drop) setting. The trailer still tows about an inch high because the air suspension levels the vehicle as soon as I start the engine and the trailer axles have probably settled a bit in 38 years.
Were it not for the air suspension, I could probably tow level and might have to go up a notch because the hitch does sag quite a bit when I hook up before the air suspension does it's thing (of couse the springs on the non-air suspension models are probably stiffer). I should note that the '66 Overlander has a higher "spec" ball height (20.5") than the newer Airstreams, even though I suspect the trailer is riding a bit low on the old axles. New axles (some day - maybe next year?) may get it all leveled up, too.
As for having the long shank (16" vs. 14" for the standard Reese shank), it came down to what the hitch dealer had "on the shelf" when I needed a hitch. With the very short rear overhang on the Hummer this has not been an issue, but on other vehicles with a longer overhang, the standard length shank (54917) would probably be the way to go. In my case, I can open the liftgate with the trailer attached with about 6" clearance to the tongue jack, so I woud have been fine even with the standard length shank from that aspect.
Joe
66Overlander is offline   Reply With Quote
Old 08-13-2004, 08:33 AM   #8
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
I bought davids old R54932 because the drop bar I had was too much for my 88 3/4 2wd Suburban.
I also have what I think is a R54917 It should work on what I hope will be my next tow rig a few years.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-14-2004, 09:57 PM   #9
davidz71
davidz71's Avatar
Smile 54932 vs. 54995
Maybe this might help:
With the platform set at the lowest position on the 54932 drawbar, heigth from the ground to the top of my ball was 22 1/4". The distance from the ground to the top opening of my receiver was 17 1/4" so I guess the bottom distance is around 2" less. I needed a drawbar that would extend the platform 2 1/2" lower to get a 19 3/4" ball hitch heigth. The 54932 had only 6 mounting holes down the bar so it just wasn't right.
The 54995 has 10 holes and allowed me to drop the platform 2 1/2" with one mounting hole left for 1" further drop if I needed it. This again is with an '01 Chevy 2500hd with 8.1, Allison trans and stock Firestone Steeltex 245-75-16 tires. Hope this helps.
Craig
AIR #0078
3.73 rear end
Old 08-15-2004, 12:21 AM   #10
Silvertwinkie
Aluminut
Have I said that I love this place lately?
Thanks all for the great input.
Old 08-15-2004, 12:09 PM   #11
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Here's what I am using with the OEM hitch receiver. In the pictured position it is set up for a horse trailer.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 08-15-2004, 12:13 PM   #12
davidz71
davidz71's Avatar
Picture of the 54995 as set up with my Excella 500.
http://www.airforums.com/forum...ad.php?t=11168
Craig
AIR #0078
3.73 rear end
Old 08-15-2004, 12:20 PM   #13
davidz71
davidz71's Avatar
Picure of the 2 bars next to each other.
http://www.airforums.com/forum...ead.php?t=4024
Craig
AIR #0078
3.73 rear end
Old 08-15-2004, 01:10 PM   #14
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
can you tell who has a new toy?
must be down to two posts a week! ha ha!!
john
you call them ferrets, i call them weasels.
Hitch Ball size for 1971 31' Sovereign? westeagle Hitches 2 12-07-2003 12:04 PM
New hitch bar needed? cactushead 2003 International CCD 9 07-20-2003 03:47 PM
Reese hitch bar davidz71 Parts Archive 2 04-16-2003 07:52 PM
Reese R54995 hitch bar davidz71 Hitches 0 03-17-2003 11:16 PM
Replacement Reese hitch bar davidz71 Hitches 11 02-20-2003 05:22 PM
