Old 04-28-2009, 07:02 PM   #1
Cape coral, , Florida
Hitch ball size
Just bought a 1976 AS international 31 ft. I need to know what size hitch ball I need to tow it home. Brand new to all this...thanks for all the help...I've read a lot of threads and hope I can acomplish it all. Kinda scarry...Thanks
KMLAWS is offline   Reply With Quote
Old 04-28-2009, 07:12 PM   #2
Kevin245's Avatar
Welcome...should be 2-5/16". Make sure you have a load equalizer hitch, brake controller and an adequate tow vehicle.
Good Luck,
Kevin
Eleanor Roosevelt
Old 04-29-2009, 12:34 AM   #3
Whitefish , Montana
Would the 2 - 5/16 ball be the same for a Argosy 26 ft ?
Bubbarosa1 is offline   Reply With Quote
Old 04-29-2009, 12:39 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums.
Yes, it would be the same, unless somebody has hacked the old one off, and welded a different one in its place.
Old 04-29-2009, 04:16 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
a 1963 Overlander uses a 2 inch ball. My 77 Sovereign uses a 2 5/16".
Old 04-29-2009, 06:55 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
The switch to 2 5/16" was made about 1969. Be sure and get one with a 10,000 pound rated shank.
5 meter Langford Nahanni
Old 04-29-2009, 07:09 AM   #7
Well Preserved
1993 21' Sovereign
Many 1969 models had the 2", the switch seems to have been made late in the model year.
Old 04-29-2009, 07:12 AM   #8
Thanks Terry. overlander64 could have told me but overlander63 is poured from the same mold. Figures, eh?
Old 04-29-2009, 09:33 AM   #9
Whitefish , Montana
Thanks for the Welcome and info.
1968 Land Yacht hitch ball size intow Hitches, Couplers & Balls 5 08-11-2007 09:28 PM
Hitch ball size Argosy27 Hitches, Couplers & Balls 1 05-23-2006 05:53 PM
Ball hitch size schaumannk Hitches, Couplers & Balls 8 12-01-2004 07:31 AM
Hitch Ball Size mopar7 2003 Safari 1 01-22-2004 04:56 PM
Hitch Ball size for 1971 31' Sovereign? westeagle Hitches, Couplers & Balls 2 12-07-2003 11:04 AM
