Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 10-03-2005, 07:17 PM   #1
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
Hitch Ball Rating
I just bought a 2-5/16'' stainless steel ball. As I was about to remove the old rusty ball I noticed it had a 10000# rating stamped on it, the new S.S. ball is only rated for 6000# (also stamped on it). I guess I never paid attention to this before but is it possible that a stainless ball is weaker than a regular steel ball of the same size? I checked the web-site for the new ball & it confirms the 6000# rating. BTW: My trailer sits 5600# m.t. & around 7800# gross...
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Old 10-03-2005, 07:19 PM   #2
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
RivetED,
Do both trailer balls have the same size shank? If not that will make a difference in the rating.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 10-03-2005, 07:23 PM   #3
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
The 10,000 pound balls have a larger shank than the 6,000 pound balls.
The above doesn't look quite right, but I am not sure how to change it.
You repair things with tools. You fix things with a hammer.
AIR#2611
overlander63 is online now   Reply With Quote
Old 10-03-2005, 07:30 PM   #4
RivetED's Avatar
Hillsboro , Texas
I'm sure no dual meaning was implied
The new one is 1'', the one on the hitch looks like it may be 1-1/8 to 1-1/4'', not sure, I didn't take it off but it looks to be just more than one inch to the outside of the threads.
Old 10-03-2005, 07:32 PM   #5
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Talking
Ed,
If your GVW is 7800# you really should get the heavier duty ball, given the cost involved ...or like Terry indicated...get bigger ball(s)
Aaron
WBCCI #2449 AIR #2495
Old 10-03-2005, 07:40 PM   #6
Images: 52
Okay, I guess I'll go there, this time... You need a bigger ball.
AIR#2611
Old 10-03-2005, 07:41 PM   #7
RivetED's Avatar
Hillsboro , Texas
I should have realized this topic could have a certain overtone that can't be ignored!! I been looking for a stainless ball for over a year and just assumed the shank size was the same on any given size ball. I'll just have to keep on looking, the manufacturer, Highland, does not list a 10000# rated ball of any kind.
Old 10-03-2005, 07:54 PM   #8
2airishuman's Avatar
Profile:
yes it's possible and often the case.....while stainless is less corrosive, depending on the grade of stainless it can be weaker at the same diameter as many other grades of steel.
there are some informative websites on stainless steel, the many grades and properties....often they inlcude tables that compare stainless to the many other grades of steel.
cheers
2air'
Old 10-03-2005, 07:59 PM   #9
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Ed,
After the thread the other day we couldn't help it
Here is a link to help you out www.qmctechnologies.com/hitchballs/item7.htm
Also try www.hitchesonline.com
Hope it helps you out...
Aaron
Pingbacks are On
Hitch size Jim Sease On The Road... 10 11-04-2002 10:38 AM
Hitch problem wyhjr Hitches 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches 3 07-09-2002 03:05 PM
Hitch height Chuck Hitches 9 06-09-2002 10:32 AM
Old CB ball mount davidz71 Phone, CB & Ham Radio 2 05-28-2002 06:54 PM
SEO by vBSEO 3.1.0
