Old 03-22-2015, 11:03 PM   #1
1Boyscout's Avatar
2015 28' International
Edmond , Oklahoma
Question Hitch Ball Play
how much give, slack, or moving should there be once the coupler is latched on the ball.?
I have a new 28'AS, and an equalizer hitch 10K lb. it was installed at the dealer. l have towed more than 30 yrs and never had this much movement of the ball inside the coupler.
1Boyscout is offline   Reply With Quote
Old 03-22-2015, 11:15 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, none; I have had it happen twice where the ball wasn't down all of the way and coupler latch wasn't completely latched. It caused some bumping. Now, even though the latch handle goes down enough to install the lock/pin, it's not proper unless the front of the latch lever is sitting flat against the top of the coupler housing. When not latched properly, the latch lever sits up above the coupler housing only a fraction of an inch.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-23-2015, 05:29 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Zero. My guess is you are coupled up incorrectly OR the dealer put on the wrong sized ball.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-23-2015, 10:05 AM   #4
1Boyscout's Avatar
Edmond , Oklahoma
hhitch ball
It is 2 5/16. The coupler lever goes all the way down, flat on the coupler .
I will tighten the nut before next hook up. I have another ball, it measures the same diameter,
from my old weight distributioon Reese hitch.
I never had sway problems with the Reese WD hitch and a sway bar. The Equalizer hitch has a different feel going down the road. I used a WD hitch over 25 yrs. I have had 2-- 34' TTs
Thanks for all the feedback.
MSG MAD HATTER
Old 03-23-2015, 10:10 AM   #5
Gainesville , Florida
Is it stinger play when inserted into the receiver? Jim
Old 03-23-2015, 10:14 AM   #6
1Boyscout's Avatar
Edmond , Oklahoma
What do you mean stinger play?
Old 03-23-2015, 10:27 AM   #7
When the hitchhead is inserted into the receiver sometimes there is play. There is a ubracket to buy which helps to eliminate the play. This play varies depending on the hitch and tow vehicle. Jim.
Old 03-23-2015, 10:33 AM   #8
1Boyscout's Avatar
Edmond , Oklahoma
Old 03-23-2015, 10:45 AM   #9
r carl's Avatar
Lin , Ne
Old 03-23-2015, 10:50 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I posed this question a couple years ago.
I get about 3/16-1/4" of play on our 1999 Excella hitch with a ball inserted by itself. When I insert the ProPride, the ball is pre-mounted, same size as I tested with, there is slack.
I replaced the "coupler latch" thinking it was "worn"... Nope. Same exact feel.
I can't pull the ball out of the hitch coupler. I have even jacked the trailer and it lifts the truck stern end... But there is that movement!
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-20-2015, 07:29 AM   #11
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Am I correct in assuming that the correct hitch ball size for the equalizer hitch is 2 5/16". I'm in the process of ordering the 10K equalizer online & the ball is sold seperate.
Mrjkq is offline   Reply With Quote
Hitch Ball Alignment mnikisher Hitches, Couplers & Balls 39 08-09-2005 02:29 PM
Help-Hitch Ball problem Chitown AirStreamers Hitches, Couplers & Balls 4 07-22-2003 12:35 AM
Hitch ball height... drboyd Hitches, Couplers & Balls 2 06-30-2003 05:29 AM
Hitch ball lubrication Kistler Our Community 9 05-12-2003 12:48 PM
Hitch ball torque APB Hitches, Couplers & Balls 2 02-24-2003 05:13 AM
