Old 03-12-2012, 08:24 PM   #1
mefly2's Avatar
2015 25' FB Eddie Bauer
HItch ball height via AS and via Leveling
Another try on this subject ...
I was just a bit unsure of myself with the ~3" disparity between what the AS factory (and owner manual) says the hitch ball height should be (17.75") and what I actually need by leveling the trailer fore and aft and then measuring the distance from the cement ground to the inside of the coupler (20.5-.75").
If you are using the AS factory recommendation of 17.75", I'd really like to hear your experiences. I do not have self-leveling suspension and am concerned that AS would provide a specification that is that far off of my own experience.
Old 03-12-2012, 10:44 PM   #2
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
The trailer won't be perfectly level it it's spec'd towing alignment.
Friday is offline   Reply With Quote
Old 03-13-2012, 06:21 AM   #3
dznf0g's Avatar
Oswego , Illinois
I've yet to hear of two AS'es which sit at the same height...well OK that's an exageration, but.... My Classic is spec'ed at 18.75" in the book. Fully loaded with about 1200 lbs over the UVW, it sits at 19" from top of coupler to ground. So it too was born higher than "spec". (BTW, that was BEFORE switching to 16" wheels, so it's really at about 19.5" now)
I think the point here, is for you to load up the gal like you're going camping, with proper tire inflation, level the AS front to back, and get your particular unit's height from top of coupler to ground. Then work your hitch and TV numbers. (Don't forget to simulate your typical loaded vehicle weight).
As a starting point, I have found that setting the ball height about 1" above the coupler height is typically close. You'll then have to dial it in.
There are plenty of folks here that can help with that once you get the basics done.
-Rich-
Old 03-13-2012, 06:34 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up what dz said....
X2
"I was just a bit unsure of myself with the ~3" disparity between what the AS factory (and owner manual) says the hitch ball height should be."
The operative word there being "should". As with the factory weights, consider all AS numbers as suspect.
Load the trailer, level it, measure from ground to inside top of ball socket=real world TH.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-13-2012, 01:15 PM   #5
mefly2's Avatar
Thank you for the input; your experience shared with us is very much appreciated. I just wanted confirmation that what I have done is the proper procedure ... still hard to believe that AS puts out a spec that far off the mark.
Old 03-13-2012, 01:56 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
mefly2, Don't feel bad. Mine specs at 18 inches, current real world is about 13. It is 48 years old so of course my axle is shot. New one has been on order for 6 weeks, hopefully will show up sometime this month.
MICHAEL
Belly skin and Banana Wrap Alloy perryg114 Belly Pans & Banana Wraps 16 03-03-2014 05:12 AM
Apparent Hitch height disparity ??? mefly2 Hitches, Couplers & Balls 27 03-15-2012 03:38 PM
It's Monday and I love my Airstream because..... THEPILL Off Topic Forum 4 03-12-2012 11:10 PM
Help! On the road and fridge isn't cooling AirEPotter General Repair Forum 8 03-12-2012 06:22 PM
PINK, VINTAGE and READY! 1967 Concession Airstream Trailer eBay Watch Airstreams on eBay 0 03-12-2012 02:40 PM
