Old 09-27-2007, 05:09 PM   #29
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
OK, here is my thoughts. If the ball is too high, and assuming that the weight of the trailer hitch lowers the trailer down enough to allow the trailer to be level, the entire hitch weight is borne by the rear wheels of the tow vehicle and the receiver. Technically that's a dead weight drop on the hitch. Most receivers and hitches are rated 2 ways. Once when used as a dead weight drop and used in weight distribution mode. Typical dead weight limits are 50% less than using the hitch in a distribution mode.
So let's take this a step further, why wouldn't we in our wisdom always have the hitch ball higher than necessary so that we wouldn't have to use weight distribution? Especially when the truck is rated to carry that weight?
Well first you have to realize that using a hitch in a weight distribution mode uses all of the suspension components in both the tow vehicle and trailer to carry the hitch weight. That makes both vehicles ride better and takes the stress off that rear axle of the tow vehicle when road issues occur. It would seem to me that more rear TV wheel road shock would be transmitted to the trailer due to a dead weight load. Secondly I think brake performance would be impacted in a dead weight situation since you could induce wheel lock earlier in the front brakes of the TV and trailer brakes since these wheels are carrying less load. Again the additional weight on the rear tires will probably accelerate some wear on the TV rear wheels. Less weight on the trailer wheels and front wheels of the tow vehicle provides less friction which may cause a decrease in traction overall.
I'm sure there are some other things I haven't thought of but that logically seems to be some of the issues that come up when you are using the dead weight concept rather than using the weight distribution hitch. In the case of having the hitch ball too high, even if you use the WD hitch, you aren't effectively transferring the load so that rear axle of the TV is still carrying more weight than necessary.
Is this a little more of what you were looking for Steve?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-27-2007, 07:16 PM   #30
SteveH's Avatar
Common Sense , Texas
A picture is worth a thousand posts.
OK, here is a snap shot I took of the outfit on my way home from Tucson. Does it really look that dangerous to you?
Old 09-27-2007, 07:34 PM   #31
proof
The truck scale "is the proof."
What it looks like is one thing, that can be misleading for a number of ways.
The truck scale is the positive, final answer.
Old 09-27-2007, 07:47 PM   #32
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Judging from your picture, the setup looks actually pretty close to where it should be.
But, like Andy said, a truck scale will tell much more. Or, if you want the answers right quick, use the tried and true tape measure method. Do a search, there's many posts on this already.
Uwe
www.area63productions.com
Old 10-02-2007, 07:39 PM   #33
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I just came across this thread,and I saw the discussion ,so I went out and inserted the Reese Strait-line that I have had for 10yrs an never used,I find the ball height is 21-1/2 inches.This is on a 1 ton SW F350. I may be in trouble .What shall I do. Still lookin for a trailer!
Thanks for all Your input Andy
Roger
Mikethefixit is offline   Reply With Quote
Ball Height Question Steve Heywood Hitches, Couplers & Balls 77 09-23-2007 04:53 PM
Ball Height ?? Alden Miller Hitches, Couplers & Balls 7 04-10-2006 10:07 PM
Specified ball height wacnstac Hitches, Couplers & Balls 15 04-02-2006 08:04 PM
Hitch Ball Height RivetED Hitches, Couplers & Balls 4 03-21-2004 08:25 PM
Hitch ball height... drboyd Hitches, Couplers & Balls 2 06-30-2003 05:29 AM
