Old 05-15-2003, 08:26 PM   #1
working's Avatar
1967 22' Safari
athens , West Virginia
Rivet Hitch angle?
What's the logic behind the adjustment of the hitch head angle? I read that it should/could be angled up to 15 degrees from plumb, that this helps with sway. What works for you folks?
working is offline   Reply With Quote
Old 05-16-2003, 07:04 AM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: Hitch angle?
Think about the angle of the leveling bars and the piviot point. by having some downward angle the bars on either side of the A of the tounge are going to both want to swing out so that the tip of the leveling bar is seaking a high point. With them on either side of the hitch they are always working against each other to find that high point and settle at a center point. This in turn helps keep the trailer sway down. As one bar is seaking high a high point the other is being pulled to a lower point.
The weak link in this being very effective is the chain (pun intended ). One brand of hitch has a solid link instead of the chain and it is well reguarded as a stable set up. I think it is "Equalizer" brand?
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-16-2003, 07:33 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Hitch Head Angle?
Greetings Working!
I have an approximate 3 degree angle on the hitch heads for both my '78 Argosy Minuet 6.0 Metre, and my '64 Overlander International. The dealer who setup my hitch originally (not familiar with Airstreams) did not angle the hitch head at all - - the trailer didn't track as smoothly as it does now with the 3 degree angle (toward the trailer). I know that there is a note in the owner's manual for my Overlander that mentions the best angle to be 1.5 degrees for the previous owner's '65 Mercury Monterey and 3 degrees for their 1975 Oldsmobile 98 Luxury Sedan. I don't know that I have ever seen a specific factory recommendation for this adjustment.
Kevin
Kevin D. Allen
AIR #827
How to choose a shock-absorbing Hitch ? femuse Hitches, Couplers & Balls 16 06-05-2011 07:46 AM
Hitch angle? Krazykraut General Motorhome Topics 2 07-01-2004 03:53 PM
Hitch Rating DaveJ Airstream Motorhome Forums 4 09-18-2003 08:29 PM
Interesting Reese hitch experience... 85MH325 Hitches, Couplers & Balls 25 07-30-2003 06:00 AM
Need HITCH help on a 59 59toaster Hitches, Couplers & Balls 3 02-14-2003 11:13 PM
