Old 12-28-2007, 08:28 PM   #1
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Hitch and receiver rattle
Well...I finally ready to fix the space in which the reciever into the hitch is just a tad to small and it rattles when driving or gives a thunk when I take off.What solutions have you all done to fix this.I have heard all kinds of things but they are all not a permanent solution.I have found 1 though but do you all think this could hold up over time with this much force.Thanks All.
The Hitch Corner sells Draw-Tite trailer hitch accessories
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 12-28-2007, 08:41 PM   #2
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
That's the first thought I had also when I saw this. How well will it hold up under weight distributing loads? I haven't ever seen one but it looks like an innovative fix. Not that xpensive to try out either.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 12-28-2007, 09:09 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I don't have a hitch rattling problem, but what you have pictured, in my opinion, would only work if you drive around with the hitch in the receiver without your trailer attached. I don't think it would be strong enough to hold things in place with a real load on it. [trailer and WD hitch installed] I had thought of makeing and useing a thin metal wedge that you can tap in place either on the top or bottom of the receiver.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-29-2007, 06:30 AM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
That does not look like it will work very well under any load. You hitch pin is likely worn or too small.
Michelle TAC MT-0
Sarah, Snowball
Old 12-29-2007, 06:57 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I have some slop in the receiver/head also. Part of it is the brand of receiver and head you use, some have closer tolerances. Part of it is wear, also. If you have lots of time to mess with it, you can make a nylon/teflon pad for the head to ride on, it should hold up pretty well.
The head moves in the receiver on ours as well, but the only time I hear a "clunk" is when I walk into it ...ouch.
Old 12-29-2007, 04:52 PM   #6
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
I had one hitch head that had the same problem you had. I ran a small bead of weld on the bottom, one on each side of the bottom. Then test fit it and used the grinder judiciously until it slid in tightly but was still removable without hurting myself trying.
As Michelle has noted it could also be a too loose pin. I've found that going to the RV Parts store and trying their hitch pins until I found one that was just slightly tighter fit than mine stopped an annoying rattle on one hh.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 12-30-2007, 04:18 PM   #7
Devoman's Avatar
Pin
I have only tried a couple pins but I think you and michelle are right about that.The only thing I would have to fix then is the up and down movement of the hitch to make it completly solid.I think I am going to talk to a friend of mine who welds and see what I can do about it here in the future.Thanks everyone.
Old 12-30-2007, 04:38 PM   #8
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Have you checked with VW? I have the same problem with my car and I bet it's the same receiver. Be interesting to see what you come up with.
Pop Rivet is offline   Reply With Quote
Old 02-16-2008, 10:19 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
If it's snug in that fitting, maybe it could be welded on...
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-14-2008, 08:28 PM   #10
2005 31' Classic
Gretna , Nebraska
Receiver slack
My receiver is only a year and a half old and I have a lot of slack in the connection. I have been considering some strips of sheet metal to be inserted along side the shank.
Has anyone tried that?
Also, I wonder if the receiver will continue to get more sloppy if nothing is done to stop the action.
The welding and grinding/fitting would be the best solution if done by a welder who protects the tempering of the steel.
Dwight
31' Classic/GMC 2500HD 6.0L
16595 is offline   Reply With Quote
Old 03-14-2008, 08:39 PM   #11
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
My 2007 Suburban requires a deep drop shank for the WD hitch. The receiver is so loose, that the bottom of the shank where the ball resides can swing back and forth over one inch in either direction. It is ridiculously loose. It clunks and wiggles like it's defective. It is not the hitch pin, in my case. It is simply a sloppy receiver tube. I haven't a clue what to do about it.
Uwe
www.area63productions.com
Old 03-14-2008, 09:02 PM   #12
Devoman's Avatar
Hitch
I am planning to try the weld line down the shaft on the top and side of it.I would think this would work but I have not tried it yet.I am still looking into a solutions.I would say though that mine wiggles around about 1/2 inch max but I think it is a tiny bit smaller than that.
Old 03-14-2008, 09:13 PM   #13
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Devo, BE CAREFUL welding directly on the vehicle. Disconnecting the vehicle ground line at the battery is not enough. All of the computers are tied into ground as well. It can get expensive quickly.
Find someone that has experience with welding on european vehicles.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 03-14-2008, 09:19 PM   #14
safari57's Avatar
1960 24' Tradewind
West Coast , BC
The weld down the top and side does work, we've done it with no issues.
The other question is to have a good look at the receiver as well to make sure that it's not cracked. I've seen this a few times. If you need more info let me know.
Barry
Barry & Donna
Receiver Hitch pin hole repair ? Davis Hitches, Couplers & Balls 17 06-15-2017 06:03 PM
Hitch receiver plaques rangebowdrie Off Topic Forum 10 11-30-2007 02:48 PM
Receiver Hitch Bolts Davis Hitches, Couplers & Balls 2 08-04-2006 09:06 AM
Brake rattle kabila Brakes & Brake Controllers 1 06-16-2005 08:44 PM
plumbing rattle/'99 Safari Antique Pedaler Water Heaters, Filters & Pumps 6 02-07-2003 05:54 PM
