Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 06-18-2008, 05:25 PM   #43
SilverToy
Profile:  1992 34' Limited
Falls Church , Virginia
The latest....
Hello all -
Today I took about an hour and removed the 'old' Curt hitch and installed the 'new' Curt hitch. Actually quite glad that I did the work myself as I fould 2 under-torqued bolts. Actually scary to contemplate if I had not gone back and checked the work.... and with towing things might have loosened further.... and then....?!
Checked the 'new' receiver tube with all my attachment pieces and all is right with the world again. Mounting was fairly easy (good thing the 13 y/o is off school) with an assist needed for getting the hitch up and a few bolts tightened.
All torqued down and ready to roll. Tried the bike rack as that was what alerted me to the slop. There is very minor back and forth (as with the OEM) but nothing like the 8-10 degree back and forth with the 'old', now replaced, Curt.
Lessons? Contact the manufacturer of any unit that you have newly bought something that is not up to spec. Curt was very responsive. They have offered to pay for my install on the 2nd unit.
BTW, I will be alerting Curt of the sloppy install by the local distributor.... perhaps they can make an improvement there as well.
Again, Thanks for reading this far. I am glad that I did not have to go the route that some others here suggested with hitch, or receiver mods, clamps and the like. I want to the proper way that it should be. I have that now. Thanks Curt.
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 06-18-2008, 06:36 PM   #44
ROBERT CROSS
"The Frantic Banana"
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 41
Good News..
Glad all worked out well for you.
I've gotten into the habit of retorqueing the reciever mount bolts every Spring make-ready, after helping a fellow camper when three of his bolts failed as he was backing into his spot. Very lucky it didn't happen on the road.
Stream safe
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 07-02-2008, 09:33 AM   #45
hitchguy
Profile:  Eau Claire , Wisconsin
I would just like to state. That Curt Hitches as well as receiver tubes are not manufactured in China. The hitches are built in Eau Claire, WI. The receiver tube is built by a company in Michigan. When the receiver tubes come in they are sampled for size using a maximum and minimum check gauge. Sometimes one does make it through that is larger than normal. Often the issue with slop comes from the ballmount of whatever is being towed. All receiver tubes and ballmounts are not the same. If the ballmount or accessoryis made in a foreign country. Most likely the material is metric. Which has a different radius. If you stick a Curt Ballmount or accessory in one of our hitches and have the problems Axel experienced. We will gladly send you a replacement. You can be assured at Curt Manufacturing we listen to you as the customer, and will resolve the issue.
Shannon Engel
Quality Control
Curt Manufacturing
Eau Claire, WI
hitchguy is offline   Reply With Quote
Old 07-02-2008, 10:09 AM   #46
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Originally Posted by jbond View Post
Devoman
I have been using a device similar to what you first asked about and it will stop the rattle. Bought mine at Camping world and its a little different. Because of the way the new Suburban hitch is set into the bumper I had to grind on the device a little to make it fit.
Uwe
This also stops all the side to side movement so far. I towed several thousand miles with the new hitch & device. If this hadn''t worked I was going to have a welder adapt an older Reese hitch to mount underneath the current hitch at a more normal height. I contacted (reese)Cequent and they said they had no plans to make a receiver since all Suburbans come with the hitch aka known as the bumper.
I will take a look at one of these, but only after a dealer visit. I am hoping that GM will replace my hitch with a new, better fitting one.
I also have issues with the third row seats not locking into place, and a headliner that is falling down on one side over the cargo area.
Uwe
Old 07-02-2008, 10:20 AM   #47
Mikethefixit
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Your profile does not say what your TV is, But there was a recall on GM installed hitches. The welds were breaking and the tubes were sloppy. Check with your dealer. I cant even tell ya what brand those hitches were,cause Im not a GM person.
Mikethefixit is offline   Reply With Quote
Old 07-02-2008, 02:23 PM   #48
ROBERT CROSS
W.N.Y. , "
Images: 41
http://www.airforums.com/forums/f464...les-34603.html
Although retired I still work part time at a G.M. Store. Not aware of any recalls on G.M. recievers. We have replaced a number under 3/36 warranty for for the problems noted.
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Hitch receiver plaques rangebowdrie Off Topic Forum 10 11-30-2007 03:48 PM
Receiver Hitch Bolts Davis Hitches 2 08-04-2006 10:06 AM
Receiver Hitch pin hole repair ? Davis Hitches 1 07-15-2006 07:44 AM
Brake rattle kabila Brakes & Brake Controllers 1 06-16-2005 09:44 PM
plumbing rattle/'99 Safari Antique Pedaler Water Heaters, Filters & Pumps 6 02-07-2003 06:54 PM
