Old 10-28-2011, 09:04 AM   #15
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I usually travel one week per month for work. After fourteen years in the hotel, I decided to try a trailer this year
IMO, this choice is going to work out very well for you. Some tax advantages exist and the neighbors, the privacy and the comfort can't be beat.
Old 12-15-2011, 12:42 PM   #16
2008 22' Sport
Green Mountains , Vermont
Just to follow up...
I contacted Equal-i-zer support. They told me the 10,000# hitch and 1000# bars were fine for the 4000# trailer. Was told to be sure to adjust the WD properly. That was all.
I went ahead and ordered two 600# bars. They are smaller than the 1000# bars and leave a little more space for movement where they connect to the hitch. Hope this won't cause issues.
Took a 250 mile trip with the new setup. Seemed fine. Stiffer ride. More of the movement was transferred to the TV than before. Used to see the trailer sway a little in some situations. Now if it starts to sway, it stops almost instantly. Mileage dropped 2mpg.
nesvt is offline   Reply With Quote
Old 12-15-2011, 04:43 PM   #17
dznf0g's Avatar
Oswego , Illinois
I believe you will have to have sleeves made to fit the 600# bars in the 10,000# head. Actually, that would be great, we were talking about someone doing this on another thread. I am sure any good metal fab guy could make you sleeves for not much money.
We WILL of course expect pics and full feedback on how this works out. 600# bars in a 10,000# head is, IMHO, the only way to make an EQ work for me.
-Rich-
Old 12-16-2011, 04:50 PM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I am assuming that this is felt by the driver through the steering. My first step is TV tire pressures. Maintaining factory FF/RR balance and playing with a range. As before, no substitute for certified scale weights. Several reasons for "stiffer ride" come to mind.
Second is any slop in TV steering. R&P doesn't have much room for play, but the system should be examined while on the rack for play, loose mounts, etc.
Reduced mpg is possibly: colder weather, more start & stop, higher travel speed (with quartering headwinds the worst); brake drag, alignment and gasoline with higher ethanol content (winter gas). More steering corrections per 10-miles is cited by big truck makers as worthy of correction.
New owners of a 2008 Safari Sport 22' nesvt Member Introductions 7 10-03-2011 11:35 AM
New 2008 Safari Sport 22' nesvt Trailer Values 9 09-07-2011 07:25 PM
Lola :: 2008 Safari Sport leopattie Airstream Registry Discussions 0 08-19-2011 08:32 AM
Need advice on best hitch jetjocky Hitches, Couplers & Balls 15 08-05-2011 07:19 PM
Trailer Hitch for 2005 25' Safari basecamp1 Hitches, Couplers & Balls 7 03-28-2011 07:40 PM
