Old 03-15-2010, 03:21 PM   #1
2008 20' Safari SE
Alta , Utah
Hitch?
We are in the process of acquiring a 08 20' Safari. It weighs 5000# with a tongue weight of 600# and will be towed with a 2010 Tundra. Equalizer makes hitches with 6000/600 rating and 10,000/1,000 rating. We've gotten advice in both directions; the downside of the higher rated hitch being that the equalizer bars hang down further and decrease ground clearance. Both cost about the same. Any thoughts or advice?
rosie29 is offline   Reply With Quote
Old 03-15-2010, 04:26 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have a 07 20' Safari towed with a 06 Tundra (lighter load capacity than yours, but very comfortable ride).
Our dealer installed the 10,000/1,000 Equal-I-Zer correctly as instructed by the hitch mfg. On smooth highway it is fine, but on rough highway it rides terrible. Porpoising, pitching back and forth between vehicle trailer, extremely stiff. One rivet came undone inside and a/c vent covers and two light covers came off.
I loosened the weight distribution bars one bolt hole, the level of the truck still measured close to spec, and the next trip of 2,000 miles was smooth and steady, and the steering felt firm. I then returned it to original settings for safety concerns, even though I sensed no problems.
There is no way I would advise doing this however, because loosening the bars removes at least some steering control, and much more importantly, the extremely important sway control feature is compromised, maybe even lost! No way to know.
We love traveling with our 20' Safari, and safety is everything out on the open road. For that reason, after returning home, we will buy a ProPride hitch. Big dollars but worth it in emergency handling conditions.
My reasoning is its stellar handing characteristics, always knowing you have no trailer sway, and the ability to select and adjust the weight distribution bars to the tow vehicle you have, without concern for loosing sway control.
From the standpoint of towing capacity and payload, your trailer and new Tundra look like an excellent match, to me, others will disagree I'm sure. Some jealousy here of the new Tundra.
Old 03-25-2010, 06:15 AM   #3
SteveH's Avatar
Common Sense , Texas
I agree your Tundra and 20' Airstream are a good match. However, if you just MUST have an Equal-I-Zer hitch, I would suggest you get the lighter one. The ONLY down side to doing this is, if you later traded to a larger trailer, the hitch would be too small.
Over the years I've had many different types of friction sway control hitches, and they all worked....to a degree. Then last year I splurged and bought a ProPride. It is great..wish I had done it years ago. There is no camparison to an old technology friction device.
Regards,
Steve
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
What hitch should I be using? altamont Hitches, Couplers & Balls 12 07-17-2007 12:21 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
What do you think of your hitch? Blue Hitches, Couplers & Balls 1 01-24-2004 01:59 PM
