12-05-2014, 01:01 PM
beaufort
, South Carolina
hitch ?
Hi all
I have a Yukon Denali, do I need anything special to pull a 25' AS?
chas
12-05-2014, 01:16 PM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
You're going to be inundated with questions.
Simple answer is yes, you will need a weight distribution hitch with an anti sway bar.
Now, got prepared for more information that you ever thought you wanted. ;-)
12-05-2014, 01:17 PM
2012 25' FB International
Trent Woods
, North Carolina
Yeah, there are about a bezillion threads on that subject. Read about weight distribution and also read about sway control.
Larry
12-05-2014, 01:29 PM
2012 25' Flying Cloud
Battle Lake
You don't need anything special but if you want the most pleasant, safest towing experience possible get a sway elimination hitch. Only two manufacturers build them, Hensley and ProPride. ProPride is an updated version of the Hensley original, costs less, requires no drilling of frame to install, and is sold only direct from the builder to you or your installer.
This is based on our experience with conventional and ProPride hitches. The difference is remarkable.
Doug and Cheryl
12-05-2014, 02:02 PM
1986 31' Sovereign
Miami
No argument that Hensley and ProPride are superb hitches but they weigh several hundred pounds and I'm guessing that with a Denali pulling a 25' the OP might have a better use for that payload.
Reese Dual Cam, Blue Ox etc. all have their fans and all seem to do the job.
Mike
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
12-05-2014, 02:37 PM
Biloxi
, Mississippi
Ditto on the Blue Ox SwayPro. Lighter, cleaner, appreciably less expensive and totally eliminates sway. This is not a paid advertisement. Only a recommendation from a satisfied customer.
MICHAEL
12-05-2014, 02:59 PM
beaufort
, South Carolina
thanks guys....Im off to research
12-05-2014, 05:23 PM
2008 27' International FB
Venice
I have an 2005 Suburban 1500 Z71. I have been pulling my '85 Sovereign since 2009 and everything is good!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
12-08-2014, 06:58 AM
Vintage Kin
Fort Worth
This hitch is capable of ordinary antisway resistance and no more. The manufacturer recommends adding one -- even two -- additional friction controls for better performance.
Not at all the same as a Hensley or Pro Pride which are not dependent on tongue weight to control the trailer.
An enormous difference between the two designs.
12-08-2014, 07:11 AM
2013 30' Classic
Greenwood
, Mississippi
It depends on how deep your pockets are. I have had success with EazLift and Equal-i-zer, but if my pockets were deeper I would have a ProPride.
Do you have $400 or $2,300? That will lead you in the direction you need to go.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
12-08-2014, 07:19 AM
Vintage Kin
Fort Worth
The design of the BO looks good, granted. I'd rather have it over Equalizer. But used HA and PP are reasonable in price and are then an enormous bargain given performance.
12-08-2014, 07:22 AM
2013 30' Classic
Greenwood
, Mississippi
I have seen used Hensley and ProPride in the $750-$1,000 range, but shipping will eat you alive unless you are close enough to do the transaction in person. I don't even have that much. The OP might, though-
TAC #MS-10
Airforums #70955
12-08-2014, 07:26 AM
Vintage Kin
Fort Worth
I've seen them even lower. The point might be made that price needn't be an obstacle as the difference is two entirely different classes of hitch design.
12-08-2014, 07:29 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
In addition to a weight distribution/anti sway hitch system, you will also need to install a quality trailer brake controller in your Yukon. Without this, the brakes on your Airstream will not operate.
You will also need some type of trailer mirrors for your Yukon. The standard mirrors on your Yukon are not suitable for towing an Airstream.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
12-08-2014, 07:44 AM
Mantua
, Ohio
I believe the info in post number nine is incorrect. No addon sway devices are necessary for the b o sway control. Correct me if I am wrong, won't be the first time. Jim
12-08-2014, 07:45 AM
Biloxi
, Mississippi
Could you site your referance for that claim?
MICHAEL
12-08-2014, 07:52 AM
Vintage Kin
Fort Worth
I already did
12-08-2014, 07:58 AM
Vintage Kin
Fort Worth
hitch ?
"Necessary" and "recommended" are not the same any more than are "eliminate" and "resistant to".
The anti sway resistance is no more than conventional. Friction controls increase that minimal amount. The advantage of the hitch would appear to be the fresh take on the old design. Simplicity.
12-08-2014, 08:07 AM
Biloxi
, Mississippi
I already did
Where? No mention of this on the Blue Ox web site. I just got of the phone with Blue Ox. The laughed when I quoted you. They make no such recommendation.
MICHAEL
12-08-2014, 08:11 AM
Vintage Kin
Fort Worth
It would help if you read the site. See the FAQ. And anyone understanding hitch design knows the limitations of what spring bars provide AND knows that this is the standard prescription for increased sway resistance.
