Old 12-14-2014, 08:09 AM   #57
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Bob, would you describe the service you do seasonally on your Hensley?
Doug and Cheryl
Old 12-14-2014, 09:40 AM   #58
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Doug,
Yes...it's pretty routine by now.
1st make sure everything is clean.
Lay everything out, it’s all been marked & gets replaced where it came off.
Inspect strut bar mount holes for elongation, pins for ware & clips for no spring. Adjust for proper lateral alignment at install. Do not over-tighten, snug & locked will do it. Too tight contributes to ‘egg holes’.
Clean and inspect over-center locks.
Run jacks full range by hand for smooth operation…NO lubrication,(already learned that lesson, won’t hold adjustment if sprayed with graphite)
Inspect WD bar bearing surface for ware, grease @ 500mi intervals, inspect jack bar bracket pins, clips & holes.
Inspect head bearings for water intrusion and looseness, Clean & partially fill caps with Amsoil Marine grease, seal caps with RTV.(cap removal…not annually 4 times in 7yrs) So far have not had to re-pack.
Clean and lube hitch ball, very light coating as there is no rotation, inspect hitch latch, make sure it locks over center.
Re-torque frame brackets, ck LPG line for clearance.
Clean & inspect the stinger hole….oooooh that sounds bad.
Ck safety chains, bolt & screw extender, make sure hooks close properly, (weak/broken spring)
Finally.....install fancy Orange cover.
Old 12-14-2014, 10:16 AM   #59
Ayr , Ontario
Originally Posted by ROBERT CROSS View Post
Doug,
Bob, this is great information for any hitch owner. I wish I had known before setting out this year. Is there any way that you could put this into a video and post it? That would certainly help all the folks who aren't as familiar with all the terms.
I did the usual greasing stuff, just not the taking apart and inspecting. I took the hitch apart after it broke, but never knew that I needed to do that as routine maintenance.
gator.bigfoot is offline   Reply With Quote
Air Safe Air Hitch and WD hitch combo Uptightto Hitches, Couplers & Balls 18 12-22-2014 03:38 PM
Top Rated Sway Control Hitch (Hensley Hitch) Dgresham Airstream Classifieds 0 08-27-2014 10:20 AM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
