Old 10-12-2012, 01:28 PM   #1
1992 21' Sovereign
Hi-Torque Acme power jack
hi, i am a newbie in a '93 Sovereign. Yesterday, when attempting to lower the jack at first it was making a louder than normal sound then quit moving. when we tried the manual jacking it was sporadic in moving then nothing. the motor still runs. all you veteran experts out there, the questions are..is it the gears gone bad? i have no idea how old this jack is, do you think it is worth taking it apart and see about fixing or just bite the bullet and buy a whole new jack?
gramzinski is offline   Reply With Quote
Old 10-12-2012, 01:43 PM   #2
Spring Hill , Florida
That happened to me years ago. I took the head off and found a gear with a coupla teeth broken. I wrote to the mfg and they sent me the gears ---- free. Put it back together and it worked great.
Harold
zekethebear is offline   Reply With Quote
Old 10-12-2012, 02:25 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
The bane of electric jacks' existence are the limit switches. When improperly adjusted, the gears get subjected to too much torque, and fail in short order.
Should you decide to replace sheared gears, make sure the limit switches are adjusted correctly.
Tom
Old 10-12-2012, 04:09 PM   #4
1992 21' Sovereign
ok, we'll look into that. thanks
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 08:57 AM
Airstream Power Jack .. worth the $$? Suzzeee Jacks, Stabilizers, Lifting and Leveling 6 01-15-2012 01:20 AM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
No Power to Hydraulic Jack cloudflyer Winterizing, Storage, Carports & Covers 3 03-31-2011 05:28 PM
