Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 11-04-2009, 05:56 PM   #1
Astroboy's Avatar
2007 28' International CCD
West Hollywood , California
Here r my numbers (fresh from the scale)
Hummer H2 2008, GVWR 8600 lb
(Front axle rated for 4000 lb , Rear 5000 lb)
International CCD 28' with Hensley Arrows
[full fresh water, grey & black empty, lots of stuff (in front living room, in mid-galley, in mid-bath) but no much stuff in rear bed room]
Tow vehicle only (6760 total: one driver, almost empty trunk, full tank of gas)
1) 3560 front, 3200 rear
Hitched (14140 total):
2) 3220 front, 4860 rear, 6060 trailer
After adjusting WD bars...
3) 3300 front, 4740 rear, 6100 trailer
More adjusting...
4) 3380 front, 4660 rear, 6120 trailer
And again... (at this point, WD bars are ratcheted very very tight)
5) 3440 front, 4560 rear, 6140 trailer
I'm still not convinced as to how I should set up my WD bars...
Your comments or insights will be much appreciated.
Currently driving with #5) setting. I will check back in a few hours.
Gotta be on my way. Sorry to be abrupt.
Thanks in advance.
Astroboy is offline   Reply With Quote
Old 11-04-2009, 06:14 PM   #2
_
excellent info astro'
1. which w/d bars?
2. how much drop on the stinger?
3. at WHICH setting is the trailer DEAD LEVEL...
there are other questions related to the haha,
but a couple of well framed PHOTOS would save us LOTS of words.
cheers
2air'
Old 11-04-2009, 06:17 PM   #3
Astroboy's Avatar
I'm wondering if I should:
Move some weight to the rear bedroom?
Move some weight to the tow vehicle?
Dump the fresh water (40 gallons, or 320 lb)?
Thanks.
Old 11-04-2009, 06:28 PM   #4
Astroboy's Avatar
I just took this photo with the laptop's tiny camera (sorry not much of quality).
The HAHA stinger is 6 inch drop.
I think the trailer is hitched little higher in the front, I can feel the floor is sloping down as I walk to the rear...(Should exchange to 8-inche, I wasn't sure which one, after exchanging several times from (flat, 2-inch, and now 6-inch).
Thanks.
Old 11-04-2009, 06:28 PM   #5
_
see the questions in post 2...
the TOTAL tongue mass is ~1320.
subtracting the haha (~250lbs) yield a trailer tongue wt of ~1070 lbs....
which is RIGHT on 15% of the total trailer mass, a good figure.
__________
need more info.
cheers
2air'
Old 11-04-2009, 06:30 PM   #6
Astroboy's Avatar
Here's the photo.
Old 11-04-2009, 06:31 PM   #7
_
6 inch drop, ok good.
the trailer is a little NOSE high?
is that AFTER adjusting the w/d bars or before?
WHAT RATING are the W/D bars...1000 lbs or 1400 lbs?
tiny pics betta than no pix.
NOW how about a CLOSE UP of the ORANGE thing and related parts of the A frame/tongue area...
i wanna see the screw jacks (bottom end) in particular and the struts and w/d bars...
cheers
2air'
Old 11-04-2009, 06:34 PM   #8
Astroboy's Avatar
BTW, I actually weighed the tongue with Sherline this afternoon before I hitched up. It showed 1460 lb with HAHA attached.
I think, this is not good. I'm gonna shift some weight to the rear under-bed storage NOW...
Should I dump the fresh water? (Can I let it trickle, as I drive on Hwy...?)
Old 11-04-2009, 06:40 PM   #9
_
yes u can trickle fresh water, open the tank DRAIN valve...
but THAT will not solve the issues, and might make things WORSE...
especially if you LOAD the rear end and front end.
some fresh tanks are JUST BEHIND/over the axles.
so dumping won't help then.
gemme more pix....
and WHAT w/d bar rating???? 1000 or 1400...???
cheers
2air'
Old 11-04-2009, 06:42 PM   #10
Astroboy's Avatar
WD bars photo...
The 1000 lb WD bars seem pretty tight to me. You see how the WD jack is slanted...
Old 11-04-2009, 06:50 PM   #11
Astroboy's Avatar
Wow, I'm getting helps 2air... I'm awe-struck.
I read so many of his(or her?) threads (for hours & hours), which helped me much to be where I am with regards to this Airstream life.
It's like you read Shakespeare (or your favorite classic author), and you feel like he's your good friend. But the problem is Shakespeare is dead, and you can't converse with him...
Yet, here I am, conversing with 2air!!!
Old 11-04-2009, 06:53 PM   #12
Astroboy's Avatar
It's freezing cold.
Gonna start driving now, wanna get to the next truck stop or rest area before I get tired for the night.
Can't stay no longer at this supermarket parking lot. Was just shooed by the store manager...
Will check back in later.
Thanks a million.
Old 11-04-2009, 07:04 PM   #13
_
ok...
1000 lb bars, 6 inch drop and FULLY screw jacked, with the trayla NOSE high.
____________________
IMO and this isn't absolute, but it IS my best guess based on the info at hand...
1. gotta have 8 inch drop.
2. gotta have 1400 lb bars
3 may need to CHANGE HOLES on lower end of the screw jack tubes (see the haha owners manual)
___________________
1. the H2 /haha users here MOSTLY use 8 inch drops.
there is ONE fella towing with the 6 and NOSE high, who reports he's happy...
but the others use 8 inch drops.
the issue is TRANSFERRING mass forward to the steering axle WHILE keeping the trailer level.
to do THAT one must start with the TONGUE a bit LOWER and as the bars are tensioned the trailer levels out.
u will NOT ever be able to do that with the 6 inch bar, based on the photos.
2. the tongue mass is OVER 1000 lbs, so 1400 lb bars are needed.
if it was JUST a tiny bit (50 lbs) over, 1000 lb bars can work, barely.
but at 1200 u need 1400s.
the 1000s just continue to BEND but after reaching their rating, MOVE NO MORE MASS...
the orange company USED TO (secretly swap w/d bars) and might IF you really really get after them.
because the 1000s are WRONG in this situation.
getting the tongue weight down just moving stuff inside isn't enough (unless u r carrying anvils up front)
IF you removed BOTH lp GAS bottles that would scrub a 100 lbs off, but then where to carry them????
it is not safe to carry them in the SUV or TRAILER.
3. once the proper DROP and W/D bits are used, it MAY be necessary to change HOLES on the screw jack tubes...
this would allow for MORE tightening and wt transfer, BUT ONLY with the correct bars and stinger.
_______________
really that is IT, case closed.
______________
now if u are IN ROUTE somewhere and cannot park till the right bits arrive these things will help a TINY TINY bit...
1. increase the AIR PRESSURE in the H2 rear tires (check the sidewalls for max)
2. increase the AIR pressure in the REAR tires on the trailer (65 max, but i might go to 68 if desperate)
3. load stuff OVER the axles in the trailer NOT either end, OVER The axles...
4. put some STUFF in the H2 MIDDLE seat.
but u are CLOSE the gvwr already so THAT is an issue too.
_____________
towing with the current set up is gonna STRESS the rear trailer tires and axles....
one could UNtension the screw jacks (this would lower the trailer nose) but then the STEERING axle will be light...
so CONTROL while towing would be an issue.
the COMPROMISES all have risks associated with them, that's why they are COMPROMISES...
nothing bad may happen for a 100 miles or a crack in the earth could swallow you and half of california...
if that happens take more pictures!
____________
best of luck, get an 8 inch drop bar AND 1400 lb w/d bars and you will be in fat city...
and i don't want to OVER emphasize getting the proper wt/position and trailer angles, but these things are sorta important.
given your very FIRST POST was about potential disasters!...
http://www.airforums.com/forums/f439...nly-43585.html
cheers
2air'
Originally Posted by Astroboy View Post
... the problem is Shakespeare is dead, and you can't converse with him...!
rumor is i am dead too...
and this post was recorded months ago for emergency use by the "errs committee" ....
Old 11-04-2009, 07:04 PM   #14
funkill's Avatar
Tucson , AZ
Images: 27
Getting shooed out by the manager - what a poor sport.
I know nuthin about the haha's but if you hang in there long enough, these folks will set you up!
Stay warm and wishin' you luck.
Laura
funkill is offline   Reply With Quote
Old 11-04-2009, 08:46 PM   #15
Astroboy's Avatar
Originally Posted by 2airishuman View Post
- the 1000s just continue to BEND but after reaching their rating, MOVE NO MORE MASS...
- towing with the current set up is gonna STRESS the rear trailer tires and axles....
Wow, you can figure out all that?
There was another measurement at the scale which I didn't mention...(I was afraid that it may dilute the focus of the discussion, but I should have)
No WD adjustment was made from #5) setting in my original post. I had just rolled the rig to a few feet in order to weigh trailer's tandem axles separately...
#6) 8040 (tow vehicle), 2740 (front tandem), 3360 (rear tandem).
#5) 3440 front, 4560 rear, 6140 trailer (front tandem + rear tandem)
These above 2 figures are measured only seconds apart.
3440 + 4560 = 8000 (doesn't equal 8040...!)
2740 + 3360 = 6100 (doesn't equal 6140...!)
The measurement of #6) is done with front tandem and the rear tandem on different weigh plate of the truck scale; each axle weighing on the edge of the each plate...
So, I thought it was a fluke or the inaccuracy of the scale when I saw the significant difference of front tandem (2740) & rear tandem (3360)... And I didn't think it was a big deal...
Old 11-04-2009, 08:55 PM   #16
_
..So, I thought it was a fluke or the inaccuracy of the scale when I saw the significant difference of front tandem (2740) & rear tandem (3360)...
no fluke and the accuracy of the weighing looks very good.
and that REAR tandem axle load will INCREASE with MOVEMENT down the road.
again the extra load may not cause any (obvious) harm but then again it may.
ideally each axle (and each side) are loaded similarly.
you have done a great job getting data and the numbers all appear sensible given the players.
i suspect that AFTER strapping on the right stinger and w/d bars,
the NEXT time it's weighed you'll DIAL it in tight and proper.
but take a real camera with ya!
(i am laughing hard about you pointing the LAPTOP at the rig to take a pic...)
no wonder the store manager wanted u outta there.
cheers
2air'
Old 11-04-2009, 08:57 PM   #17
Astroboy's Avatar
It's amazing how 2air conjectured all that...
ACK on 8-inch stinger and the 1400 lb WD bars... (should have prepared before..., but I didn't know any better...)
Right now, this very moment,
- I just bicycle pumped my H2's rear axle air bag suspension (I had thought wrongly that AS liked a cushy ride, so I didn't stiffen up my rear when I started driving...)
- Trickling out the water now.
- I have shifted all the heavy stuff (tool boxes, crates of books, etc. 100 ~ 150 lbs) to mid-bath floor and the shower room.
Dumping water now.
- pumping up AS's rear tandem tires. Infrared temp monitor showed higher temp on rear tires. (amazing 2 air! Most importantly, your comments deconstruct what's happening and help me understand...)
Old 11-04-2009, 09:02 PM   #18
Astroboy's Avatar
Rear tandem tires were about 80F.
Front tandem tires were about 73F.
No more juice on my battery. Gotta drive some more to inverter charge. On my way... at 55 ~ 60 mph.
Arigato, Shie-Shie, Grazie Mille, Gracias Muchos...
Old 11-04-2009, 10:36 PM   #19
Astroboy's Avatar
Originally Posted by funkill View Post
Getting shooed out by the manager - what a poor sport... Stay warm and wishin' you luck.
Laura
I appreciate ur support, Laura.
Towing is labor/energy/attention intensive activity! It takes so much out me. I had only done few trips so far, only a few thousand miles of exp.
@ 2Air, thank you for helping me out kindly.
Lights out. Zzzzz...
Old 11-05-2009, 02:52 AM   #20
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
I guess manager didn't realize he was looking at a very rare street-side door A/S...
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
scale model Airstreams thunderbird Off Topic Forum 9 08-30-2016 07:20 PM
Weights from scale read-outs RLS Hitches, Couplers & Balls 16 09-16-2009 08:48 AM
Cat Scale Etiquette campadk Towing, Tow Vehicles & Hitches 15 11-24-2006 03:46 PM
HO scale Buick and Airstream! dinoburb Our Community 2 09-19-2004 07:53 PM
Another ebay auction - Scale Model BobbyW Our Community 2 01-08-2003 07:42 PM
