Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 05-13-2006, 07:55 PM   #1
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Hensley Stinger Cover
I leave the stinger on my Hensley hitch because it is easier to unhitch and leave the Enkay RockTamer mudflap protectors in place. I usually grease the part that goes into the truck receiver for easy in hitching but that leaves the stinger out there to get grease on my leg or pants if I'm not careful. My project was to find a 6" receiver tube with a measurement of 2.5" from the edge to the middle of the hole the hitch pin goes through. I found one 6.5" long and the required 2.5" to the hitch pin hole at Tractor Supply for less than $15. My plan is to have a small plate welded to the open end to close up the hole except for a small air hole at the bottom of the plate, put putty in the hitch pin holes then dip the outside of the receiver tube in bright blue Performix PlastiDip multiple times to build up a thick rubber coating. This will give me a no-slip grip with weather protection and no grease to get me when I walk by. The color also stands out to keep people from bumping their shins on. You can picture what the finished project will look like when through by looking at the beginning of this project.
ID:	21279  Click image for larger version
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-13-2006, 11:28 PM   #2
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
I think I would use the red plastidip
RED means stop where ever you go.
Nice job!
Scott
scottanlily is offline   Reply With Quote
Old 05-14-2006, 09:21 AM   #3
pmclemore
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
I use a plastic grocery bag - just tie it on by the handles and dispose of it when it gets too grody.
Pat
pmclemore is offline   Reply With Quote
Hensley Arrow Hitch Les Hitches 10 02-28-2007 08:59 PM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 12:05 PM
Hensley, Pullrite, etc. markjoandall Hitches 20 10-27-2002 05:51 PM
cover for univolt maznblu Electrical - Systems, Generators, Batteries & Solar 2 09-15-2002 07:02 PM
Trailer Life cover 83Excella Our Community 6 06-16-2002 10:14 AM
