Old 04-05-2012, 04:56 PM   #15
dznf0g's Avatar
Oswego , Illinois
This is how I have mine set up.
-Rich-
Old 04-05-2012, 06:25 PM   #16
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Thanks I will work on this tomorrow morning and follow up.
Don
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 04-06-2012, 05:37 AM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Don,
I also have the jacks set in the fifth hole, three showing empty.
You can see how far the head is tilted down, I was able to level in this case by extending the jacks equally. If the trailer is not level side to side there is still enough adjustment left in the jacks to bring it back.
A hitching stick with an "O" ring is helpful getting the height rite.
ID:	155120   Click image for larger version
Name:	July Forth trip To Cold Brook 017.jpg
Name:	July Forth trip To Cold Brook 018.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-06-2012, 06:49 AM   #18
adonh's Avatar
1976 31' Sovereign
Originally Posted by ROBERT CROSS View Post
Don,
Now that is a great idea.
Don
Don Hardman
1976 31' Sovereign
Old 04-06-2012, 07:58 AM   #19
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Bob,
Your comments are so helpful throughout these pages. I have to do some solo 'streaming next month. Can you guide me to places to purchase the hitching stick you show in your pic? Thanks.
Don,
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 04-06-2012, 09:43 AM   #20
Thumbs up
Originally Posted by Silver Otter View Post
Bob,
SO,
Thank's for the kind werdz....Hitchin' Rods. I got ours at Camping World several years ago.
PFC
"Tahawus"
RLC
John Prine
Old 04-06-2012, 10:05 AM   #21
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
I'm not sure what Andy means by the comment "exactly when you need it most." 99% of shear bolt shearing comes in a backing situation when the main unit is up against its stop. In that case you will damage your Arrow if you have a welded frame bracket. If you look at the quantitative data there are FAR more Arrows on the road with shear bolts than there are welded brackets. Andy really doesn't sell many Arrows so he has limited experience with the product and what is actually needed.
The main unit will always tip to one side when you push on it when unhitched. You are applying a load vertically and the strut is pushing toward you while the hitch pivots in the coupler. Once you are hitched it will not do that.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 04-06-2012, 11:23 AM   #22
adonh's Avatar
1976 31' Sovereign
Originally Posted by Sean Woodruff View Post
If you look at the quantitative data there are FAR more Arrows on the road with shear bolts than there are welded brackets .
I agree and used new sheer bolts as advised by Hensley Arrow.
I am am finishing up the adjustments and I have greased the hitch ball and spring bars and it should work as designed when I am through. I will report back later today.
Don
Don Hardman
1976 31' Sovereign
Old 04-14-2012, 03:18 PM   #23
adonh's Avatar
1976 31' Sovereign
Hi everyone I finally was able to complete the setup on the Hensley. I moved the rear strut to the bottom hole in the frame bracket as suggested and the struts are now level with the trailer. All clean and repainted. When the struts were on the middle hole of the frame bracket I only tightened the springs bars down to around just short of the 2nd mark from the bottom. Now I am I almost down to the last mark from the bottom. The trailer seems to sit lower in the front, but that could just be me thinking that it does. I have 7 1/2" from the bottom of the spring bars in front just as it bends to connect with the main unit.
I have an 8' drop bar I wonder could I get by with a 6".
Thanks for any comments and input. We are heading out tomorrow morning heading up to Tuscon.
Don
Don Hardman
1976 31' Sovereign
Old 04-16-2012, 05:02 PM   #24
adonh's Avatar
1976 31' Sovereign
two days over a 1000 miles
Well we left Missouri City on Sunday morning and are now stopped for the the night in Las Crucas NM. The Henslesy set up preformed flawlessly. I remember now what finally made my mine up to by the Hensley in 2000. We took the same trip with the same Airstream but with some other hitch. The cross windis up in the high hill country is really strong. The trip in 2000 was white knuckle all the way. Over the last 2 days same bad cross winds and every now and then I was tell my wife that would have been a bad one without the Hensley. Smooth ride all the way.
Don
Don Hardman
1976 31' Sovereign
Old 04-17-2012, 11:01 PM   #25
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
POI...on install I used one of the extra bolts to thread all the holes before mounting the plates.
Just seemed to me there was way too much torque being applied while cutting the threads, the bolts just might be very close to failure right from the 'git-go
I remove the haha during Winter storage, ('cept plates), and check everything thoroughly at Spring get ready.
Bolts are galvanized and have been replaced twice in five years following the RCM procedure. SFSG.
Welding?...
We used a tap on all of the holes we drilled. This eliminated anystress of self tapping with thesupplied bolts.
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Hensley self tapping shear bolts adonh Hitches, Couplers & Balls 24 04-17-2012 11:01 PM
A new airstream avenue class b van self contained ac generator 190 must see sale eBay Watch Airstreams on eBay 0 02-16-2012 05:50 PM
A new airstream avenue class b van self contained ac generator 190 must see sale eBay Watch Airstreams on eBay 0 02-09-2012 08:00 AM
Elevator Bolts: I don't get it Aktundra Repairing/Replacing Floor &/or Frame 12 02-09-2012 07:10 AM
A new airstream avenue class b van self contained ac generator 190 must see sale eBay Watch Airstreams on eBay 0 02-01-2012 04:30 PM
