Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 06-04-2002, 12:09 PM   #1
markjoandall's Avatar
Profile:  2001 30' Excella
Bedford , New Hampshire
Cool Hensley, Pullrite, etc.
I’ve joined this forum recently and have read various threads on different subjects. I find the regular members of the forum to be open and genuinely helpful to members of the Airstream community. Therefore I would like to share with you an experience I’ve had with the Hensley Arrow Hitch.
I’ll preface my comments of the Hensley hitch by commenting on my experiences with a brand “X” weight distributing hitch and the Pullrite hitch. Prior to purchasing our Airstream, we owned a 1984 Award trailer that we pulled with a 1983 Chevy Astro Van. Our first experiences were with the Brand “X” hitch and sway control brake were disastrous, neither worked. It was pure white knuckle driving and we couldn’t go above 55. After one season with this rig, we scrapped the hitch and purchased the pullrite. The Pullrite does everything they advertise and we regained the stability we needed while towing. We learned much with this hitch and accepted the compromises in turning radius, and the procedures needed to hitch the trailer to the tow vehicle. All in all, this is a very good hitch and I would suggest it to anyone.
Last year we traded the entire rig to move up to an Airstream. We purchased a 2001 Excella 30, and a GMC Yukon XL. I called the Pullrite people to order a new hitch and was told I would loose my spare tire, located under the bed and in front of the rear bumper. Unfortunately this was not an acceptable option for us and I called Hensley and ordered our new hitch.
This last April, while driving overnight to Florida, I had some instability in the rig. It felt somewhat like the old days with the Award. The trailer was chasing us around the road, and we were disappointed with our lack of stability. I purchased new tires before we left and forgot to inflate them to their maximum pressure. We stopped and pumped up the tires, this helped but not completely. When we stopped for our first load of gas I kicked the hitch and found one of the struts a little loose. I tightened the nut on the curbside strut about a half a turn and locked it in place. When properly installed and adjusted, this hitch is absolutely fantastic. There is no sway at all. A twenty-four hour trip to Florida is a comfortable experience with shared driving. The bow waves of passing semi’s are not noticeable and in the flat lands of Georgia and Florida, we have to concentrate to keep the speed down because it is so easy to go over 70. I like to tow around 62 mph. We now have over 9,000 miles on this rig and are very happy with the setup. When you have the investment many of us have in a rig, the difference of another couple of thousand is insignificant. Especially when you have your family along for the ride.
I have first hand experience with all three types of hitches. Without question the Hensley is absolutely the best with the Pullrite a close second, and both far outdistance the third.
Happy towing.
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 06-06-2002, 09:25 AM   #2
Profile:
We have owned a Hensley since '96 when we were pulling a 26' Sunline with a V8 Grand Cherokee. Since then we have towed a 30' Award with the Jeep, a 31 foot Airstream with a Tahoe, and a 34' Airstream with 3/4 ton Chevy truck. The Hensley has been on all of em....We don't leave home without it.
Happy campin'
Lee
LeeC is offline   Reply With Quote
Old 06-08-2002, 07:27 PM   #3
Profile:
Lee, how did your Tahoe do pulling the 31' using the Hensley? I'm thinking of possibly getting a 25' Classic or Safari. I would also buy a Hensley. My concern is what wheelbase is necessary for safe pulling of a 25 footer? Do I need to go to the Suburban wheelbase or is the shorter Tahoe ok? Comments would sure be appreciated.
Kent
kkrogh is offline   Reply With Quote
Old 06-08-2002, 07:41 PM   #4
66TradeWind's Avatar
Profile:
Images: 22
Tahoe puller
Hi Kent
We pull our 66 TradeWind (24 ft) with a 99 Tahoe. It has the correct rear differential for max pulling (3.73 I think). We find the stability is just fine with reese weight distribution setup. We pulled our former 60 Overlander (26ft) from Southern Ohio to Western Canada last June and never felt that the tail was wagging the dog.
If I have a concern it would be that the Tahoe has to work pretty hard on some of the mountain passes but it is very stable.
Though shorter our 24 footer is heavier than our 26 footer was. We are about 5000 lbs loaded.
Terry O'Neill
Calgary, Alberta, Canada
WBCCI 4786
VAC
http://pages.sprint.ca/Streamsite/main.html
66TradeWind is offline   Reply With Quote
Old 06-09-2002, 04:05 AM   #5
Kent,
I've seen 25 and 27 foot safari's go blasting down the road behind tahoe's. You should have no problem at all with the right rear end. Make sure you have a 3.73. The Hensley should do really fine with the shorter wheelbase of a Tahoe. I think you would feel some instability (effort to move the tow vehicle in cross winds and passing other vehicles) without one. It certainly is worth the investment.
My son (age 14) and I installed ours at the airstream dealer. No problem and only took about an hour.
Good luck
Aerosmith
Old 06-10-2002, 07:54 AM   #6
Profile:
Kent, like the others have said, the Tahoe did pretty well. Out on the Intersate, I could run with anybody. I was a little slow in the Blue Ridge Mountains. We never went to the real mountains out west. The short wheelbase was a non issue using the Hensley. We never had any problems with the Tahoe. We just drove it and kept the fluids changed. The lease ran out on the Tahoe and we decided that we wanted a crew cab truck.
Good luck and best regards,
Lee
Old 06-13-2002, 08:48 PM   #7
Profile:
No problem here with brand x
I would not want anyone who wants one to forgo the purchase of a Hensley or Pullrite. The priciple behind both products make excellent sense.
However, I would not want everyone to think it is the only alternative, either. I tow an '87 Sovereign 25' with a 94 Chevy 1/2 ton (diesel) extended cab shortbed using a single sway bar Reese load leveling hitch. To say it works great is an understatement. I have towed it thousands of miles now and am never bothered by passing semis, strong winds, or rough roads.
Now, this is a rather heavy truck, even for a 1/2 ton, and has a rather long wheelbase, so I start with an advantage. And some time and effort went into getting a proper setup. And a 25' is not the longest trailer out there. But the Reese was a fraction of the cost of either Pullrite or Hensley. And the lack of the additional weight over the bumper is a small plus as well as compared to a Hensley.
I do not say that a Hensley or Pullrite are not necessary; in fact, I suspect that they would make some otherwise incompatible trailer/tow vehicle combinations possible. I am merely observing that many times they are not actually the only choises.
Mark
Old 06-14-2002, 09:10 AM   #8
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
that makes me feel better. I haven't towed my new trailer yet (still getting repaired), but when I do, it will be with a Dodge Ram 1500 Quad-Cab short-bed, and with no fancy hitch. It weighs nearly 5200lbs empty, and has a 139" wheel-base. I don't think I'll have a problem towing a 3500lb (according to AS) trailer.
I've hauled much heavier stuff (construction equipment) in the past, and never noticed sway like I've been reading about in reference to the Hensley, etc. Seems to me that if you're experiencing enough of a problem to warrant a $3000 hitch, there's something else wrong. (truck too light/trailer too heavy/driving too fast). Maybe not...I'm no expert. maybe the profile of a TT makes a better "sail" than a backhoe, and weight isn't really the issue. More of a "leverage" thing (?)
Old 06-14-2002, 11:19 AM   #9
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Chuck,
I towed a '77 Excella 500 31' empty from AZ. to TN. with a '92 Chevy Z71 4X4 shortbed truck. I have a Reese 1,000 lb. max tongue wt. hitch and Reese straight equalizer bars. Every semi that passed me made me waunder over the road. I spent much of my time looking in the rear view mirror to prepare for the next truck. My knuckles became white sometimes. That truck was totalled by my son while trying to miss a deer which jumped in the road in front of him. I replaced it with a '01 Chevy 2500HD extended cab shortbed truck. While listed as a 3/4 ton, it actually is a 1 ton without the dual rear wheels. The wheelbase was increased, the tires are shorter (245-75-16 vs. 265-75-16) and are E rated therefore stiffer sidewalls. I still use the same hitch setup but the waundering has stopped when trucks pass. I think it is the heaver truck, longer wheelbase and the stiffer tires that have taken care of that. I bet with the Hensley attached I would not even know that the trailer was back there.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-16-2002, 08:13 PM   #10
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I have a 3500 single rear wheel 4X4 pickup, with 454 and 4.10 rear end. (9200 GVW, same as 2500HD)I tow with just a plain ball hitch, no sway control. It pulls fine, no sway whatsoever. When on a level surface the truck and trailer are completely level, so I do not use an equalizer hitch.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 06-16-2002, 08:26 PM   #11
Pick's Avatar
Images: 36
My Experiences with "Trailer Sway"
I also use this truck to pull a 23' equipment trailer, with tandem axles. The axles are centered exactly on the 18' platform. I have noticed sway with this trailer, IF the equipment being hauled is to far back on the bed of the trailer, which results in less hitch weight. When I have encountered sway, I stop and move the equipment up about a foot, and the sway stops. I have also observed that low tire pressure can cause sway. I took a look at my Airstream and noticed that the tandems are back behind the centerline of the coach, this is one of the reasons they pull so well.
Lots of Hot Sauce!
Air # 283
Old 06-16-2002, 09:48 PM   #12
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
This story is no bull (well, actually, it is, kinda)
My worst towing moment came when I didn't securely fasten the middle gate of my stock trailer and the 1200# bull I had put in the forward compartment decided to stroll to the rear. I was towing with a short-wheelbase Blazer and with all that weight at the back of the trailer, things became frantic in a hurry. Thankfully, there was no other traffic and the road was wide with good shoulders because I used all of it. I often wonder what that bull was thinking as he richcheted first off one side and then off the other.
My 22' International tows nicely with no sway damper and the tech at the dealer said I wouldn't need one. I'm a belt and suspenders guy, so I put on a Reese sway control anyway. Last weekend, doing 60+, in a hard 90-degree crosswind, I was passed by an 18-wheeler doing about 80. When I saw him coming, I lifted my hands slightly off the wheel to see what the reaction would be and there was practicaly none.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 07-05-2002, 10:47 AM   #13
caadoptees's Avatar
Profile:  1992 25' Excella
Visalia , California
Images: 14
Just to add my 2 cents. We pull a 25' Excella with a 19' Excursion. It has a V10 6.8L. It has a 'standard' load equalizing setup, nothing fancy, no sway bar, etc. I have never noticed any misbehaving. However, I am not sure which part of the vehicle weighs more (tow or trailer). The setup is very well behaved.
Roger & Roxie Smith (WBCCI#27380 - Air#178)
Visalia, CA (between Fresno & Bakersfield)
1992 25' Excella - Nuestra casa rodante
2003 F-250 6.0 Turbo Diesel Crew Cab
http://www.casarodante.org
caadoptees is offline   Reply With Quote
Old 07-05-2002, 12:05 PM   #14
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I am towing my 25ft tradewind with a 1992 Dodge 1 ton extended van. Although not a " hip" tow vehicle, it does very well. It has the 360 V8 and a 3:90something rear end. The transmission is a 4-speed automatic, whereas 4th is an overdrive with a bypass switch. It's very cooll if you have room to bring everything and everybody you want, and still have room to be comfortable in the van. The long rear end overhang makes backing up the trailer really easy, it responds very well and fast. I am not noticing a disadvantage trqavelling with the long rear overhang, just perhaps a very slight sway when semis pass at mach 3.
I use a regular hitch ball for short runs, don't even bother with the equalizer hitch. For extended trips, especially to Mexico where both vehicles are loaded, I use the equalizer lift with 2 bars. ( eaz-lift) There is a sway ball on the trailer, but I do not have the sway control system to go with it.
My equalizing hitch works well, but is very noisy n turns. Maybe anyone has a suggestion as to how to stop the noise? it clunks and creaks, as if the chains move across the tongue and catch on something. I believe the setuo is correct, i did it as per instructions.There are 4 chainlinks used, and 4 hanging loose while driving. The receiver and bar ends are lubed with moly grease, but ti is still noisy.
I noticed that if I only tension the hitch very slightly, then the noise all but disappears. Anyways, it looks like an older model, but if anyone has a similar experience and a solution, then I would love to hear about it.
Uwe
Pingbacks are On
Hensley Arrow Hitch Les Hitches 10 02-28-2007 08:59 PM
Hensley To Equal-i-zer Hitch Experiment DreamStream Hitches 65 08-18-2006 09:32 PM
Hensley is worth it, right? Big Dee Hitches 61 08-23-2005 09:11 PM
Hensley Hitch Grease Princer Hitches 3 04-12-2004 03:57 AM
Is a Hensley overkill for a 22' trailer? Charcigar On The Road... 11 08-07-2002 08:59 AM
SEO by vBSEO 3.1.0
