Old 07-22-2009, 12:09 PM   #1
Valrico , Florida
Hensley, Pullrite, Air Ride hitches
I'm so confused....Each hitch has a purpose and very valid advantages. At what point do the positives start to out weigh the negitives...Where do we draw the line....How do I decide....Help me please. 28-31 Airstream, 2500 Dodge Ram 4x4.
stufarmer is offline   Reply With Quote
Old 07-22-2009, 01:14 PM   #2
SteveH's Avatar
Common Sense , Texas
Here's some reading material for you: The Jim Hensley Hitch Story | ProPride, Incorporated
Old 07-22-2009, 01:47 PM   #3
Valrico , Florida
No where is there mention of the Hensley hitch absorbing the rough road energy between the truck & trailer like the Air Hitches with sway control do...I'm under the impression that the stiffness of a HD truck and the Airstream don't mix...
Old 07-22-2009, 03:36 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The Hensley, Pullrite serve 2 functions, weight distribution and sway control. The Air Ride, if equipped with WD adds a third, limiting the transmission of shock from TV to trailer and back.
Unless you are driving on the back roads of Alaska all the time I can't see a reason for an Air Ride Hitch.
With your 2500 Dodge I would look at a Reese Straight Line Hitch as more than enough. Yes the Hensley, and to a follow up extent the Pullrite have strong followers but the hitch up problems don't come any wheres near justifying the cost.
2004 Excursion 4x4
Old 07-22-2009, 03:55 PM   #5
SteveH's Avatar
As HowieE has stated, the Airide is designed to reduce shock to the trailer, and from the trailer to the tow vehicle...basically, ti improves the ride. I may be also combined with weight distribution, but I have not seen it coupled with the type of sway control that is used with either the Pullright (really a variation of a fifth wheel hitch), or a Hensley/Propride (both pivot projection hitches).
They are designed to do different things, and only you can determine what it is you need. If it's sway control, look at the Pullright, Hensley, Propride, or even some of the less "technical" of the weight distribution hitches with sway control. However, if it's improved ride you are interested in, you may want to consider the Airide, but I suggest you discuss your towing problems with each manufacturer to determine if their product is what you need.
Old 07-22-2009, 04:22 PM   #6
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Stufarmer
I personally have never been able to justify the amount of money that is Commanded for exotic hitches. My father used the REESE Straight Line Dual cam on the SOB's he owned and towed for yrs. I also have the same hitch (not his) Reese/DrawTite that do the job for me. I have no sway issues, my wife hates Interstates, so we travel alot of state and US highways, mostly 2 lane roads. I meet semi's of all configurations with all kinds of different wind conditions and have never had an issue.
As you can see by the lower corner of the page we have a F350 diesel, I use 550 lbs bars which give me flexing in the hitch without recoil or rebound and gives us and the trailer a smooth ride. I did have 1000 lb bars that were way to harsh, so I sold em.
The Reese will cost you about 1/10th what a exotic hitch will cost you and do the same job. Tow your trailer!
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-22-2009, 06:19 PM   #7
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I was a bit concerned about potential hitch up problems when I bought my Hensley.
My experience with it is still pretty limited, mainly just one cross country trip & back, but I will say I was pleasantly surprised.
A careful reading of the manual plus a few helpful tips from folks here on the forum, and so far, I have found hitching a breeze - plus no spring bars to install and hook up every time we hitch up. (they remain on the trailer)
As for the hitch performance - amazing - does exactly what they say!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-22-2009, 06:35 PM   #8
Valrico , Florida
Brian.
with all the positive remarks on the Hensley, does it do anything for the breaks in the Hwy. What I'm trying to say is does it eliminate the Jerk/Backlash between the Tow Vehicle and the Travel Trailer...??
Old 07-22-2009, 07:28 PM   #9
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
Hitch up problems have been virtually eliminated with the new design of the hitch box on my hitch. With over 1000 on the road I have had less than 10 hitch up calls with the new design. At the orange company I had a full time guy that answered these calls daily. I would say that of all the improvements that Jim made in the new design, the hitch box design has been the single greatest improvement. It is the single most commented on feature from former orange owners now using the ProPride.
(As for the "exotic" hitch comment... the Orange, Pull-Rite and ProPride do NOT operate the same as the conventional designs)
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 07-22-2009, 08:16 PM   #10
Valrico , Florida
Understanding that now the (hitch up) design flaws have been answered. Can you comment on my prior question...How does the hitch handle the Jerking/Clunk associated with broken Hwys and the stop & starting feeling that the Air Ride hitches solve...? For us, that rough ride (bucking) between the trailer and tow vehicle makes for a very uncomfortable road trip.
Old 07-22-2009, 08:26 PM   #11
ProPride, Inc.
Jerking and clunking is a combination of a lot of factors. The hitch will do no more for jerking and clunking than any other weight distributing hitch. The weight distribution system of the hitch is the same as any other. As has been discussed at length in other threads, the spring bars need to be properly sized (600, 800, 1000 or 1400 are all available). If the bar is too stiff it will not flex under load and that will be transferred into the tow vehicle and trailer.
I expect to have an air ride option for my adjustable hitch bar by the end of the year and that will also help damp some of the road problems.
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 07-22-2009, 08:37 PM   #12
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Howie says he does not see the advantage of Air Hitches on other than rough roads. Steve says he has not seen an air hitch with sway control as in Hensley or Pullright. Stufarmer asks about "Jerk Clunk"
I just put on a Air Safe Class 5 hitch. I have a Husky WD hitch attached to the Air Safe. The Husky has the usual place for a friction sway control.
I did this primarily to protect my Airstream from the rougher ride of my F250. I can say that the Air Safe dramatically improves the towability and you can see the AS suspension operating independantly without transmisson of minor bumps from the F250. Also bigger bumps are more quickly absorbed without being sent back and forth in wave fashion between the TV and towee. Overall the trailer tows straighter and is less subject to blow by from large vehicles. In general the trailer is significantly easier to tow. "Jerk/ Clunk is also intially reduced and is limited to the initial bump without aftershock. This is on the interstate at 60-70 mph and not on rough roads. On rough roads there is also great improvement in towing and comfort. I didn't know what I was missing till I tried it. I should say the only previous hitch I had was a Reese WD and have never used a Hensley or Pullright so I can't compare those hitches which I am sure have their advantages.
Old 07-22-2009, 08:48 PM   #13
ProPride, Inc.
I have no doubt that the air ride hitch will reduce road shock to the trailer and tow vehicle. It is quite effective in 5th wheel hitches so I'm sure the same would be true in travel trailers.
I don't see how it could help in sway control whatsoever. Sway occurs in a different plane than the vertical plane that works with the air bags. In fact, it increases the lever arm between the rear axle of the tow and the hitch ball because it needs that space for the air bags and hitch mechanism. A force in the horizontal plane acting on the ball will create more steering torque in the tow vehicle and will require steering to control the trailer.
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 07-22-2009, 09:54 PM   #14
Lumatic's Avatar
1993 34' Excella
Images: 16
The specs on Air Safe (I assume Air Ride is similar) say I could use a Air Safe class 3 hitch for my Tradewind. This hitch does not have the capability of use in conjunction with a WD hitch and/or a sway bar. This is the combo I use: Class 5 Air Safe which also accomodates a Husky WD and friction sway bar. A big factor in choosing the Class 5 Air Safe was so I could also use a WD and sway control.
It's kind of like pornography. A Supreme Court Justice (forgot who) said I don't know how to define porn, but I know it when I see it. Your comment makes sense but I don't need to understand the physics behind the hitch to feel the noticable improvement in tracking, sway and being blown around by big rigs on the interstate compared to my Reese WD with the same friction sway bar. So for me this combination does reduce sway. Also, I am only using one swaybar and the hitch can accomodate 2. Syllogistically speaking, if the combination of Airsafe, WD and sway bar reduces sway more effectively than WD and sway control alone the Air Safe plays a role in reducing sway. This is not to say the Air Safe will reduce sway on it's own. Maybe, maybe not.
Old 07-22-2009, 10:41 PM   #15
2000 34' Limited S/O
Jamestown , North Carolina
I agree with the remarks of Wingeezer above. I have had a Hensley Hitch for a year now I've been amazed at how well it performs. All the comments I've read by Hensley owners I now realize are justified. I too struggled at first to hook up but with some tips and through my own learning curve, I can hook up alone now using a mirror. I have just traded my rig for a 2000 34' Sofa SO and will be moving that hitch to the new rig.
I have a friend who just purchased the new Pro Pride and is pleased with it. For now, I am content with the set up I have.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 07-23-2009, 11:22 AM   #16
Valrico , Florida
Thank you for all your comments and opinions on the subject. I am not approching this topic to save a few dollars, but to purchase the best hitch assembly for an Airstream. We have had Class A's & C's...our last a Lance cabover, now a Travel trailer. We have gathered by your comments that the Air Ride type hitch with the proper weight dist bars give you both the comfortable ride and also do an exellent job with sway control. We have fallen in love with the 28' International for it's simplicity, and the beautiful 30-31' Classics for the luxury. what to do, what to do. Thanks again..Steve & Sue
Old 07-23-2009, 11:27 AM   #17
SteveH's Avatar
Actually, no. A weight distribution addition to the Air Ride does not really provide sway control. Sway control is a different issue from weight distribution.
Old 07-23-2009, 12:11 PM   #18
Valrico , Florida
You are correct....I ment to say a properly installed Weight Distribution/Sway control hitch assembly in conjunction with an Air Ride Hitch system...... thanks again.
Old 07-23-2009, 03:13 PM   #19
Lumatic's Avatar
1993 34' Excella
Images: 16
Steve & Stufarmer, You are both right. Also, please keep in mind I am referring to my own opinion on a specific combination of products. The Air Safe Class 3 hitch does not allow the use of a weight distributing hitch, you may still be able to use a sway bar. The Air Safe Class 5 does allow the use of a weight distributing hitch and 2 sway bars (I use one). I have a Husky WD hitch and a generic sway bar.
With my F250 3/4ton stiff suspension and minimal squat the information I have read indicates a WD hitch will have a less pronounced effect than a 1/2 ton TV. I also do not have a real problem with sway without the sway bar on my 25' 4500# Tradewind. There is a major improvement with the Air Safe hitch component. Overall, however, I do notice a across the board improvement in comfort, towability on smooth and rough roads and resistance to sway. The information out there also points to a real safety advantage in a serious equipment failure when towing, perhaps avoiding a sad new forums thread.
You might have noticed I didn't say a word about Air Safe Class 4 and 6 hitches. That's because I know nothing. Would another WD hitch work in this combination as well as the Husky? I will again invoke those famous words of Sergeant Schultz.
I can't resist throwing a red herring! The WD torsion bars I use are rated at 1000-1200#. I use these just because they are there. My tongue weight is about 500#. The Air Safe rep I spoke with said the shock absorbing design of the Air Safe hitch eliminates the problem you would otherwise have from using too stiff bars as the torsion bars and the air bag work together in a complimentary fashion.
Old 09-14-2009, 09:47 PM   #20
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Originally Posted by Mikethefixit View Post
Stufarmer
So you think a Reese hitch would do the trick for my rig? I have a 2005 F350 Diesel dually that will be pulling a 34' Airstream and have a lot of concern about sway and control.
GREENovaters is offline   Reply With Quote
Weight distribution hitches Reese Pullrite Equal-I-zer Blue Ox Hensley Air Ride markdoane Hitches, Couplers & Balls 2 09-04-2014 09:57 AM
Air Ride Hitches ShikariJones Hitches, Couplers & Balls 96 10-08-2009 02:58 PM
Pullrite hitches Randal Lee Hitches, Couplers & Balls 9 11-02-2007 08:03 AM
