Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
I called Hensley the other day to ask about something I precieved could be a problem. My Hensley points downward when the trailer is hitched up.
Because of the hight of the receiver on the H2 I need the maximum length of tow bat that Hensley makes - 8 inches. Still that is not quite enough. But because of the stresses on the tow bar they will not go any longer than 8 inches in length.
Hensley says that it is not a problem at all.
Does anybody else have this condition?
Show your support for WBCCI - MOHO2 - NO means NO! Don't let the IBT Scuttle the WBCCI - Just Vote NO! Save Wally! Buttercup Web site
Looking for a unit? Check out the SaveWally Unit Guide.
2008 Mouse count =
I have a similar problem - the Airstream rides a little high in front using the 6-inch stinger. I believe it would ride a little low with the 8-inch stinger but I have no way to tell. Here is a picture taken last week showing the position of our Hensley (it points down):
They need to make a bar for the odd sizes too (3", 5", 7"). Also you might check and be sure that your struts are not too tight, that can also push the head to point down. They should only be finger tight and 1/2 turn added.
My Hensley does the same. My Ford F250 4x4 uses the 8" drop as well. However with the 8" drop when the 25 CCD is hooked up, and the bars tensioned to the 2nd notch from the bottom (which results in a pretty good bow in the 750# bars) the trailer is prefectly level and the truck is perfectly level. The Hensley however is pointing down. The Airstream dealer, who is also a Hensley dealer, did all of the hitch setup when I picked up the trailer.
Paul & Annie
"No matter where you go, there you are..."
WBCCI #7162 AIR #1565
my understand is, a small amount of downward tilt at the front is normal/common. this is after fully linked and with the w/d bars tightened....
and also assumes your reciever isn't loose or improperly installed on the tv...
while it does depend somewhat on stinger drop length, it is also related to the position setting on the strut bars and the hole openings showing on the spring bar links at the lower end of the spring bar jacks....
of course what matters most is that the trailer is prettly level front2back and that a cat scales visit shows proper axle loads on the tv...if those 2 issues are correct downward till will be small but visible....
cheers
2air'
__________________ all of the true things that i am about to tell you are shameless lies. l.b.johnson
Good! I have not scaled the H2 with the trailer hitched up but it still does have a slight up slope when hitched up. But the H2 is level and it does tow wonderfully. From the pictures you all sent it looks exactly like what I have so all is good!
2008 Mouse count =
That is pretty. Your receiver is much closer to the ground than mine.
As for the hitch up battle, I too am getting used to it and playing around with different hitch methods. All in all it doesn't take me any longer to hitch the Hensley than the old ball hitch.
2008 Mouse count =
I am trying to match up a 2004 Nissan Armada with a hitch height of 19 inches to a 1979 AS Ambassdor that has an unhooked hitch coupler height of 15 inches. A check with carpenter level shows trailer is level unhooked. AS owners manual say hitch should be 19.5. Do not understand how to be able to pull level. Current used Hensley Hitch came with a 4 inch drop bar. Any thoughts?
2 things - First is are your axles shot? Have you checked them to still be good? If your axles are shot and you later fix them (as I have done) it will mean you will need a new tow bar. But you may need a new one already because... (keep reading)
Second, is to contact Hensley (after you have verified the axles to be good) and they will send you out the correct tow bar for the hight difference.
2008 Mouse count =
Shouldn't the WD bars be more parallel with the trailer's tongue?
In most of the pictures, the bars look like they're either mis-adjusted, or of the wrong weight rating.
