Old 07-30-2016, 03:53 PM   #1
2011 28' Flying Cloud
Farmington , Connecticut
Hensley jack assembly
So I have resisted the urge to use a electric drill/impact driver for 3 years now.
Not today. One try, one failure. I will look trough my manual, and I also remember reading about it on this forum. But if someone knows and has the fix I very much appreciate it. The top of the jack barrel has come unattached and the top sticks out and the hole unit is hanging to one side
Flying tulip is offline   Reply With Quote
Old 07-30-2016, 04:43 PM   #2
I think I might have figured it out. I brought it all the way back up and found the set screw in the small hole and set it with an Allen wrench. Still did I do that right? Or is there more to it
Old 07-30-2016, 09:47 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I don't know if the Hensley is the same as the ProPride bit I've snapped the ProPride Jack twice. There's a roll pin that connects the gear. Replace that and your all good. If the Hensley is different I don't know how to help you. Good luck!!!
Old 07-30-2016, 11:15 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If the jack screw is coming out of the top of the jack the set screw in the afore mentioned collar is loose.
If the bottom part of the jack drops out of the jack assembly, the nut on the bottom of the jack screw has come off. (The nut uses left hand threads)
FWIW, the jack will work (meaning it will do its assigned duty) in a pinch while exhibiting either or both of these conditions.
Either or both are easy fixes though.
Gradiens super tenui glacie.
Old 08-09-2016, 09:12 AM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Flying Tulip,
You fixed the jack correctly.
I use nothing but an 18 volt cordless drill at each hook up.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is online now   Reply With Quote
Hensley jack shaft Hans Grim Towing, Tow Vehicles & Hitches 15 04-26-2015 08:38 AM
Hensley or not hensley socool69 Hitches, Couplers & Balls 45 11-21-2014 09:28 AM
Hensley Hitch Jack Mifair Towing, Tow Vehicles & Hitches 4 11-08-2012 08:33 AM
To Hensley or not to Hensley Aquabud Hitches, Couplers & Balls 86 12-22-2010 09:10 PM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 04:34 PM
