Old 02-09-2009, 03:45 PM   #1
1994 30' Excella
Napanee , Ontario
Hensley hitch lubrication
Helo, we are fiairley new to rving. We have a 94 Airstream taht we park in our ONtario Canada driveway. We plan on heading South in mid March. I noticed that the nuts on top of the hitch equalizers ( I am not sure of the proper name) are a bit rusty with the melting snow. Could anyone advise as to whether I should lubricate those vertical screw tubes (equalizers?).
regards
Brian
Brian Hobin is offline   Reply With Quote
Old 02-09-2009, 05:34 PM   #2
1994 30' Excella
Mississauga , Ontario
Hi Brian,
I've got a 94 30' with a Hensley as well. And I live in Ontario. Go figure.
I have put some oil in the hole on the side of the screw jacks. Did that three years ago. Someone from Hensley warned me that if it is lubricated too well, they can unscrew by themselves when driving. This hasn't happened to me yet.
Notice I said three years.
What I have done is hook up the trailer to the tow vehicle, unlatch the ball, and then lower the trailer by lowering the jack so that I could put a large dollop of grease on the ball. It is easy to forget that there is still some movement at that connection.
Also grease all the strut mounts.
And most important, always grease the Zerks. You can't overdo this.
Al
PS my hitch is really rusty but is such heavy duty construction that it doesn't worry me too much. Just doesn't look very nice.
I guess I'm lazy. No, too busy camping.
Al
Old 02-09-2009, 06:11 PM   #3
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Originally Posted by BigAl View Post
Hi Brian,
Al
Al
I agree with AL. The main thing on the equalizers is to make sure they are working freely. If so, I would not overdo it on the lube, but as he said keep an eye on the grease at all other points. I just pulled the bearing caps off mine a couple of weeks ago and added a little extra grease(not that they really needed it). Whatever paint Hensley used does not hold up well and makes they hitches look rough, but they seem really durable.
94Tri is offline   Reply With Quote
Old 02-09-2009, 07:14 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up What's up...NORTH.
Iv'e found that VERY LITTLE graphite lube works well. Does not attract dirt, just don't over do it. Also check the lock collar allen head screw inside the little hole at the top of both jacks, if they loosen up the jack won't work. Rubber valve stem cap stuck in the hole makes a good seal. Make sure the allen sit's in the indentation in the jack screw.
I also live in an area that's hard on equipment left outside 24/7/365. I used auto clear coat spray on it when new and remove it every Fall. What's an extra 45min during Spring get-ready? It also gives me the chance to ck everything/clean & lube. Make sure all is still adjusted correctly. No big deal really.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-10-2009, 11:24 AM   #5
1994 30' Excella
Napanee , Ontario
a new question
Hello,
I can confuse myself quite ealily. When you say "--hook up the trailer to the tow vehicle, unlatch the ball, and then lower the trailer by lowering the jack so that I could put a large dollop of grease on the ball." I am not sure what you mean by the ball. We insert the square steel bar into the van and secure it and then we back the bar into the Henlsey receiver. Should I lubricate the bar and if so with grease?
Regards
Brian
Hi Brian,
Al
Al
Old 02-10-2009, 11:27 AM   #6
1994 30' Excella
Napanee , Ontario
Bearing caps?
May I ask where are these bearing caps are? I din't lnow that the Hensley had bearings--honest.
Regards
Brian
Old 02-10-2009, 11:31 AM   #7
1994 30' Excella
Napanee , Ontario
Hi Robert, may I ask what is clear coat? When you say that you remove it in the fall, are you gettig ready to go South?
Regards
Brian
Old 02-10-2009, 12:30 PM   #8
87MH's Avatar
1978 31' Sovereign
Images: 292
Full Explaination Here:
A pictorial can be found in this thread:
http://www.airforums.com/forums/f464...=hensley+arrow
Posts # 659 and 712.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-10-2009, 01:37 PM   #9
Regards
Brian
Brian,
Before I installed the Arrow I took it in in to work,(Chev store) and had the body shop spray several coats of automotive clear-coat paint. The same that is on all the late model cars. The same could be done with a spray can of clear Rustoleum. I use the vinyl cover that Hensley sells to protect it during the camping season.
I take the Arrow and tires off for Winter storage, and cover the tanks. (we're in Buffalo afterall)
No I'm not a snowbird, we stay here thru the snow season.
Name:	2007 WINTERIZE 002.jpg
ID:	75286   Click image for larger version
PFC
"Tahawus"
RLC
John Prine
Old 02-10-2009, 04:42 PM   #10
1994 30' Excella
Brian,
Those two shiny half moons in the picture on the right of the post above cover two tapered roller bearings(just like wheel bearings). Not a bad idea to pop the covers off and check if they are ok. (ie did water get in there?).
Also in the same photo above you can see that the Hensley Hitch does actually have a traditional ball that mounts into the front receiver of the trailer A frame. That is the ball connection that should be greased. After you have hooked up the trailer the way you usually do then you take out the lock or clevis and open the latch on the trailer.
Now if you extend the jack so that it raises the front of the trailer you should see the ball exposed so that you can grease it.
Al
In my previous post I believe I said lower the trailer. You should raise it.
You say you are going south in March. Any chance you can stop in at the Dogwoods and Bluegrass Rally in Kentucky?
Al
Old 02-10-2009, 04:58 PM   #11
94Tri's Avatar
1994 34' Excella
Brian,
Al
Al
Couldn't have said better myself.
Old 02-11-2009, 06:24 AM   #12
1994 30' Excella
Napanee , Ontario
Thanks Al for the pictures and the information. I am beginning to understand---slowly
Regards
Brian
New hensley hitch bdbluegrass Hitches, Couplers & Balls 8 08-20-2008 08:05 AM
Hitch Lubrication? AndyPenny Hitches, Couplers & Balls 13 11-21-2007 02:59 AM
Hensley Hitch? Brow324 Hitches, Couplers & Balls 77 09-19-2007 05:36 PM
Hitch ball lubrication Kistler Our Community 9 05-12-2003 12:48 PM
hENSLEY HITCH TCP4 Hitches, Couplers & Balls 20 10-30-2002 05:44 AM
