Old 09-20-2003, 11:08 PM   #1
Hensley Hitch Grease
I noted in previous threads that I had a large accumulation of grease between the spring bar cylinders. These are the cylinders into which the zerks screw and into which the spring bars snap.
I suspected a crack in a weld
At Hensley's suggestion, I removed the main unit of the hitch and sent it into Hensley MFG for inspection. It cost me $113 to ship the unit from Texas to Michigan. And I was told I would have to pay the return shipping. I had no problem with this since I primarily wanted to be sure the main unit was not damaged or that it had a defective weld. Hensley prople told me before I shipped that they had no other reports like mine.
I talked with the Hensley people after the hitch got up tp Michigan and this is what I learned. "That a few other instances had turned up, but the Hensley people who actually make the hitch said that over greasing the hitch could have been my problem" It turns out that cylinders cannot be fully welded at the top and there are gaps. Thus, when one pumps in the grease it can be forced out the gaps into the space between the cylinders at the top. It sure looks like this is what happened in my case.
Thus the mystery is solved. The Hensley manual says you cannot over grease. I suppose this is true, but it can sure lead to a mess. Now the only thing that I find irritating in my experience on this topic is that I will spend upwards of $200 to find out something that I think the Hensley people should have known from the getgo. It still seems a little inconceivable that I am about the only person who has pumped in so much grease that it is forced out not only at the bottom around the spring bars, but also at the top in "gaps" at the top of the cylinders.
Princer is offline   Reply With Quote
Old 09-30-2003, 02:29 AM   #2
1993 29' Excella
Jonesboro , Louisiana
Princer,
Thanks for keeping us updated on the grease delima. I, too have hac grease appear on the end of the bar that inserts into the hitch head and wondered where it came from. This explains it!!!
I am a very satisfied Hensley owner but I think they should help out with those shipping charges; especiall since it was a known problem and you discussed it with them.
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 04-11-2004, 12:15 PM   #3
Grease
I installed the Hensley yesterday. When I got to step 7 of the instructions dealing with the spring bars I added grease and watched for it to come out of the bottom as per instructions......all the grease came out the top.
Hugh & Nita
Pensacola FL
Hugh & Nita is offline   Reply With Quote
Old 04-12-2004, 03:57 AM   #4
1993 29' Excella
When I grease mine, I get grease to come out the bottom as well as the top as described in this thread. You should get something at the bottom as well. A quick check to see if the bars are being lubed is to take them out and inspect for grease. If it is present, I would not worry about it.
Welcome to the Forum!!
James Schmidt
29 ft Excello 1000
McKesh mirrors
Hensley Arrow Hitch Les Hitches, Couplers & Balls 116 12-14-2015 07:41 AM
Hensley To Equal-i-zer Hitch Experiment DreamStream Hitches, Couplers & Balls 71 04-08-2009 09:26 AM
Hensley Hitch Question Princer Hitches, Couplers & Balls 7 08-27-2003 07:16 PM
hENSLEY HITCH TCP4 Hitches, Couplers & Balls 20 10-30-2002 05:44 AM
Hensley Arrow hitch update-- greasing John Hitches, Couplers & Balls 0 04-17-2002 09:28 AM
