Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 03-25-2008, 06:17 PM   #1
toddnich
toddnich's Avatar
Profile:  2007 28' Safari SE
Westlake , Ohio
Hensley Installed- Questions
Well, it took all afternoon, but I got it installed. Took her out for a little spin around the block, and everything seems to be working well. 40 mph wind gusts, and I didn't feel anything. However, I have a few questions and concerns, and since there was no "expert" around today to help, I thought I'd ask here.
1. I screwed up and left 2 metal gold-finish rings off when I put everything back together. They look like spacers of some sort, and I'm guessing they go on the struts, but i can't tell if it's front or back. It would fit on either.
2. Are the tension spring bars supposed to lean this way and that way when you park, or when the trailer is hooked up and not at a straight angle?
3. What effect do the tension spring bars have on tongue weight? The tongue weight of my trailer and the Hensley are close to the 1000 lb. limit, but I believe that this can be offset by the w/d bars.
By the way, I know that my TV is not ideal, but it's rated for 8950 and I'm still about 2,000 under that.
Hopefully you can see the pic i tried to attach. how does it look? Maybe a little "tweak" of the w/d bars to redistribute weight to the front? I had it riding higher with my other setup. Does this look good and level?
If anyone near northeast Ohio would like to check it out for me and go for a ride, I'd be eternally grateful.
toddnich is offline   Reply With Quote
Old 03-25-2008, 06:24 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Looks like you need just a little more on the front axle. Somewhere I saw a formula for calculating proper hitch setup by measuring front and rear axle drop, but of course I can't find it now.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 03-25-2008, 06:25 PM   #3
Sean Woodruff
Commercial Vendor
Sean Woodruff's Avatar
Profile:  Grand Blanc , Michigan
Is this a used hitch you took apart and painted?
If so, the gold rings are most likely the spacers that go on the bottom of the over-center-latch clevis pin that holds the OCL into the main unit. You MUST replace those spacers or the head of the clevis pin can extend up into the links and REALLY mess up your hitch.
INSTALL THESE SPACERS BEFORE YOU USE YOUR HITCH AGAIN.
ProPride, Inc.
800-960-4767
www.ProPrideHitch.com
Sean Woodruff is offline   Reply With Quote
Old 03-25-2008, 06:31 PM   #4
jayray5
Profile:  1973 25' Tradewind
Romulus , New York
Go up another link on the chain--you can always go back. Level is good.
When you level the TT on level ground, take a picture. when you set it all up, take a picture. Some times your perception is jaded. Pictures don't lie.
jayray5 is offline   Reply With Quote
Old 03-25-2008, 06:42 PM   #5
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Thumbs up Thanks Sean
Has anyone else noticed Sean is answering questions and not his competitor? Very nice of you Sean, Karma sent. I will be upgrading to a ¾ ton in a couple of years and will upgrade my hitch then. When it comes to a choice between ProPride and the pumpkin people, I will remember this. I also appreciate the chance to make suggestions in the thread 2air strated that introduced up to ProPride (http://www.airforums.com/forums/f464...ach-37994.html) and have you take them seriously. How about posting an update there to bring us up to date. For example, did you consider my suggestion to put bronze bushings in the wear points further, etc…
Vaughan
Old 03-25-2008, 06:53 PM   #6
mi silver
Profile:  1999 25' Safari
Port Huron , Michigan
Hensley's Super Service
Hi Toddnich
I have had a Hensley on my 99 25 foot Safari since I bought it new in 1999.The dealer put mine on.My hat is off to you for installing it yourself.I think I could put one on now after all the experiences I've had with it. It is everything they advertise. I've had semi trucks past me at 85 mph and guess what no sway. I drove thru 60-70 mph winds no sway. It's a great hitch and mine is still in good shape. ANY problems you have call the service department the number for Hensley is 1-800-410-6580 .Ask for Jared he is very patient and wil help solve any problem.I have called with problems over the years and their service guys really do know this hitch.Your not going to talk to a 18 year old kid who doesn't know ---- from Shinola. Really call the service department they are super.
If you don't have a manual google wwwhensleyarrow.com .There is the complete manual on line and you can e-mail questions.THe offices are in Davidson outside of Flint Mi. The factory is in Romeo Mi.Good luck
JIm A drjjta@hotmail.com
mi silver is offline   Reply With Quote
Old 03-25-2008, 07:02 PM   #7
Sean Woodruff
Commercial Vendor
You're certainly welcome. Thanks for the karma!
I have listened to ALL of the suggestions in that thread and will get over there and update soon.
ProPride, Inc.
800-960-4767
Old 03-25-2008, 07:07 PM   #8
toddnich
toddnich's Avatar
Westlake , Ohio
thanks
i just went up to the storage lot and fixed it. duh.
another duh moment today- my safety chains are now too short, and i didn't realize it until i almost pulled them off the frame making turns. another job to do before i go anywhere.
Old 03-25-2008, 07:10 PM   #9
Sean Woodruff
Commercial Vendor
Glad to hear that! Those clevis pins are too long and can get up in the links and mess them up.
If your safety chains will hook up when you are straight in line with the trailer that is the longest they will ever need to be. They shorten in turns and you will have slack.
If you had them pulling on the frame you may have had them routed on the outside of the weight distribution bars. Make sure you rout them between the bars and under the hitch head.
ProPride, Inc.
800-960-4767
Old 03-25-2008, 07:25 PM   #10
toddnich
toddnich's Avatar
Westlake , Ohio
thanks, i'll check it out. i think that might not be the case, however, if you don't cross the chains. i know you're supposed to..
Old 03-25-2008, 07:33 PM   #11
toddnich
toddnich's Avatar
Westlake , Ohio
ok, now i'm confused. you said the clevis pin head could go "up" into the links. i think i need a visual or something. i originally dropped the pin in and put a cotter pin on the bottom. where does the spacer go? did i put the clevis pin upside down?
Old 03-25-2008, 07:38 PM   #12
Sean Woodruff
Commercial Vendor
No it drops in with the head on the top, on the links side. The spacer goes on the bottom between the cotter pin and the bottom of the main unit. The clevis pins, without the spacer, work themselves upward so that the head of clevis blocks the links.
The bottom line is the spacers go on the bottom of the clevis pin and the cotter key holds them on the clevis.
ProPride, Inc.
800-960-4767
Old 03-25-2008, 07:40 PM   #13
PWRSTRK
Profile:
Do you have a torque wrench? I finally gave in and bought one to keep in the trailer so I can check the various nuts on the hitch regularly -- then I found many other uses for it.
Tom
Tom and Frank
Evanston, Illinois
2004 Safari 28 ft Slideout "Lucy" 4 HI CAMP
2004 Ford Excursion 6.0 PSD PWRSTRK,
and Brittany, the Nova Scotia Duck Tolling Retriever
PWRSTRK is offline   Reply With Quote
Old 03-25-2008, 07:44 PM   #14
toddnich
toddnich's Avatar
Westlake , Ohio
Tom
i just bought one today. i never knew how painful 45 lbs was!
First time A/s & Hensley questions MM&MM Hitches 11 06-13-2006 10:03 PM
New Axles Installed Buttercup Axles 7 07-25-2005 05:39 PM
New Plumbing Installed Buttercup Fresh Water Systems 4 06-29-2005 10:50 PM
Installed the A/C... Anon Furnaces, Heaters, Fireplaces & Air Conditioning 40 06-13-2005 07:46 AM
New server being installed. Andy R Forum How-To's & Support 4 12-02-2004 11:30 PM
