Old 01-28-2016, 05:20 PM   #1
1997 30' Excella
Corpus Christi , Texas
Hensley hitch arm fell out
After we arrived home from a trip, the left arm fell out of the Hensley hitch. My hubby puts the bolt back in and tightens it, but when he moves the hitch, the arm falls out. Help! Any advice?
Knudsvig is offline   Reply With Quote
Old 01-28-2016, 06:04 PM   #2
1994 30' Excella
Mississauga , Ontario
I assume you mean one of the weight distributing bars. There is a zerk(grease fitting with a projecting pin that holds the bar in. If it has worn down the bar will fall out. Just order a new set of those.
Al
Al and Jean
TAC ON-3
Old 01-28-2016, 06:41 PM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Yep what bigal said!
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 01-28-2016, 06:47 PM   #4
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Read the manual! They talk about this...
Both of mine fell out first time. 1/2 of a turn of the grease fitting (after loosening the lock nut) resolved the issue...
Bruce B is offline   Reply With Quote
Old 01-29-2016, 05:21 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink From the haha manual......
"If the bar falls out, you may need to adjust the retainer pin in increments of 1/2 turn at a time and retry. Do not screw the threaded bushing too far into the hole as damage can occur to the retainer pin when towing. Finally connect the lower jack pin to the spring bar U- Bracket to secure. Repeat these steps for the 2nd bar
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-29-2016, 05:32 AM   #6
1997 30' Excella
Thank you!
We did not buy/install hitch. It came with our rig. So no manual. An Internet search turned up a pdf manual. It sounds like a grease fitting. Will diagnose and get back to you!!
Old 01-29-2016, 06:04 AM   #7
Bruce B's Avatar
I will admit it is an odd little setup...
It works well once you understand it though!
Bruce
Old 01-29-2016, 06:42 AM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
You may notice also that Hensley recommend applying grease to the spring bar grease fittings every 500 miles or so (I think from memory it is 500.)
I usually try to follow that recommendation fairly closely, although it seems a bit much.
It is a bit of a messy job, and I found the best thing to do is to carry the grease gun along with spare cartridges and clean up rags in a dedicated plastic tool box so that grease and oil doesn't get all over everything in the truck! Oil will leak from the grease gun on a hot day!
You continue greasing until you see the grease squeezing out of the spring bar bushing under the hitch - it is well to clean up the grease that squeezes out, or eventually it gets all over the safety chains, and generally makes a mess!
A minor disadvantage of using a Hensley hitch - but much outweighed by the benefits I think!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-29-2016, 07:06 AM   #9
dougandlori's Avatar
2004 28' Classic
Fresno , California
I had the same problem and now carry a spare grease zerk and set screws.
As regular maintenance check the set screws, I once had one fall out.of the screw arms.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 01-29-2016, 07:18 AM   #10
dznf0g's Avatar
Oswego , Illinois
I actually poured through the MaMaster Carr catalog and found some inexpensive fittings from which I removed the "nipple" so I could reuse the HAHA housing. IIRC, it was about $3 each for the modified nipples as apposed to $12 or $16 for the HAHA assemblies. I wish Hensley would sell the nipples separately, as that is all that wears. The McMaster work-around nipples are a bit shorter than the Hensley ones, but work fine. I made and carry a half dozen or so,.
Here is the page I got them from :
http://www.mcmaster.com/#standard-sp...ngers/=10w56ct
But I don't remember which spec I used....I would have to really dig to see if I still have the receipt.
It is necessary to cut a groove in the base of the nipple to allow grease to get to the pin and groove in the WD spring. Just a little dremmel wheel cut gets that done.
-Rich-
Old 01-29-2016, 07:21 AM   #11
Thumbs up Another reason....
Brian.
......for a complete service at your Spring Get-Ready.
PFC
"Tahawus"
RLC
John Prine
Old 01-29-2016, 07:37 AM   #12
crispyboy's Avatar
1994 30' Excella
I did the same thing - carry spare McMaster Carr modified editions. I think Hensley could have engineered this aspect of the hitch better.
WBCCI # 3072
Old 01-29-2016, 01:27 PM   #13
Tom T
Tom_T's Avatar
Orange , California
You can also ask these types of questions at Hensley's 800# & do download & print the manual for keeping in the trailer.
Also, they're Lifetime warrantied - so be careful about not adding parts not from them, which could void the warranty. Not sure if you're the original or subsequent owner.
If this was on the trailer from a prior owner, Hensley also has a process to transfer the lifetime warranty to you for a modest fee &/or to send the hitch in for them to refurb it & add the lifetime warranty for you as new owners (a member on here recently did this on buying a used one) - at their recco & your choice.
Talk to Terry Powell at Hensley & he can guide you on which is best.
Also, do the recco'd maintenance items in their manual - including grease as noted above, but also to re-torque the 4 bolts at each rear bracket on both sides jack/spring bar mounting brackets.
You can try adjusting the grease Zereks as noted in prior posts & in their manual to see if it resolves the problem.
Good Luck!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
Old 01-29-2016, 02:08 PM   #14
dznf0g's Avatar
Oswego , Illinois
Yeah, I have no warranty. Bought used and the serial # sticker was long gone.
-Rich-
Hensley Hitch 4" hitch bar to trade for a straight one StreaminGuy Airstream Classifieds 0 10-20-2015 08:03 PM
Top Rated Sway Control Hitch (Hensley Hitch) Dgresham Airstream Classifieds 0 08-27-2014 10:20 AM
Step problem--bolt fell out--inaccessible Kistler Steps 4 08-24-2003 12:07 PM
Daughter fell out of the trailer... Safari Tim 1969 - 1973 Safari 12 07-22-2003 09:01 AM
