Old 11-09-2013, 10:33 AM   #1
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Hensley Facelift II
Since we are trading in Old Lucy (2005 25FB) on New Lucy (2012 23FB) we decided that it is once again time to give our weather-worn Hensley Arrow another Facelift. We didn't like the idea of putting such a terrible looking hitch on a shinny new Airstream.
Our Hensley received its last facelift in March of 2011. Our Hensley was new in 2005, and really looked bad by 2011. It was not quite as faded this time, but getting a new Airstream warrants another facelift. We also got a Hensley rebuild kit and will replace the all of the pins and spring clips. We will also replace both of the retainer clips for the spring bars and the Zerk fittings. We will also put new shear bolts on the frame brackets. We will do most of this when we actually move the Hensley from one Aistream to the other.
SuEllyn started stripping the orange paint from the upper assembly several days ago. It was a very tedious job to get all of the paint off. She then masked off and primed the upper unit with two coats of primer. After letting the primer dry for a couple of days. She started applying light coats of the gloss orange enamel. She now has two coats on it. She is planning several more coats of orange, and at least two coats of Nyalic Clear Surface Protectant.
Below are a few pictures of the work so far.
Brian
ID:	199619   Click image for larger version
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 11-09-2013, 12:57 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
You guys do good work!!
Old 11-09-2013, 05:25 PM   #3
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Looks great. I was thinking that mine could use a refresher when I put the trailer away for winter. Maybe next spring I'll find the time for a fresh coat of paint.
andreasduess is offline   Reply With Quote
Old 11-10-2013, 10:28 AM   #4
moosetags's Avatar
Actually, it's SUEllyn that is doing this project solo. I don't have the patience for this type of work.
Brian
Old 11-10-2013, 11:20 AM   #5
ProPride Industries, Inc.
Sean Woodruff's Avatar
Holly , MI
The masking job is the most impressive part of this project. I've never seen anyone do it with the hitch installed on the trailer. Good work.
ProPride Hitch
"The Most Advanced Generation in Trailer Sway Elimination"
Holly, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 11-10-2013, 01:17 PM   #6
moosetags's Avatar
Lucy's Hensley now has its final coat of orange enamel. Hopefully, it will be ready for clear coat tomorrow.
Brian
Old 11-12-2013, 08:16 PM   #7
moosetags's Avatar
Two coats of clear coat have been applied. We're going to let it cure for a couple of days before we put the stickers on it.
Brian
Old 11-12-2013, 08:24 PM   #8
W , New England
Brian - that looks great! Did you go with Hensley orange to keep it original or do you just love the color? I'd be tempted to go black, silver, or a patriotic RWB :-)
Old 11-12-2013, 08:25 PM   #9
Gilmurr's Avatar
1998 30' Excella 1000
Halifax , Nova Scotia
Painted our Hensley while on the trailer this summer....it really made a difference. Just like yours..it looks like new. Nice job!
David & Andrea
'98 Excella 1000 Classic 30ft
2007 Toyota Tundra Dbl Cab
Gilmurr is offline   Reply With Quote
Old 11-12-2013, 08:48 PM   #10
2022 Atlas
Homosassa , Florida
Looks great. Your extra effort to strip the hitch of old paint really made for a nice finish.
Tater is offline   Reply With Quote
Old 11-13-2013, 12:14 PM   #11
moosetags's Avatar
We thought about changing colors. We've seen a couple of Hensleys painted black and one painted silver. They just don't look right to us. It would be like painting a John Deere tractor brown. It would detract from the authenticity. It would kind of be like putting big blue numbers on your airstream.
Brian
Old 11-13-2013, 12:17 PM   #12
moosetags's Avatar
Originally Posted by Gilmurr View Post
Attachment 199871
Nice work, David and Andrea. Go Orange!!
Brian
Old 11-13-2013, 04:08 PM   #13
W , New England
Brian
I get it now! Excellent analogy!
Old 11-13-2013, 05:08 PM   #14
"Cloudsplitter"
Thumbs up Look'n Good...
Brian,
That DW special looks sooper, I think ours would be beige if....ooops.
Glad I put a couple coats of clear on ours when it was new....it still looks OK.
Helps that it comes off for winter storage...
...and gets covered when installed.
Old 11-13-2013, 05:50 PM   #15
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Looks good Brian! I also like the orange paint as it makes it stand out.
I have refurbished two different HAHA hitches, disassembling to the furthest extent and each time the bearings were full of moisture and pitting. I washed out, regreased the bearings and put in new seals and they seemed to operate more smoothly.
You have a lot of miles on your hitch, have you thought about this aspect of maintenance?
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-13-2013, 06:04 PM   #16
moosetags's Avatar
Originally Posted by ROBERT CROSS View Post
Brian,
That Hensley still looks pretty good. Ours is number 8332 and was new in 2005. This is the second time that SuEllyn has repainted it. Lucy has never been winterized, and her Hensley has never been off and was never covered.
Brian
Old 11-19-2013, 08:28 PM   #17
moosetags's Avatar
No, I haven't. What was the procedure you used to do that?
Brian
Old 11-19-2013, 08:32 PM   #18
moosetags's Avatar
SuEllyn finished up with the Hensley facelift. She applied to new stickers today.
Brian
ID:	200330   Click image for larger version
Old 11-20-2013, 05:19 AM   #19
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
FABULOUS work, SuEllyn! I'll not let my wife see these pictures, as she will insist I do the same. (We call it "honest wear" or something of the sort.) <grin>
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
Silver Otter is offline   Reply With Quote
Old 11-20-2013, 06:59 AM   #20
crispyboy's Avatar
1994 30' Excella
Brian
Brian,
The procedure is virtually the same if you have ever greased a wheel bearing on your trailer.
There are a total of 8 wheel bearings and 4 wheel seals.
The silver caps are like the outside dust covers on your trailer hubs. Behind them is the cotter pin, castle nut - remove them and you can disassemble the whole hitch.
I wouldn't say the project is mandatory but I have worked on two used hitches and I like to know what I am starting with. It is messy work but in the end I have full confidence that the used equipment I have purchased is in good working order. With the entire hitch disassembled it is easy to closely inspect all of the welds and wear and tear on the weight distribution bar socket.
WBCCI # 3072
