Old 11-13-2013, 05:50 PM   #15
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Looks good Brian! I also like the orange paint as it makes it stand out.
I have refurbished two different HAHA hitches, disassembling to the furthest extent and each time the bearings were full of moisture and pitting. I washed out, regreased the bearings and put in new seals and they seemed to operate more smoothly.
You have a lot of miles on your hitch, have you thought about this aspect of maintenance?
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-13-2013, 06:04 PM   #16
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by ROBERT CROSS View Post
Brian,
That DW special looks sooper, I think ours would be beige if....ooops.
Glad I put a couple coats of clear on ours when it was new....it still looks OK.
Helps that it comes off for winter storage...
...and gets covered when installed.
That Hensley still looks pretty good. Ours is number 8332 and was new in 2005. This is the second time that SuEllyn has repainted it. Lucy has never been winterized, and her Hensley has never been off and was never covered.
Brian
SuEllyn & Brian McCabe
Old 11-19-2013, 08:28 PM   #17
moosetags's Avatar
No, I haven't. What was the procedure you used to do that?
Brian
Old 11-19-2013, 08:32 PM   #18
moosetags's Avatar
SuEllyn finished up with the Hensley facelift. She applied to new stickers today.
Brian
ID:	200330   Click image for larger version
Old 11-20-2013, 05:19 AM   #19
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
FABULOUS work, SuEllyn! I'll not let my wife see these pictures, as she will insist I do the same. (We call it "honest wear" or something of the sort.) <grin>
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 11-20-2013, 06:59 AM   #20
crispyboy's Avatar
1994 30' Excella
Brian
Brian,
The procedure is virtually the same if you have ever greased a wheel bearing on your trailer.
There are a total of 8 wheel bearings and 4 wheel seals.
The silver caps are like the outside dust covers on your trailer hubs. Behind them is the cotter pin, castle nut - remove them and you can disassemble the whole hitch.
I wouldn't say the project is mandatory but I have worked on two used hitches and I like to know what I am starting with. It is messy work but in the end I have full confidence that the used equipment I have purchased is in good working order. With the entire hitch disassembled it is easy to closely inspect all of the welds and wear and tear on the weight distribution bar socket.
WBCCI # 3072
Old 11-20-2013, 09:26 AM   #21
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I did a hitch off redo of my A-frame, battery box, jack and Hensley this summer. Sandblasted everything, primed and painted, and replaced the old Hensley zerks, bolts, pins, etc. Unlike Brian, I am not an orange Hensley loyalist, so I painted mine to match the A-frame. What a job! Took me about 2 weeks.
Name:	2013-06-23 17.38.12.jpg
ID:	200362   Click image for larger version
Name:	2013-07-06 11.39.32.jpg
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 11-20-2013, 09:45 AM   #22
crispyboy's Avatar
1994 30' Excella
Ca Streamer,
Nice looking cleanup/paint on the trailer and hitch.
Have a question: Where is the rack on the tongue that holds the LP tanks in place?
WBCCI # 3072
Old 11-20-2013, 11:14 AM   #23
TinShack's Avatar
2005 28' Safari S/O
Ca Streamer,
Thanks, Crispy! I took it off to sandblast and paint it, and in the first pic I hadn't put it back on yet. In the second pic, you can't see it because the tank cover hides it.
Steve
