Old 08-31-2017, 07:13 PM   #1
2012 19' International
Southeastern MI , Michigan
Hensley chain vs jack
We're getting a 27' this month, and since Hensley manufactures hitches right near my work I'm thinking I'll get one for the new trailer.
Which version do you prefer, the newer style with the chain or the jack version?
Countryboy59 is offline   Reply With Quote
Old 08-31-2017, 07:17 PM   #2
dznf0g's Avatar
Oswego , Illinois
Definitely Jack. It's much more easy to align the stinger when hitching. Chains let the head flop around.
-Rich-
Old 08-31-2017, 10:38 PM   #3
2007 22' International CCD
And using a wrench on a jack is much, much easier than trying to pry the chain bracket in place if you need a lot of WD bar tension.
And speaking for myself, I'm not getting younger and stronger, either.
Old 08-31-2017, 11:23 PM   #4
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Jacks for sure. I just use a rechargeable drill to tighten them. Takes 5 seconds each. The same drill and bit fits the Airstream stabilizers too so double duty.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 09-01-2017, 08:56 PM   #5
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
One big advantage to using the jacks instead of chains is the added benefit of upward spring bar dampening of the TV/TT vertical movement while pitching up and down on interstates. Known as freeway "jounce," it is caused by uneven slabs. Years ago Hensley recommended their hitch for that among other reasons. About 13 years ago, I had replaced my Easy Lift for that reason and it helped.
guskmg
Old 09-04-2017, 05:20 PM   #6
TSchleff's Avatar
2005 30' Classic
Omaha , Nebraska
I have had a Hensley since 2009 and pulled my AS over 40,000 miles with it. Absolutely love it. I have the jack distribution bars which I prefer, and if I'm correct, back in 2009 that was my only choice. The jacks allow you to angle the hitch head to match the stinger in those rare occasions when the TV and TT are at different angles. There is a learning curve, but once you "get it" you can hook up and unhook on any site and at any angle. (Having a backup camera on the pickup helps.
I'm a big fan of the projection hitch, Hensley or ProPride.
Now having said that, let me also say if all you are going to do is pull the trailer a few hundred miles from home, a couple or three times a year, I don't know if it is worth it. There are a lot of good hitches out there that can meet you needs. But if you plan on going from coast to coast, then I think the projection hitch is worth the $$.
TSchleff is offline   Reply With Quote
Old 09-04-2017, 07:25 PM   #7
Money's not an issue. I want the safest hitch. I still work so we're only on vacation a couple times a year. Last vacation took me from oil change to oil change. I think that qualifies.
If I can figure out the right stinger to get, I'm getting the Hensley.
Old 09-04-2017, 08:10 PM   #8
2002 19' Bambi
Lafayette , California
Talk to the Hensley about what stinger they suggest and get it. The drop will be close enough to being correct to get your trailer home. If it is not quite right, your being near the company makes exchange easy. If things haven't changed, an exchange is free or nearly so.
Tim
Tim A. is offline   Reply With Quote
Old 09-05-2017, 08:59 AM   #9
TSchleff's Avatar
2005 30' Classic
Omaha , Nebraska
Good for you. I think you will love it and they do add a degree of safety.
Hensley or not hensley socool69 Hitches, Couplers & Balls 45 11-21-2014 09:28 AM
To Hensley or not to Hensley Aquabud Hitches, Couplers & Balls 86 12-22-2010 09:10 PM
Safety Chain Restraint Navigator On The Road... 3 02-28-2004 11:20 AM
Safety Chain Shaclkle - Weakest Link? Creampuff Hitches, Couplers & Balls 6 12-09-2003 07:46 PM
Safety chain femuse Hitches, Couplers & Balls 4 04-19-2003 09:26 AM
