Old 11-03-2009, 02:37 PM   #15
_
Originally Posted by rluhr View Post
...Also, my apologies...
no need rich.
getting the original first person reports is the prime objective.
learning happens and better understanding matters more 4 me than being right or wrong.
victory is fleeting but SCARS last 4ever!
good stuff really !
cheers
2air
on edit, the OP has another recent thread that may be useful,
especially for rossfam' or others being PUSHED or BUMPED in the curves...
http://www.airforums.com/forums/f439...art-58070.html
and the report that marshall rog' experienced PAIN is all the more reason to read it....
Old 11-04-2009, 01:37 AM   #16
Be Calm, Have a Cupcake
Secguru's Avatar
Houston , Texas
Thanks for the excellent comments...
Thanks both to 2air who always has something worthwhile to say and also to rluhr who did not hijack the post but added a very valuable extra dimension to it. I have also been thinking about changing my brakes to disk. I noted that there are several good posts on that topic. For those interested in this topic (including me), one such post is: http://www.airforums.com/forums/f206...kes-57501.html
Be kind to everyone,
Secguru
Secguru is offline   Reply With Quote
Old 11-17-2009, 06:54 PM   #17
Ben4762's Avatar
1989 32' Excella
Lawrenceville , Georgia
It is possible to experience the Hensley bump even if your brake controller is set properly. I usually downshift my transmission when going down a steep grade and sometimes there is no need to apply brakes. The travel trailer will be free wheeling and the Hensley will bump. This could create some handling problems if it happened on a curve in the road.
Ben4762 is offline   Reply With Quote
Old 11-17-2009, 07:41 PM   #18
_
ben...
DOWNSHIFTing to slow, IN ANY CURVE is an issue while towing.
even with "on the BALL towing" the trailer will still PUSH forward.
IF this happens while using a haha it's a signal to NOT do that again.
1. SLOW (brake/shift) before the curve
2. TURN (without braking or shifting) in the curve
3. ACCELERATE (or SLOW more) after the curve
downshifting or using an EXHAUST brake can be a problem towing with ANY hitch...
IF the speed, grade, curve or deceleration CHANGE is significant.
bump = WARNING to do something different.
Old 11-17-2009, 08:57 PM   #19
Ben4762's Avatar
1989 32' Excella
Originally Posted by 2airishuman View Post
ben...
I think you missed the point I was trying to make in my post. The Hensley can bump on a straight away going down hill while using the transmission for braking. If it bumps in a curve it can cause handling problems. Some people with new Hensley's may not be aware of this. I don't brake in a curve. I've owned this hitch for 10 years.
Old 11-17-2009, 09:05 PM   #20
_
and it appears you missed THE point...
ANY hitch can push on a straight way going down hill while using the transmission for braking. If it pushes in a curve it can cause handling problems.
EVERYONE towing needs to be aware of this.
and only the haha/pp give a CLUE that PUSH is happening.
cheers
2air'
Old 11-17-2009, 09:22 PM   #21
Ben4762's Avatar
1989 32' Excella
cheers
2air'
You just don't get it. The added bump that you get from a Hensley is different from just being pushed when using another type hitch. The bump can cause handling problems going down hill.
Old 11-17-2009, 09:28 PM   #22
_
and the PUSH by an hitch can cause handling problems going down hill.
that's the GET part.
cheers
2air'
Old 11-17-2009, 09:38 PM   #23
Ben4762's Avatar
1989 32' Excella
cheers
2air'
but a "bump" along with a push causes additional problems. GOT IT?
Old 11-18-2009, 04:25 AM   #24
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
And it's still a TRAILER braking problem.
Old 11-18-2009, 06:46 AM   #25
SteveH's Avatar
Common Sense , Texas
I've not towed very much with the PP, but for what it's worth, I've not experienced any "bumps".
Old 11-18-2009, 07:08 AM   #26
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
Bump is a problem for us
We have a 30' Excella towed by a 2006 F250 PSD, using the HAHA (which we love). We have disc brakes that were retrofitted in April 2008 by David Tidmore at Roger Williams Airstream... but it was one of the last jobs he did before leaving.
We get the bump everytime unless I pre-apply a little bit of brake pressure. My efforts to correct it are detailed here: http://www.airforums.com/forums/f439...ade-41447.html
We run with the brake controller set at 10. At that setting, I am unable to get those huge disk brakes to lock up even when I'm doing 10 mph. I am convinced its the interaction of the 2006 Ford brake controller with the activator. David said its a software problem.
Unfortunately, David left before we could address the issue. I don't mean to hijack this thread, but if anybody else has faced (and fixed) this problem, please let me know.
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 11-18-2009, 08:17 AM   #27
Ben4762's Avatar
1989 32' Excella
If you are towing on level terrain and you are getting the Hensley bump when you stop it is definitely a Trailer braking problem. If you tow on hilly terrain or in the mountains sooner or later you will feel the Hensley bump. This is caused by down shifting the transmission on the tow vehicle. The tow vehicle slows when you down shift, but not the trailer. The Hensley shifts either to the right or left and you feel the bump.
Old 11-18-2009, 10:45 AM   #28
_
Originally Posted by Tin Diesel View Post
...We run with the brake controller set at 10. At that setting, I am unable to get those huge disk brakes to lock up even when I'm doing 10 mph. I am convinced its the interaction of the 2006 Ford brake controller with the activator...
hi tin
craftsman HERE has the 2006 with ITBC and had issues UNTIL upgrading to the larger reservoir (ver.2) of the actibrake.
i see you'll already got that version.
my thought would be in the WIRING/install.
did david set the voltage at something LESS than full voltage (he did this on richL's trailer) ???
see the post earlier in this thread about that...
__________
the ford controller is NORMALLY set to scale back voltage with REALLY slow speeds.
so IF THAT is combined with a controller install (on the trailer side) with lower voltage,
the 2 together may be limiting the availability of FULL power.
that's just a wag on my part.
__________
some1 should explore the wiring/install with a voltmeter, along with the wiring/schematics and determine how much juice is flowing.
and given actibrake is no longer in the biz, u might be better off long term installing a different controller/reservoir.
have u contacted kodiak to see what system THEY recommend now?
good luck.
2air'
Hensley or Propride rochar3 Hitches, Couplers & Balls 88 04-01-2017 11:05 PM
HELP!!! Hensley vs ProPride 3P sempi2 Hitches, Couplers & Balls 91 12-08-2014 09:43 PM
Bump Your Head Yet? ArveeBob Base Camp 26 05-21-2010 11:06 PM
Hensley with Propride adjustable stinger boondockdad Hitches, Couplers & Balls 5 12-03-2008 07:55 PM
