Old 04-16-2012, 02:23 PM   #1
timmaah's Avatar
1999 25' Safari
On , the road
Hensley - Bent shaft on frame brackets?
On my Hensley.. circa 1999, the two posts that the jack assemblies mount on are bent downward. I assume this is not normal as they are bent at different degrees.
Is this something that needs to be fixed/replaced before I can use the hitch? Would this have happened from someone torquing down way too much on the wd bars? Also the jack assembly portion that slides over this post has a lot of play in it. Is this normal?
I have never towed this trailer or hitch before. According to previous owners there are ~30k miles on the setup.
timmaah is offline   Reply With Quote
Old 04-16-2012, 02:36 PM   #2
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Wow. Yeah, that's definitely a problem that should be covered under warranty. I would NOT tow with that condition. I imagine the collars that hold the jack assembly on would be under a lot of force and potentially 'pop off'.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 04-16-2012, 03:32 PM   #3
SteveH's Avatar
Common Sense , Texas
Be happy first that you caught the bent parts before using the hitch, and also that nothing has broken. I've heard of parts breaking on the Hensleys, even to the point that one person I talked with carries spares with him.
Old 04-16-2012, 03:35 PM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Glad you checked it. Put up pics of the rest so we can ooh and ahh . . (help you make sure).
Old 04-16-2012, 04:40 PM   #5
timmaah's Avatar
1999 25' Safari
On , the road
Everything else appears to be in great shape. The main assembly has a bit of surface rust. I have it all apart, cleaned and ready to paint. Though I'm going to wait on a response from Hensley on this issue before I go further.
Old 04-16-2012, 05:08 PM   #6
2002 19' Bambi
Lafayette , California
I find the way they are bent a bit strange. It is possible that jacking up the WD bars did it, but your trailer's tongue weight is lower than what many Hensley hitches are subjected to. Perhaps somebody stood on the posts while the WD bars were pulled up.
The assembly that slides over the post is supposed to be loose. That allows the jacks to move freely during operation.
Tim
Tim A. is offline   Reply With Quote
Old 04-16-2012, 05:36 PM   #7
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Dont look safe to me,, I would sure look for stress cracks...
Must have been set up wrong,, and one heck of a dip,, or pot hole..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 04-17-2012, 02:31 PM   #8
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
WOW, our Hensley dates from 1999, too. It easily has 30K miles on it, heck, I put 26,000 on last summer. No evidence of bending like the picture on ours. We will all be interested what the factory has to say about the possible cause and the "fix" if there is any.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 04-17-2012, 06:30 PM   #9
timmaah's Avatar
1999 25' Safari
On , the road
Hensley did not seem to be overly concerned about the bends.
Old 04-17-2012, 08:18 PM   #10
dznf0g's Avatar
Oswego , Illinois
I been holding back on comment until I heard the response from Hensley. As some of you know, I found a great deal on an apparent low mile used HAHA a few months ago. One of my frame brackets has a slight bent in the jack post. When I called Hensley I got the same response. It is apparently caused when in a tight backing turn AND a sizable dip. Once the arc is set, it never changes. Just inspect for cracks....if none, continue forward.
-Rich-
Old 04-18-2012, 09:08 AM   #11
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
This problem first appeared when the jack busing was changed from an angled cut to a straight cut. I would bet that your jack bushing is a square cut and not cut like the photo I have attached.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 04-18-2012, 10:01 AM   #12
ProPride, Inc.
^^ bushing
not busing
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 04-18-2012, 08:28 PM   #13
dznf0g's Avatar
Oswego , Illinois
Yes, Sean, mine is square cut....I believe that the bottom of the inside jack gets a lot of side load toward the center of the A frame in a hard turn and the bushing gets in a bind and turns the end of the frame bracket post downward.
Mine is less severe than Timmaah's and appears to more at the tip of the post.
-Rich-
