Old 12-01-2011, 08:58 PM   #1
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
Hensley Arrow weight adjustment question
Well, we are almost there. We have a 2012 25FB Flying Cloud with a Hensley Arrow setup and a Chevy Trailblazer for a TV. How do we know when we have the weight adjustment correctly done? Is it trial and Error? There has to be a better way. I need some help guys.
danlehosky is offline   Reply With Quote
Old 12-01-2011, 09:54 PM   #2
2006 30' Classic
Milton , Florida
Hensley Arrow Setup Procedure
The following link may give you some ideas on how to approach your Hensley Arrow setup.
http://www.airforums.com/forums/f238...hts-73579.html
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 12-02-2011, 05:42 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
This may help you, too:
http://www.airforums.com/forums/f464...ide-26279.html
Old 12-02-2011, 06:56 AM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
It's a one-day PITA. For a new guy. Looks complicated (on paper) but isn't. One has to know weights and then apply proper leverage through the hitch apparatus. That's it.
Just did an autopsy of an H/A setup, starts on Post #50:
Disk Brake Conversion
Here's a handy quote from Ron Gratz about working the WDH numbers in the most basic sense (for the default TV, a pickemup or similar):
"A properly sized and adjusted weight distributing hitch will
"transfer" a load equal to approximately 20-25% of the tongue weight to the TT's axles.
A load equal to about 75-80% of the tongue weight will be added to the TV's rear axles."
You'll need (and post):
TV door sticker on:
GAWR, FF & RR
GCWR
GVWR
TT:
GVWR
TW
And then a set of scale readings for TV & TT, empty
TV, empty: driver, with full fuel (and anything permanent in truck; toolbox)
TT: empty, but with full propane/fresh water plus permanent equip/supplies.
With manufacturer published numbers, and true "empty weight" one can know the range to work within. Short of this means frustration. Get the published and empty weights, please.
TW: a separate number is invaluable. Home TW Measurement
Once the numbers are available (a full set thereof, otherwise no go) then the rigging can be dialled in. This involves a trip to a certified scale. Use the Ron Gratz chart as shown in the autopsy above, or copy off the blank from the other thread below. Being able to double-check numbers is key.
After that, a few more adjustments as necessary, and scale tickets to confirm.
With future trips, one will learn -- with an accumulation of certified scale weight tickets (3-pad scale) -- the potential range of adjustments to work with differing loads (short or long trips, different loadings, etc).
Visited CAT Scales and Numbers are in
WDH & Tire Wear
Read a good bit. Don't worry over "debates", the money is on having the proper numbers from which to dial in the rigging. The rest is the usual fun-and-games around here.
Numbers talk. The CAT Scale is your friend. Initial adjustments are great, but experience with the TV-TT rig means finding what works best. It is not just a one-time thing, but a trend.
Old 12-02-2011, 09:16 AM   #5
2007 25' Safari FB SE
Eureka Springs , Arkansas
My method was to measure the distance from ground to top of rear wheel lip.
After I hooked up, I adjusted bars until measurement was the same as unloaded.
I then wrapped white electrical tape on the adjustment jacks so I can quickly adjust it.
triplenet is offline   Reply With Quote
Old 12-02-2011, 09:21 AM   #6
easplund's Avatar
2014 28' Land Yacht
Phoenix , Arizona
Yes, and no. I found that I had to try a setting, drive it for a while, and then make adjustments. Basically, I needed to keep applying more tension until the ride smoothed out.
I should add that I spoke with Hensley a couple of times about this, and they said that how the vehicle rides is the most important factor, and not how level it looks, or how much its height changed, or how much the spring bars are tensioned.
easplund is offline   Reply With Quote
Old 12-02-2011, 09:46 AM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Disclaimer: I have no Hensley experience. Your hitch, in fact, is the Hensley I've looked at most closely (last August in Eureka Springs.) In general, though, I think you're missing something with your method. You should measure both the front and rear distances from ground to the wheel arch before and after hitching up and look for the proper adjustment to keep the tow vehicle level. If you adjust so that the tow vehicle doesn't drop at all at the rear axle when you load up with the trailer's tongue weight, you may be transferring too much weight to the steering axle.
David
hensley, weight
Weight Distribution Question star kitty Hitches, Couplers & Balls 23 11-30-2011 05:09 PM
Hensley Arrow Orson Hitches, Couplers & Balls 20 10-24-2011 05:36 PM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
Lets talk Hensley 1400lb spring bars and grease fittings mikeb9550 Hitches, Couplers & Balls 0 03-20-2011 10:18 AM
31' Classic weight question pappy19 Tow Vehicles 11 02-06-2011 09:55 AM
