Old 04-18-2010, 11:08 PM   #1
72Blazerod's Avatar
1986 29' Sovereign
Delta , British Columbia
Images: 31
Hensley Arrow on a 2006 GMC 2500 - what is the 'drop' for the stinger?
Hi guys,
I just bought a 2006 GMC 2500 6.6l Duramax 4x4. It is stock height. Just wondering if anybody has this set up and could tell me how many inches the drop of the "stinger" that connects to the truck is. Thanks!
Rod
72Blazerod is offline   Reply With Quote
Old 04-19-2010, 06:40 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
You really need to do an actual measurement for your truck as tire height can affect this figure and whether of not your GM truck has its OEM receiver. Many owners got rid of the originals as they were so weak.
To measure for the Hensley, get your trailer perfectly level on level ground. Measure from the ground to the top of the opening where the stinger goes. Do the same measurement with the tow vehicle loaded with the stuff that you carry in the truck when you travel with the trailer.
Keep in mind that Hemsley makes their hitch bars in 2" incriments (0-2-4-6-8-10"). Also be aware that ProPride make a height adjustable hitch bar for the Hensley Arrow. They are somewhat pricey ($500), but can be an answer to adapting to changing situations.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 05-13-2010, 06:26 PM   #3
72Blazerod's Avatar
1986 29' Sovereign
Images: 31
I was just wondering how much drop other people have used with their stock (bone stock in height) 2006 GMC 2500 4x4 Duramax Crew Cab short box with the stock reciever hitch. I currently have a 4" drop hitchbar, but I was wondering if other people have to order a 6" drop bar for this application. The 4" drop was for a 1998 Suburban 3/4 ton with air helper springs. (My big problem is finding enough level ground for the truck and trailer to both be perfectly level - I live in very hilly terrain)
If you have a STOCK 2006 GMC 2500 4x4 Duramax Crew Cab short box, what have you used. I'd like to see if the set up I have will work before I try to get in touch with Hensley.
Rod
Old 05-13-2010, 06:35 PM   #4
_
measure the RECEIVER height (inside top of 2 inch box) and post it.
there are many many posts with pictures of receiver height/stinger drop and selecting a drop.
the haha manual explains selection and their tech support will also supply the info.
SOME of the variation depends on the TONGUE weight and w/d tension required to dial in the rig.
and the condition of the trailer AXLEs also affects this.
many of us were/are INbetween 4 and 6 and must compromise to get the ideal combo...
thankfully that's NOT an issue 4m nemore.
cheers
2air'
Old 05-13-2010, 09:14 PM   #5
72Blazerod's Avatar
1986 29' Sovereign
Images: 31
I went outside and measured. To the inside top of the reciever hitch box is 20.5". This is with the truck unloaded and sitting in my 'almost' level driveway. Should I put some weight in in the back of my truck before I make my measures?
Thanks again,
Rod
Old 05-13-2010, 10:13 PM   #6
_
ok, rod
so that puts it in the 6 inch drop range...
could be a tad less but if the trailer axles aren't new, 6 is probably good.
i'm at 20 (with the truck FULL) and use ~6...
see this pic (but it's not the same tv or same spring rate)
http://cdn.airforums.com/forums/atta...2&d=1259125188
and here's a member with ~ almost the same tv who switched from 4 to 6 with satisfaction (see posts #211-215)
http://www.airforums.com/forums/f464...tml#post370047
IF u call their tech support with that measurement, they should be able to determine this.
cheers
2air'
Hensley with Propride adjustable stinger boondockdad Hitches, Couplers & Balls 5 12-03-2008 07:55 PM
Hensley Arrow transfer to another AS? starflyte1 Hitches, Couplers & Balls 24 12-23-2006 07:41 PM
Hensley Stinger Cover davidz71 Hitches, Couplers & Balls 2 05-14-2006 09:21 AM
Hensley Arrow ctdair Hitches, Couplers & Balls 0 09-26-2005 10:05 AM
Hensley Arrow, will it help? 74SovereignInt. Hitches, Couplers & Balls 20 04-05-2003 10:36 PM
