Old 07-11-2015, 12:24 PM   #57
1989 34' Excella
Cedar Hill , Tennessee
I think it's to much drop on the hitch from the pictures, we have the opposite issue with our Hensley.
rob2015ellen is offline   Reply With Quote
Old 07-11-2015, 05:07 PM   #58
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Call Hensley. They'll guide you on where to measure and to get the right stinger.
Old 07-11-2015, 05:23 PM   #59
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
That looks like an 8" drop hitch bar in the photo. When it's real low like that, it tends to bottom out in driveways much more often.
Brian
SuEllyn & Brian McCabe
Old 07-13-2015, 06:49 AM   #60
philipsinewe's Avatar
2003 30' Classic
Centerville , Ohio
That is clearly the wrong drop bar. I assume you have already changed it.
philipsinewe is offline   Reply With Quote
Old 10-09-2015, 04:26 PM   #61
Oak Harbor , wa
used Hensley purchased
Recently purchased a used Hensley arrow, installed on 25' AS, love it beyond belief. I have read about these hitches for a long time, found a used one at reasonable price. Did the cut and paste to weld modify the drop, painted the hitch Airstream platinum to match the tongue.
Looks great, tows great, can not believe the difference from a std WD hitch. Easy to hook up, I have the Hensley brackets, not jacks. Once stinger is connected I raise the tongue 3", then snap up the chains. Easy, best medicine for care free towing.
Stormalong is online now   Reply With Quote
Old 10-09-2015, 04:58 PM   #62
Retail6's Avatar
2007 28' Safari SE
Springdale , Arkansas
Totally happy with my Hensley. The support guys were right there with me via phone when I installed it. Sent them the pictures of the setup, they had me change a couple of things and the trailer pulls like a dream. No more worry about being passed or much of anything. Sure I paid more, don't care. With that type of support and ease of use, its well worth the investment. I did sense a bit of attitude with PP, not sure if it was in the videos or posts here in the forums.
Retail6 is offline   Reply With Quote
Old 10-27-2015, 07:21 PM   #63
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
hitch weight
Please provide the physical weight of the Hensley and the Protrude hitch, jacks., bars, and stinger assembly? I have the impression that it is about 200 pounds, but can't find any data. Your info or direction to where it can be found is appreciated.
Old 10-27-2015, 10:18 PM   #64
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Shipping weight for a Hensley is about 200 pounds complete.
That is as close as I can get to answering your question.
Sorry!
Brevi tempore!
Old 10-28-2015, 09:29 AM   #65
PKI
PKI's Avatar
Sorry!
Brevi tempore!
Thanks for the response. Was hoping for less, but light weight unobtainium is likely in short supply. Pat
Old 10-28-2015, 10:37 AM   #66
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
On the bright side, once the main part of the hitch is on the trailer it stays on the trailer. The heaviest thing that needs to handled routinely is the the stinger.
Brevi tempore!
Old 10-28-2015, 11:29 AM   #67
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The weight of our Propride as 180 lbs including the stinger. Our other hitch was 80 lbs, so our ProPride is 100 lbs more than the conventional hitch. To take it a little further, our ProPride adds 25 lbs to each axle of our 12,000 lb Airstream/truck combo after weight distribution. Hardly worth thinking about.
The only significance of the ProPride weight to me is that I never lift the hitch head, only the stinger. Which for practical purposes makes it lighter than our former conventional hitch where I had to lift the whole thing to hook and unhook it.
Doug and Cheryl
Old 10-28-2015, 05:48 PM   #68
PKI
PKI's Avatar
Understand your point. Thanks for the information.
Old 10-31-2015, 05:58 PM   #69
Milwaukee , Wisconsin
Hensley weight...precise;
Head unit = 99lbs (boxed)
Hitch bar = 71lbs (boxed, and can vary by drop distance)
WDH bars = 54lbs (boxed)
RinconVTR is offline   Reply With Quote
Old 10-31-2015, 10:17 PM   #70
PKI
PKI's Avatar
So that would be 224lbs total. Thank you very much.
Hensley To Equal-i-zer Hitch Experiment DreamStream Hitches, Couplers & Balls 71 04-08-2009 09:26 AM
Hensley Arrow hitch Ed Keyes Hitches, Couplers & Balls 33 05-26-2004 07:55 PM
Hensley Hitch Grease Princer Hitches, Couplers & Balls 3 04-12-2004 03:57 AM
Hensley Hitch Question Princer Hitches, Couplers & Balls 7 08-27-2003 07:16 PM
Hensley Arrow hitch update-- greasing John Hitches, Couplers & Balls 0 04-17-2002 09:28 AM
