Old 09-18-2011, 06:53 PM   #15
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Kirk,
I've found a liberal smear of grease on the stinger makes for smooth disconnect.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-20-2011, 09:41 AM   #16
2012 25' FB Flying Cloud
2015 Interstate Ext. Coach
Nevada City , California
Hensley
Dear Bob-
It is the large cotter pin (maybe it is not called a cotter pin?) which secures the
hitch to the tow vehicle. There is very little space in which to operate and the pin is very tough. My husband uses a hammer and pliers and has a tough time.
Since I will be going alone, much of the time, this really worries me.
Thank you in advance for your greatly appreciated help. Orson
Orson is offline   Reply With Quote
Old 09-20-2011, 12:47 PM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Orson,
This is the pin?
And this what most call the "stinger", it slides into the receiver of the Tundra.
I know even on our Burb the area you need to get to is difficult, makes it a little difficult to line up the holes and install the pin. Once lined up the pin should slide in without any hammer persuasion.
A light bulb moment....
"which secures the hitch to the tow vehicle."
The above quotation begs the question........You are installing the stinger into the receiver, installing the pin and then backing into the square opening of the HAHA, right?
OK silly question but I had to ask.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-20-2011, 01:45 PM   #18
Orson,
BTW....Did the selling dealer give you the Install/Parts manual for the HaHa.
If not you can download it at the Hensley web-site.
PFC
"Tahawus"
RLC
John Prine
Old 09-21-2011, 09:56 AM   #19
Hensley Hitch cotter pin
Bob,
I just read your response to my husband and I am not certain I have communicated well. After the stinger is placed in the receiver, there is a metal,
round solid tube which goes horizontally through the stinger and the receiver to
hold it into place. Through the end of this tube/bar is a hole into which a pin is
inserted(cotter pin) to secure the whole unit. Perhaps the tube is too short? It
is extremely difficult to insert the pin. I will call Hensley. Thank you for your help. Orson
Old 09-21-2011, 10:33 AM   #20
Thumbs up
Orson,
That's what I thought.
Mine is also very cramped and difficult to get lined-up, and almost impossible to get the lock/cotter pin in.
I solved it with a dog-bone locking pin from Reese. It comes with a round key which makes it easier to un-lock and remove.
PFC
"Tahawus"
RLC
John Prine
Old 10-24-2011, 05:36 PM   #21
TSchleff's Avatar
2005 30' Classic
Omaha , Nebraska
These are all great ideas for hooking up the HAHA ... and I will throw in another, which I think I saw somewhere on this website. Little hard to explain, but let me try.
I use two of those lime green poles with the magnets on one end. And I have found if I spend a few minutes at the time of unhooking the trailer, it makes hooking up easier. Let me explain.
When I'm ready to disconnect the trailer at the RV Park, I loosen the weight distribution bars until they are sloppy lose. Then I raise or lower the trailer tongue until the pen that goes through the stinger on the TV hitch can be turned by hand. This tells me there is no weight on the stinger or the hitch of the truck. I then pull the TV forward until the stinger comes out of hitch just a few inches.
At this time I put one of the poles on the very end of the stinger and one on the HAHA right above the front of the receiver. Then I use the cranks on the weight distribution bars, just like the handles on a wheelbarrow to get the two poles to be exactly parallel, in all directions. Now I know when it comes time to hook up the trailer I know the hitch and stinger are set at the right angle. I now adjust the height of the trailer so it is level.
When it comes time to hook up the trailer, I put both poles back where they were. One at the very end of the stinger and one right above the opening of the receiver. I slowly back up lining up the poles and stop right before they touch. Then I raise or lower the trailer to match the height of the stinger and finish backing it in.
Since I have started using this approach it really makes hooking it up real easy and quick. Now you are probably asking; why spend the time of making the poles parallel at time of unhooking? There are two reasons; 1) Seems like I'm always a little more rushed to get going in the mornings than unhooking in the PM. 2) This is the hard one to explain. If the TV and TT are on different plains, then the poles are very hard to "read". And, unless your significant other is great at giving directions to get the stinger and hitch to match up .. you will find yourself making several stabs at getting the stinger close to the hitch. Trust me, it you try this you will see the advantage of getting the stinger and hitch matched upon disconnect.
The key is to get those two poles parallel in all directions, both front to back and sideways.
One final comment about the HAHA. Last year we traveled 5,500 miles pulling the trailer in all kinds of weather and wind. It works great.
TSchleff is offline   Reply With Quote
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
Hensley zerks sheared off mojo Hitches, Couplers & Balls 10 05-23-2011 07:47 PM
Hensley stinger. BigAl Hitches, Couplers & Balls 4 04-06-2011 06:49 PM
Lets talk Hensley 1400lb spring bars and grease fittings mikeb9550 Hitches, Couplers & Balls 0 03-20-2011 10:18 AM
Hensley Hitch Value L4740 Hitches, Couplers & Balls 5 01-18-2011 08:05 PM
